Libraries TODO List
Re: Libraries TODO List
I think DelayedOn() function should be a function of Relay class, instead of general function.
What do you think?
What do you think?
I think you are right. For some reason I'm thinking there was a reason why I didn't put it in the Relay class to begin with but I can't recall the reason(s) right now.rimai wrote:I think DelayedOn() function should be a function of Relay class, instead of general function.
What do you think?
I'll investigate moving it to the Relay class.
Figured things out and moved it over. In the next release, instead of saying this:
you will say this:
It makes more sense having it like that because we are operating on the Relay's. It was coded the "wrong" way initially due to some errors with variable sharing but those were resolved and everything is working as expected now.
ReefAngel.DelayedOn(Port1, 5);
ReefAngel.Relay.DelayedOn(Port1, 5);
Hi Curt/Dave,
Would you be able to confirm this bug?
Seems to only happen with r121 though.
Send:
Result:
Followed by:
Result:
Send:
GET /r121
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Type: text/xml
Content-Length: 495
<RA><T1>737</T1><T2>0</T2><T3>0</T3><PH>676</PH><R>248</R><RON>0</RON><ROFF>255</ROFF><R0>0</R0><RON0>2</RON0><ROFF0>255</ROFF0><R1>0</R1><RON1>0</RON1><ROFF1>255</ROFF1><R2>0</R2><RON2>0</RON2><ROFF2>255</ROFF2><R3>0</R3><RON3>0</RON3><ROFF3>255</ROFF3><R4>0</R4><RON4>0</RON4><ROFF4>255</ROFF4><R5>0</R5><RON5>0</RON5><ROFF5>255</ROFF5><R6>0</R6><RON6>0</RON6><ROFF6>255</ROFF6><R7>0</R7><RON7>0</RON7><ROFF7>255</ROFF7><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH></RA>
GET /r99
HTTP/1.1 401 Access Denied
WWW-Authenticate: Basic realm=Reef Angel Controller
Content-Length: 0
what version of the libraries are you using or did you notice this with?
I'm still on .15
If I follow your steps and include the trailing space after GET /r121 and GET /r99 everything works fine.. If I don't include the trailing space in the above statements I see:
Never was able to get exactly your output, though
HTTP/1.1 200 OK
Server: ReefAng
el
Pragma: no-cache
Connection: close
Content-Type: text/html
Content-Length: 24
<h1>Unknown Request</h1>
Just confirmed I see the same results I mentioned above on .16 as I did .15
I guess I'll just download the libs again. I may have changed something that screwed it up.
Yeah, I had to do the trailing space to get the correct stuff, but that was not the problem. It was expected to be that way.
I'm testing the masks of the expansion module relays of the Dev libs and the profile of relays of your Client to trigger events on the RA
Basically using the expansion relays as virtual on/off switches that can be turned on/off through the Client
Hey Curt,
What happens if I send you another pull request, with the current one I requested a couple days ago still open. Can you merge both of them??
I'd like to smooth down the pH readings by averaging 20 readings. Credits to Paul Viscowich for the idea, which should've been done since the beginning.... lol
i just merged the open request. for your reference, i can add your repository to my remotes for my local copy and i can manually pull any changes you have posted to your github account.
my master branch is updated to the latest with your changes in it. i have not updated the version of the libraries yet though (and don't plan on it just yet until i'm ready for .19 which will be after the pwm expansion settings via wifi and your ph updates).
