No. I was just using that as an example for repeat. The maximum number for repeat is 32767 minutes. That is well above 4 hours. It will work if you exceed 24 hours (1440 minutes).lukeluke wrote:the max repeat time is 4 hour ?
v0.9.0 Libraries
Re: v0.9.0 Libraries
Yeah, that's the "preferred" way with 0.9.X libraries. The reason is that it's more "human readable" and easier to understand. You could put it in terms of the 0's & 1's but that's just a little harder to read.projectx wrote:This compiles without any errors, is this the proper way?
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
What is this syntax? E[0]projectx wrote: ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
Haven't seen that before. Thx
E[0] is for expansion relay box.
You can have E[0] through E[7] to set the ports of all other expansion boxes.
Great Thanks just did a few comparisons from the old to the new, just have to learn the code, I have found that Notepad++ is great for making it readable vs notepad
I love Notepad++ on windows. It works so much better than notepad.projectx wrote:Great Thanks just did a few comparisons from the old to the new, just have to learn the code, I have found that Notepad++ is great for making it readable vs notepad
So I have something thats amiss with my expansion relay. from the portal I am able to turn on n off my pumps, but with the new code they are not being turned on.
here is my INO file
// Autogenerated file by RAGen (v1.2.1.158), (02/20/2012 22:17)
// RA_022012_2217.ino
#define DirectTempSensor
#define wifi
#define RelayExp
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Box0_Port1 | Box0_Port2;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Box0_Port3);
ReefAngel.Relay.On(Box0_Port4);
ReefAngel.Relay.On(Box0_Port7);
ReefAngel.Relay.On(Box0_Port8);
// Specific functions
ReefAngel.SingleATOLow(Port1);
ReefAngel.StandardLights(Box0_Port1, 21, 0, 7, 0);
ReefAngel.StandardLights(Box0_Port2, 7, 0, 20, 0);
ReefAngel.MHLights(Box0_Port5);
ReefAngel.MHLights(Box0_Port6);
ReefAngel.MHLights(Port4);
ReefAngel.DosingPump1(Port7);
ReefAngel.DosingPump2(Port8);
here is my INO file
#define wifi
#define RelayExp
#define SIMPLE_MENU
I have real problems now, my ATO is staying on all of the time, I stripped out all of the expansion box items as it started to happen when my moon lights (box0_port1) were scheduled to come on.
I repushed the code and it is still on, thankfully i was sitting there when it did it so i was able to pull the plug on the pump before I had a mess to clean up.
Any ideas?
Any ideas?
The ATO is because your code is should use Box1_ instead of Box0_
Box0_ refers to the main relay box.
The Dosing pump is because there was a bug that was fixed today.
Please download the latest libraries using the update utility.
http://www.reefangel.com/update
It was a premature move to update the dosing pump code and I had to return back to the original code.
Ok I am getting the update now, odd, i stripped all of the code for the expansion out and it was still doing it.
Thanks, that took care of it, and it also solved a few other things that i was fighting
on your last library, 0.9.6 , you add the function:
SingleATOHighExtended(byte Relay);
i add it on my .ino and i compile it right.
I must modify the ATOHighTimeout .... how can i do ?
Can i use your java ReefAngel Status changing the variable from byte to int ? for example i want 10 minutes. Can i set on the location 842 the value INT 600 ?
Bye
Bye
First, I haven't made a post about the new functions and how to use them, so that's my fault.lukeluke wrote:on your last library, 0.9.6 , you add the function:
Second, here's your answer. You can use those functions instead of the regular ones. The extended functions use different memory locations that the standard ones. The reason is the extended ato functions use INT variables and not BYTE variables. Here's the memory locations for the new functions:
Mem_I_ATOExtendedTimeout 876
Mem_I_ATOHighExtendedTimeout 878
ok Curt.
thanks a lot .
you are the best
thanks a lot .
you are the best
I thought I read/heard somewhere alone the way that there was an update coming to the libraries soon. Is that the case? I'm getting reading to setup the RA+, add a dosing pump, and make a few other changes, but figured I'd hold off if a library update was coming soon. Thanks!
Libraries updates will always be released. We are constantly evolving the code and it is thanks to you all that make this project move forward. Some bugs can only be found in a real environment.
There is also always request for new functions and such, so don't hold off on an update or you will be holding off for a very long time as there will always be another one coming up
Yeah, like Roberto said, there's always updates coming out. So don't hold off "playing" just because you are waiting for another update.
Thanks guys. I worked up some new code and took a stab at installing the RA+ board this morning. Had some oddball stuff going on. My moonlights started to turn on and off and my leds didn't seem to be reading the internal memory settings. I ended up putting the old board back in until I have time to trouble shoot it. I'll be back with questions.
Does E[0] automatically refer to the first relay expansion box or does it need reference the ID that is set up using the expansion module dip switches?rimai wrote:E[0] is for expansion relay box.
I had the same issue I am guessing your moonlights are in port 5 or 6. I am going to take another stab at it this weekend. Need to get the memory updated first then push the code to it I'll let you know what happensMike S wrote:Thanks guys. I worked up some new code and took a stab at installing the RA+ board this morning. Had some oddball stuff going on. My moonlights started to turn on and off and my leds didn't seem to be reading the internal memory settings. I ended up putting the old board back in until I have time to trouble shoot it. I'll be back with questions.
Sent from my Galaxy Nexus using Tapatalk 2
My moonlight are on 5 and 6 but I had uploaded it with the wrong board setting. When I uploaded it again last night with the RA+ setting they worked fine. My leds, heater and ato were not so lucky. I think my LED issue may have been due to a mh delay setting. Need to double check that.... One step at a time.
