My banner does not work
paulo.hanashiro
Post by paulo.hanashiro »
All.
I just compiled a new pde file in order to use my wifi adapter, but I can't make it work.
How I did the banner setup in my pde file:
prog_char id_label[] PROGMEM = "phanashiro";
prog_char probe1_label[] PROGMEM = "Display";
prog_char probe2_label[] PROGMEM = "Room";
prog_char probe3_label[] PROGMEM = "Light";
prog_char relay1_label[] PROGMEM = "Light";
prog_char relay2_label[] PROGMEM = "Moon%Light";
prog_char relay3_label[] PROGMEM = "Heater";
prog_char relay4_label[] PROGMEM = "Chiller";
prog_char relay5_label[] PROGMEM = "ATO";
prog_char relay6_label[] PROGMEM = "Dosing%Balling%1";
prog_char relay7_label[] PROGMEM = "Dosing%Balling%2";
prog_char relay8_label[] PROGMEM = "Dosing%Balling%3";
When I try to use it with this link: http://www.reefangel.com/status/image_s ... phanashiro
Only a "blank" screen appears.
Am I doing anything wrong?
Regards.
Paulo
Re: My banner does not work
paulo.hanashiro wrote: Only a "blank" screen appears.
I'm going to assume that labels 2,6,7,8 all are supposed to have spaces in their names. Since you only have a % there, it's being interpreted as %L, %B, %1, etc.
It should be %20 where you need spaces to be otherwise you get some unknown responses.
Try this out:
prog_char relay2_label[] PROGMEM = "Moon%20Light";
prog_char relay6_label[] PROGMEM = "Dosing%20Balling%201";
prog_char relay7_label[] PROGMEM = "Dosing%20Balling%202";
prog_char relay8_label[] PROGMEM = "Dosing%20Balling%203";
That should fix things up for you.
paulo.hanashiro
Hi Curt.
Thanks for your help.
I did the changes, but the error persists.
My full code:
// Autogenerated file by RAGen (v1.0.4.93), (05/29/2011 16:52)
// RA_052911_1652.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DirectTempSensor
#define wifi
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    // Initialize and start the web banner timer
    ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
    ReefAngel.Timer[4].Start();
    ReefAngel.FeedingModePorts = B00000000;
    ReefAngel.WaterChangePorts = B00000000;
    ReefAngel.OverheatShutoffPorts = B00000001;
    ReefAngel.LightsOnPorts = B00000001;
//    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardLights(Port1, 12, 00, 24, 00);
    ReefAngel.StandardLights(Port2, 24, 00, 8, 00);
    ReefAngel.StandardHeater(Port3, 23, 26);
    ReefAngel.StandardFan(Port4, 27, 29);
    ReefAngel.StandardATO(Port5, 2400); //Quantidade de segundos para reposição, se desligar pelo timer, led vermelho do RA acende e bloqueia a reposição
    ReefAngel.DosingPump(Port6, 1, 9, 0, 50); //(byte DPRelay, byte DPTimer, byte OnHour, byte OnMinute, byte RunTime)
    ReefAngel.DosingPump(Port7, 1, 12, 0, 50);
    ReefAngel.DosingPump(Port8, 1, 15, 0, 50);
    // Web Banner stuff
        ReefAngel.WebBanner();
How long does it take to have the banner available?
Could it be anything related to refresh?
Thanks again.
Paulo
paulo.hanashiro wrote: How long does it take to have the banner available?
Do you have your wifi module configured to send the data to reefangel.com? If not, the data will not get sent.
Read up on this page: http://www.reefangel.com/Enable-a-Web-B ... controller
Here is the screenshot of the window that contains the settings. These instructions should also be in the manual as well.
Web Banner wifi settings
If you do this, then you should be working.
paulo.hanashiro
Hi Curt.
Did everything you wrote, and got nothing.
Did a factory reset and the wifi setup process again, now it's working.
Thanks!!!
Cool. Glad you got it working. :)
paulo.hanashiro
Thank you for your support!!!
Regards.
Paulo
paulo.hanashiro wrote:Thank you for your support!!!
Regards.
Paulo
You are welcome. That's what I'm here for. :geek:
