Tide function (proper use quesiton)
PostPosted: Fri Feb 05, 2016 3:45 pm
That was from reeftronics.net go check it out and sign up. You will get a 24 hour, 7 day history and 30 day graph of most parameters
PostPosted: Sun Apr 17, 2016 3:57 pm
I am having trouble with the tide speed call. My speed stays fixed on 50 no matter what time of day. Is this how the code is supposed to operate? I thought this would vary.
#include <SunLocation.h>
#include <Tide.h>
   strcat(text, "  ");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 93, "Salinity:");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 75, 93, text);
   ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
Tide tide;
byte tideSpeed = tide.CalcTide();
SunLocation sun;
int DaylightPWMValue = 0;        // For cloud code
                         // Define Relay Ports by Name
#define MoonLights         1
#define ATOPump              2
#define Unused             3
#define ATOCirculation     4
#define Skimmer            5
#define MainPump           6
#define WhiteLED           7
#define BlueLED              8
   ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
   ReefAngel.FeedingModePorts = Port5Bit | Port4Bit | Port6Bit;  // Ports toggled in Feeding Mode
   ReefAngel.WaterChangePorts = Port5Bit | Port4Bit | Port6Bit;  // Ports toggled in Water Change Mode
   ReefAngel.DCPump.FeedingSpeed = 0;
   ReefAngel.DCPump.WaterChangeSpeed = 0;
   ReefAngel.LightsOnPorts = Port1Bit | Port7Bit | Port8Bit;
   ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
   InternalMemory.OverheatTemp_write(869);
   ReefAngel.Relay.On(Port2);
   ReefAngel.Relay.On(Port4);
   ReefAngel.Relay.On(Port5);
   ReefAngel.Relay.On(Port6);
   tide.Init(45, 10, 30);
   tide.SetWaveLength(12 + SECS_PER_HOUR);
   sun.Init(25.6839518, -80.4713138); // Miami, FL
   sun.SetOffset(-4, 0, -4, 0); //Offset to get Eastern Time Zone
   CheckCloud();
   ReefAngel.PWM.SetChannelRaw(0, DaylightPWMValue);
   sun.CheckAndUpdate();
   byte w_risehour = sun.GetRiseHour();
   byte b_risehour = sun.GetRiseHour(); //Starting Blues an hour before
   byte riseminute = sun.GetRiseMinute();
   byte w_sethour = sun.GetSetHour();
   byte b_sethour = (sun.GetSetHour()) + 1;
   byte setminute = sun.GetSetMinute();
   char label_rise_hr = sun.GetRiseHour();
   char label_rise_min = sun.GetRiseMinute();
   char label_set_hr = sun.GetSetHour();
   char label_set_min = sun.GetSetMinute();
   byte vtDuration = InternalMemory.RFDuration_read();
   ReefAngel.StandardLights(Port7, w_risehour, riseminute, w_sethour, setminute);
   ReefAngel.StandardLights(Port8, b_risehour, riseminute, b_sethour, setminute);
   DaylightPWMValue = PWMSlopeHighRes(w_risehour, riseminute, w_sethour, setminute, 0, 50, 60, 0); //White SunLocation
   ReefAngel.PWM.SetChannelRaw(1, PWMSlopeHighRes(b_risehour, riseminute, b_sethour, setminute, 0, 85, 30, 0));  // Blues SunLocation
   ReefAngel.StandardLights(Port1, w_sethour, setminute, w_risehour, riseminute); //Moon Lights
   ReefAngel.CustomVar[0] = label_rise_hr; //Sunrise time label
   ReefAngel.CustomVar[1] = label_rise_min; //Sunrise time label
   ReefAngel.CustomVar[2] = label_set_hr; //Sunset time label
   ReefAngel.CustomVar[3] = label_set_min; //Sunset time label
   ReefAngel.CustomVar[4] = tideSpeed; //Tide speed
   ReefAngel.CustomVar[5] = vtDuration; //Tide duration
   ReefAngel.DCPump.Threshold = 20;
   if (hour() >= 0 && hour() < w_risehour) {
      ReefAngel.DCPump.SetMode(Lagoon, tideSpeed, vtDuration);
   else if (hour() >= w_sethour && hour() <= 24) {
   else if (hour() >= w_risehour && hour() <= w_sethour)
      ReefAngel.DCPump.SetMode(LongPulse, tideSpeed, vtDuration);
   ReefAngel.Portal("CaliFSU");
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(9,00)
   // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
   // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
   // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
   byte LightningModes[] = { Mega2,Mega,Mega };
   static byte cloudchance = 255;
   static byte cloudduration = 0;
   static int cloudstart = 0;
   static byte numclouds = 0;
   static byte lightningchance = 0;
   static byte cloudindex = 0;
   static byte lightningstatus = 0;
   static int LastNumMins = 0;
   static byte lightningMode = 0;
   static boolean chooseLightning = true;
   static time_t DelayCounter = millis();    // Variable for lightning timing.
