Internal webserver UI
PostPosted: Fri Dec 04, 2015 10:36 pm
I did see the labels not being kept though.
I'll work on this shortly.
PostPosted: Sat Dec 05, 2015 5:54 am
It happens to me when going from custom, with it's own hard-coded speed and duration, to any other mode. It shows the custom speed and duration until a refresh.
Also, there seems to not be an icon for gyre?
PostPosted: Sat Dec 05, 2015 7:29 am
lnevo wrote:
cosmith71 wrote:Changing DC pump modes shows the icon for the previous mode until refreshed.
Edit: Just tried it on a different computer and it works as expected?
Edit part 2: Speed and duration don't automatically refresh. If I go from a specified mode with default speeds to custom mode with hard-coded speeds, the new speed/duration doesn't change until I refresh.
I hope this kind of stuff is what you were looking for, otherwise I'm just being a jerk. :mrgreen:
The problem is when you issue a wifi command to change something you get back OK and you don't get the same results like when setting a relay which returns the entire XML. Then you'd have to do a second query.
We could do 2 things to streamline that. Instead of sending just OK or ERR. We could put a status flag in the /sa /r99 output. It might break some of the current apps, but we'd just be adding the same tag it's looking for inside the rest of the output.
The other would be making the second call to the web ui to refresh. But I have issues sometimes if I query to quickly so a slight delay wouldn't be horrible. This btw, is all the same behavior of the current UApp also.
I implemented a delay when refreshing from that command in my app for the same reason. too fast of request will error out.
PostPosted: Sun Dec 06, 2015 8:45 pm
cosmith71 wrote:It happens to me when going from custom, with it's own hard-coded speed and duration, to any other mode. It shows the custom speed and duration until a refresh.
Can you post the relevant code for me to replicate the problem?
PostPosted: Mon Dec 07, 2015 3:42 am
Here you go.
void PumpControl()
  // *******************  Pump Control *******************
  if (InternalMemory.DCPumpMode_read()==11)   // If custom mode on Portal
    ReefAngel.DCPump.UseMemory = false;    // Turn off memory control
    ReefAngel.DCPump.SetMode(Else,60,30);  // If nothing changes it in the next few lines, this is what runs.
    ReefAngel.DCPump.Threshold=20;
    if (hour()>=22 || hour()<9) ReefAngel.DCPump.SetMode(Gyre,80,30,50);  // Gyre max, duration, minimum
    if (hour()>=9 && hour()<10) ReefAngel.DCPump.SetMode(Gyre,90,30,60);  // Gyre max, duration, minimum
    if (hour()>=10 && hour()<11)
      ReefAngel.DCPump.SetMode(Else,40,20);    // Else mode from 1000 to 1100.  Wake up!
  else ReefAngel.DCPump.UseMemory = true;    //  If it's not custom mode on the portal, then do what mode the portal says.
PostPosted: Mon Dec 07, 2015 10:12 pm
But if you are using usememory=false, you shouldn't be able to change speed and duration, right?
PostPosted: Mon Dec 07, 2015 10:43 pm
Yeah you're logic is a bit off..once in custom how do you get out?
PostPosted: Tue Dec 08, 2015 6:03 am
Correct. Custom uses the hard coded values. Right now, they are gyre 80/30. The memory values for a non-custom mode are, say, 60/20. If I switch from custom with coded values of 80/30 to, say short pulse, the speed and duration still show the coded values of 80/30 instead of the memory values of 60/20 until I do a refresh. Same if I go back to custom from a memory mode. The mode display updates immediately, but the speed and duration values don't update on the screen until a refresh.
Lee, you can choose any mode you like from the DC Pump page. The code can tell when custom is selected.
PostPosted: Tue Dec 08, 2015 6:41 am
Right nevermind. I misread the if statement. If memory is set to non custom the RF.UseMemory is true.
PostPosted: Thu Dec 17, 2015 8:40 am
how do I update to the newest libraries?
