Sun.Init & Lighting duration on & off
PostPosted: Sat May 13, 2017 8:16 am
Hi everyone. Doing a little bit of house cleaning on my code and wanted to get more dynamic flow and lighting set up correctly and had a quick question if possible. I believe I am not using the sun routines properly. I've included my code but I believe while I am calling the routines I'm overwriting them in the end.
I am calling Tide and SunLocation and setting some basic vars.
I don't recall why I have byte PWMChannel 6 set, but probably to tell something I am using the expansion. I am with pumps being run on the daylight/actinic channels.
I set ports - hopefully correctly. Then move to tide init and sun init (long/lat for my area).
Question 1: In the void loop I am setting the LED power to start and stop at a set time using StandarLights (set by wizard). This is the first area I was wondering about. If I use Sun/Moon is this necessary?
Question 2: After that I am using PWMChannel 0 - 4 (only using 4 of the 6 expansion) to set when it turns on, ends, and percentages. Again, I think this is overwriting sun routines or guessing anyway.
I now do a bunch of tide stuff (which I also think is wrong) and set sun parameters. Check clouds, check sun, set daylight/actinic channels sync (which I think is in the wrong area), then Set Chanel PWM stuff and go into if else for random waves (which I need to fix).
Comment: While I see I'm setting sun and checking updates I don't think it is being used. Am I missing a function or calling/setting it wrong? I believe I am. Thanks for any guidance.
#include <Moon.h>
#include <Tide.h>  // testing for tide control
#include <SunLocation.h>
Tide tide;  // testing for tide control
SunLocation sun;
byte  PWMChannel[6];
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.Use2014Screen();
    ReefAngel.AddPHExpansion(); // pH Expansion Module
 ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
 ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
 ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
 InternalMemory.OverheatTemp_write( 819 );
 ReefAngel.Relay.On( Port1 );  // skimmer
 // ReefAngel.Relay.On( Port4 );  // LED Fans
 ReefAngel.Relay.On( Port5 );  // RW 4 left side facing tank
 ReefAngel.Relay.On( Port6 );  // RW 4 right side facing tank
    tide.Init(40, 5, 10);
    tide.SetWaveLength(12*SECS_PER_HOUR);
    sun.Init(38.5791, 121.1939); // Rancho Cordova, Ca
    ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
    ReefAngel.StandardLights( Port3,8,0,22,0 ); // LED bar
    ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
    ReefAngel.StandardHeater( Port7,750,800 );
    ReefAngel.StandardHeater( Port8,750,800 );
    // Channel 0 (1000mA max) - 5 Neutral White
    PWMChannel[0]=PWMParabola(9,0,21,0,0,80,0);
    // Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
    PWMChannel[1]=PWMParabola(9,0,21,0,0,85,0);
    // Channel 2 (700mA max) - 12 Lime
    PWMChannel[2]=PWMParabola(9,0,21,0,0,55,0);
    // Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
    PWMChannel[3]=PWMParabola(9,0,21,0,0,70,0);
   tide.isIncoming();
   byte tideSpeed = tide.CalcTide();
   byte w_risehour = sun.GetRiseHour();
   byte b_risehour = sun.GetRiseHour(); //Starting Blues an hour before
   byte riseminute = sun.GetRiseMinute();
   byte w_sethour = sun.GetSetHour();
   byte b_sethour = (sun.GetSetHour()) + 1;
   byte setminute = sun.GetSetMinute();
   char label_rise_hr = sun.GetRiseHour();
   char label_rise_min = sun.GetRiseMinute();
   char label_set_hr = sun.GetSetHour();
   char label_set_min = sun.GetSetMinute();
   byte vtDuration = InternalMemory.RFDuration_read();
    CheckCloud();
    sun.CheckAndUpdate();
    ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
    ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
    ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
    ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
    ReefAngel.DCPump.Threshold = 40;
 if (hour() >= 0 && hour() < w_risehour) {
      ReefAngel.DCPump.SetMode(Lagoon, tideSpeed, vtDuration);
   else if (hour() >= w_sethour && hour() <= 24) {
   else if (hour() >= w_risehour && hour() <= w_sethour)
 ReefAngel.Portal( "saf1" );
 ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 45
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 4
#define End_Cloud_Before NumMins(21,30)
#define Lightning_Change_per_Cloud 65
 // Channels used by the actinic LEDs on the PWM Expansion module
 // These channels will not be dimmed when the cloud effect is triggered
 // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
//#define Actinic_Channels B000001  // Original sample code values
 // Channels used by the daylight LEDs on the PWM Expansion module
 // These channels will be used for the spike when lightning effect is triggered
 // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
//#define Daylight_Channels B000010  // Original sample code values
 static byte cloudchance=255;
 static byte cloudduration=0;
 static int cloudstart=0;
 static byte numclouds=0;
 static byte cloudindex=0;
 static int LastNumMins=0;
#ifdef forcecloudcalculation
 if (cloudchance==255)
#else
#endif
 cloudchance=random(100);
 // If we have cloud today
 if (cloudchance)
 lightningchance=random(100);
 if (cloudchance)
 //is it time for cloud yet?
 // let's go through all channels to pick which ones will be dimmed
 for (int a=0;a<6;a++)
 if (bitRead(Actinic_Channels,a)==0)
 // this will slope down the channel from the current PWM to 0 within 3minutes.
 // then it will stay at 0 for the duration of the cycle
 // and finally slope up from 0 to PWM value within 3 minutes
 // it is basically an inversed slope
 PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
 for (int b=0;b<6;b++)
 if (bitRead(Daylight_Channels,b)==1)
 else lightningstatus=0;
 if (lightningstatus) PWMChannel[b]=100;
 else PWMChannel[b]=0;
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 if (cloudindex < numclouds)
 int x=0;
 if (lightningchance)
 int x=0;
 cstart*=60;
 cend*=60;
 if (n>cend) return PWMStart;