   static int DelayTime = random(1000);      // Variable for lightning timimg.
   if (hour() == 0 && minute() == 0 && second() == 0) cloudchance = 255;
#ifdef forcecloudcalculation
   if (cloudchance == 255)
#else
   if (hour() == 0 && minute() == 0 && second() == 1 && cloudchance == 255)
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance = random(100);
      if (cloudchance>Cloud_Chance_per_Day) cloudchance = 0;
      if ((day() % Clouds_Every_X_Days) != 0) cloudchance = 0;
      // If we have cloud today
      if (cloudchance)
         numclouds = random(Min_Clouds_per_Day, Max_Clouds_per_Day);
         cloudstart = random(Start_Cloud_After, Start_Cloud_After + ((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2)));
         cloudduration = random(Min_Cloud_Duration, Max_Cloud_Duration);
         lightningchance = random(100);
         if (lightningchance>Lightning_Change_per_Cloud) lightningchance = 0;
   if (cloudchance)
      //is it time for cloud yet?
      if (NumMins(hour(), minute()) >= cloudstart && NumMins(hour(), minute())<(cloudstart + cloudduration))
         DaylightPWMValue = ReversePWMSlope(cloudstart, cloudstart + cloudduration, DaylightPWMValue / 40.95, 0, 180)*40.95;
         if (chooseLightning)
            lightningMode = LightningModes[random(100) % sizeof(LightningModes)];
            chooseLightning = false;
         switch (lightningMode)
         case Calm:
            break;
         case Mega:
            // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
            if (lightningchance && random(ReversePWMSlope(cloudstart, cloudstart + cloudduration, 100, 0, 180))<1 && (millis() - DelayCounter)>DelayTime)
               // Send the trigger
               Strike();
               DelayCounter = millis();    // If we just had a round of flashes, then lets put in a longer delay
               DelayTime = random(1000);   // of up to a second for dramatic effect before we do another round.
