New IDE v1.6.8
PostPosted: Tue Feb 06, 2018 12:35 pm
rimai wrote:There might be a change on the Arduino IDE that requires the wizard and preloaded code to be recompiled too.
I have only tested on v1.6.8.
ok. that makes sense. i do think some things changed.
PostPosted: Sat Feb 10, 2018 5:42 pm
Well, there's more that has changed with 1.8.5 (the version that I'm using for a High Sierra build).
It's proving to be a cumbersome (and frustrating) task.
PostPosted: Mon Apr 16, 2018 1:14 pm
Any additional work done on this? I hit a roadblock and haven't gotten past it.
PostPosted: Tue Apr 17, 2018 4:08 pm
Didn't got around doing that yet. :(
PostPosted: Tue Apr 17, 2018 6:11 pm
rimai wrote:Didn't got around doing that yet. :(
no problem. I know you are busy. I just wanted to check up on it.
PostPosted: Sat Apr 21, 2018 11:54 am
Can you explain a little more of what the problem you are having?
PostPosted: Sat Apr 21, 2018 2:11 pm
rimai wrote:Can you explain a little more of what the problem you are having?
There were some issues with including the correct libraries and dealing with the additional tools. I think there was also an issue with compilations with the latest libraries. I don't recall about the exact compilation problem because i was more focused on the main errors.
here's the additional errors that I had saved. I'll have to double check because I haven't looked at it for a while.
Verify the Libraries check function call.
java.lang.NoSuchMethodError: processing.app.Base.getSketchbookFolder()Ljava/io/File;
Invalid libraries:
Invalid library found in /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/WiFi: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/WiFi
Invalid library found in /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Ethernet: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Ethernet
Launching "Restore pre-loaded code":
java.lang.NoSuchMethodError: processing.app.Sketch.getCode(I)Lprocessing/app/SketchCode;
at com.reefangel.tool.RestorePreloaded.run(Unknown Source)
i know that they changed things but I just haven't had the mindset to dive in to how it works...like you already had.
PostPosted: Sat Apr 21, 2018 4:13 pm
when running the wizard, this is the output:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Sketch.getCode(I)Lprocessing/app/SketchCode;
   at com.reefangel.tool.Wizard.run(Unknown Source)
   at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
   at java.awt.EventQueue.access$500(EventQueue.java:97)
   at java.awt.EventQueue$3.run(EventQueue.java:709)
   at java.awt.EventQueue$3.run(EventQueue.java:703)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Running the restore preloaded code gives this:
Then compiling against the current dev libraries yields this:
Archiving built core (caching) in: /var/folders/3h/m3xyqrbj57vf3kmyrzy3zn900000gp/T/arduino_cache_671070/core/core_arduino_avr_RAStar_c41a4462a748f55bf51d70a30288e42f.a
Multiple libraries were found for "Ethernet.h"
 Used: /Users/binder/ownCloud/Documents/Arduino/libraries/Ethernet
 Not used: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/libraries/Ethernet
libraries/ReefAngel/ReefAngel.cpp.o (symbol from plugin): In function `ReefAngelClass::DisplayMenuHeading()':
(.text+0x0): multiple definition of `__vector_9'
libraries/SoftwareSerial/SoftwareSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
/Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Reef Angel Star Controller.
i know some of these errors are probably simple ones but i'm not that familiar with the ide changes you have made before to get things to compile.
i am definitely willing to work at this more but i need guidance and assistance. :?
PostPosted: Sat Apr 21, 2018 4:35 pm
I don't think you need to run the Restore Preloaded code, right? :)
I never had problem compiling code though.
I'll double check.
PostPosted: Sat Apr 21, 2018 6:08 pm
rimai wrote:I don't think you need to run the Restore Preloaded code, right? :)
you never know. ;-)
I'll double check.
I think the issue lies with extra libraries that are included by default but we don't typically need them. I think I vaguely recall from years past that we had to remove a specific library due to it including something we didn't need...or multiple definitions...or something like that. I'm not positive though.
