Re: PWM Slope
Posted: Mon Dec 31, 2012 9:26 am
Re: PWM Slope
Posted: Mon Dec 31, 2012 10:21 am
Cool. Good to know. On my other question... will an inverse slope work ? Where we dim to dark and dim back up?
Re: PWM Slope
Posted: Mon Dec 31, 2012 10:23 am
I think so....
Never tried.
Re: PWM Slope
Posted: Mon Dec 31, 2012 10:33 am
Guess I will give it a try and report back..
PWM Slope
Posted: Tue Jan 01, 2013 3:00 pm
It did not seem to work. The portal shows no change between my darkness hours...no slope seen
Re: PWM Slope
Posted: Tue Jan 01, 2013 4:48 pm
Did you use the overnight version?
PWM Slope
Posted: Tue Jan 01, 2013 4:54 pm
Didnt need the overnight..i'll paste my code later tonight. The overnight was to support people doing a ramp up separate from ramp down.
Re: PWM Slope
Posted: Tue Jan 01, 2013 6:36 pm
Here's the block of code I tested last night. From the portal data, it seems to have dropped to 0 from 2am-5am.
if ((hour()>=2) && (hour()<5)) { // 2:00am-4:59am
// Some complete darkness. Ramp down to 0 and back up to MoonPhase().
ReefAngel.PWM.SetDaylight(PWMSlope(2,0,5,0,MoonPhase(),0,30,0));
ReefAngel.PWM.SetActinic(PWMSlope(2,0,5,0,MoonPhase(),0,30,0));
} else {
// Set moonlights to the MoonPhase
Re: PWM Slope
Posted: Tue Jan 01, 2013 9:22 pm
Oh no...
You need to do the opposite...
You need to overnight function and ramp up at 5am and down at 2am
PWM Slope
Posted: Tue Jan 01, 2013 9:26 pm
Ahhh got it. Will try tomorrow.
PWM Slope
Posted: Wed Jan 02, 2013 4:21 pm
I noticed the overnight function is not in the libraries?
Also, i noticed a function ReversePWM that was used in the cloud program...would that be more direct to use for what I am trying to do?
Re: PWM Slope
Posted: Wed Jan 02, 2013 4:29 pm
Correct, the overnight never made to the libraries.
The reverse version is on seconds and not minutes, but it will also not cross over to next day.
PWM Slope
Posted: Fri Jan 04, 2013 5:46 am
Worked perfectly last night! Thanks Roberto!
Re: PWM Slope
Posted: Fri Jan 04, 2013 8:58 am
Awesome!!!
