Errors when compiling with dev branch
PostPosted: Mon Nov 26, 2018 7:31 pm
Plus
PostPosted: Mon Nov 26, 2018 10:05 pm
Can you post your code?
PostPosted: Sat Dec 01, 2018 10:12 pm
Just playing around right now, so there's not much to it. Basically, all it's doing is setting the 0-10v ports to 100%.
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.PWM.SetDaylight(100);
    ReefAngel.PWM.SetActinic(100);
    ReefAngel.Portal("sbidny");
    ReefAngel.CloudPortal();
    ReefAngel.DDNS("reef"); // Your DDNS is sbidny-reef.myreefangel.com
PostPosted: Mon Dec 03, 2018 9:38 am
FYI, when I upload the same (minus the ReefAngel.CloudPortal() call) via Arduino 1.0.1, I don't see the same issue with trailing characters.
I'll try uploading using 1.8.6 without the CloudPortal() call.
PostPosted: Mon Dec 03, 2018 6:46 pm
Same issue.
PostPosted: Mon Dec 03, 2018 7:00 pm
I wonder if this is a MacOSX issue only.
I'm not able to replicate.
lnevo, can you report if you have this issue?
PostPosted: Mon Dec 03, 2018 7:20 pm
I’ll try to get it going from Windows and see if the problem persists.
Previous