            break;
         case Mega2:
            // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
            if (lightningchance && random(ReversePWMSlope(cloudstart, cloudstart + cloudduration, 100, 0, 180))<2)
               Strike();
            break;
         case Fast:
            if (lightningchance && (NumMins(hour(), minute()) == (cloudstart + (cloudduration / 2))) && second()<5 && (millis() - DelayCounter)>DelayTime)
               Strike();
            break;
         case Slow:
            // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
            if (lightningchance && (NumMins(hour(), minute()) == (cloudstart + (cloudduration / 2))) && second()<5)
               if (random(100)<20) lightningstatus = 1;
               else lightningstatus = 0;
               if (lightningstatus)
                  DaylightPWMValue = 4095;
               delay(1);
            break;
         default:
            break;
         chooseLightning = true; // Reset the flag to choose a new lightning type
      if (NumMins(hour(), minute())>(cloudstart + cloudduration))
         cloudindex++;
         if (cloudindex < numclouds)
            cloudstart = random(Start_Cloud_After + (((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2))*cloudindex * 2), (Start_Cloud_After + (((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2))*cloudindex * 2)) + ((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2)));
   if (LastNumMins != NumMins(hour(), minute()))
      LastNumMins = NumMins(hour(), minute());
      if (cloudchance && (NumMins(hour(), minute())<cloudstart))
         int x = 0;
         if ((cloudstart / 60) >= 10) x = 11;
         else x = 17;
         //ReefAngel.CustomVar[3] = cloudstart / 60; // Write the hour of the next cloud to custom variable for Portal reporting
         if ((cloudstart % 60) >= 10) x = 29;
         else x = 35;
         //ReefAngel.CustomVar[4] = cloudstart % 60; // Write the minute of the next cloud to custom variable for Portal reporting
      //ReefAngel.CustomVar[7] = (cloudduration);    // Put the duration of the next cloud in a custom var for the portal
      if (lightningchance)
         int x = 0;
         if (((cloudstart + (cloudduration / 2)) / 60) >= 10) x = 51;
         else x = 57;
         //ReefAngel.CustomVar[5] = (cloudstart + (cloudduration / 2)) / 60;    // Write the hour of the next lightning to a custom variable for the Portal
         if (((cloudstart + (cloudduration / 2)) % 60) >= 10) x = 69;
         else x = 75;
         //ReefAngel.CustomVar[6] = (cloudstart + (cloudduration / 2)) % 60;
void Strike()
   int a = random(1, 5);    // Pick a number of consecutive flashes from 1 to 4.
   for (int i = 0; i<a; i++)
      // Flash on
      int newdata = 4095;
      Wire.beginTransmission(0x40);      // Address of the dimming expansion module
      Wire.write(0x8 + (4 * 1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
      Wire.write(newdata & 0xff);          // Send the data 8 bits at a time.  This sends the LSB
      Wire.write(newdata >> 8);            // This sends the MSB
      Wire.endTransmission();
      int randy = random(20, 80);    // Random number for a delay
      if (randy>71) randy = ((randy - 70) / 2) * 100;    // Small chance of a longer delay
      delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
                            // Flash off.  Return to baseline.
      newdata = ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
      Wire.beginTransmission(0x40);    // Same as above
      delay(random(30, 50));                // Wait from 30 to 49 ms
      wdt_reset();    // Reset watchdog timer to avoid re-boots
byte ReversePWMSlope(long cstart, long cend, byte PWMStart, byte PWMEnd, byte clength)
   long n = elapsedSecsToday(now());
   cstart *= 60;
   cend *= 60;
   if (n >= cstart && n <= (cstart + clength)) return map(n, cstart, cstart + clength, PWMStart, PWMEnd);
   if (n>(cstart + clength) && n<(cend - clength)) return PWMEnd;
   if (n >= (cend - clength) && n <= cend) return map(n, cend - clength, cend, PWMEnd, PWMStart);
   if (n>cend) return (int)PWMStart;
>>--Cali-->
PostPosted: Sun Apr 17, 2016 9:22 pm
Ok first off you copied the same mistake someone else made. If you set wavelength to 12 + SECS_PER_HOUR then it will be 72 minutes per high tide to low tide. Should be 12 * ... Unless you're troubleshooting maybe.
Also you only set tideSpeed once when you declare it so it isn't updating. Try setting it inside loop instead. Also you have w_sethour and label_rise_hr which are the same value. You could just consolidate them and reduce the number of variables you need.
PostPosted: Tue Apr 19, 2016 9:07 am
Lee - thanks for your input. I got it working.
What are you doing to generate the vtDuration number? I wanted to see what I could tie this to in order for it to vary throughout the Tide cycle.
>>--Cali-->
PostPosted: Tue Apr 19, 2016 10:08 am
I really only change that depending on the mode. If you look at my function RFCustom you'll see where I set it.
Previous
