Power Control Expansion & How to use
PostPosted: Fri Jan 06, 2017 7:09 pm
I had a request to add the Power Control Expansion module to my Android App. I wanted to investigate on what needs to be done so it could be implemented.
Doing a search on the forum lead me to discover that the Power Control Expansion module works exactly like a relay expansion and you can just toggle the ports ON/OFF like a standard relay port.
So, I interpret that as you simply designate that the Power Control Expansion is Relay Box 1 (if you only have a single relay box). Then you code the controller to control each each port on the Power Control Expansion just like a standard relay port.
My question is simply this: Is what I discovered correct?
I'm assuming so, but I wanted to be certain.
PostPosted: Fri Jan 06, 2017 8:03 pm
Correct.
There is no need for any addition.
It works just like a expansion relay box.
PostPosted: Sat Jan 07, 2017 8:26 am
Great. Thanks for the confirmation.
