VortechMenu
VortechMenu
Cool,
Any other way to change modes? Considering my vortech will now become the slave
Re: VortechMenu
You can manually change the modes via the web interface. This is the same way that the iPhone and Android apps work.Poiromaniax wrote:Cool,
// RF Mode
http://YOURIPADDRESS:2000/mb855,X
// RF Speed
http://YOURIPADDRESS:2000/mb856,X
// RF Duration
http://YOURIPADDRESS:2000/mb857,X
Or you can use the java status app to change the memory locations:
http://forum.reefangel.com/viewtopic.php?f=8&t=246
- JNieuwenhuizen
Re: VortechMenu
So I have tested the code with the changes suggested, It still only changes the mode for a second and then returns to normal operation.
Any chance we could re-visit this to see if we can get it going?
Re: VortechMenu
Try this:
// this goes above the menu entries
byte vtmode = 0;
void MenuEntry7()
vtmode++;
if ( vtmode == 7 ) vtmode = 9;
if ( vtmode > 9 ) vtmode = 1;
InternalMemory.RFMode_write(vtmode);
- JNieuwenhuizen
Re: VortechMenu
Hi
I tried the code you suggested, now it does not switch modes at all.
Re: VortechMenu
Try this:
void MenuEntry7()
// TODO complete this function
Need to have an override variable inside the loop that forces a specific mode whenever
the menu is toggled. This should mimic the PWM override.
Cycle through the modes.
Use the Internal Memory values OR create a switch statement that has default values
for Speed and Duration based on the modes being switched to.
Once at the end of the modes,
return to constant mode (begining)
resume normal operations
if (!fOverrideRF && vtechmode == 9)
vtechmode=0;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
vtechmode++;
fOverrideRF = true;
if ( vtechmode == 7 ) vtechmode = 9;
if ( vtechmode > 9 ) {
vtechmode = 0;
fOverrideRF = false;
// 1st parameter is Mode, 2nd is speed, 3rd is duration
Re: VortechMenu
While trying out your code, I noticed a bug in your DrawTime() function that was causing the wdt to kick in.
Change this:
To this:
Change this:
char temp[]=" ";
char temp[]=" ";
Re: VortechMenu
Curious, are all of the URL options for the RA documented somewhere?binder wrote:You can manually change the modes via the web interface. This is the same way that the iPhone and Android apps work.Poiromaniax wrote:Cool,
You simply use your IP address and port. Then, you would use the value you want in place of X. This is just like what was mentioned earlier.Code: Select all
// RF Mode http://YOURIPADDRESS:2000/mb855,X // RF Speed http://YOURIPADDRESS:2000/mb856,X // RF Duration http://YOURIPADDRESS:2000/mb857,X
I know about /r1, /r99, /wifi, and now these few. Is there an authoratative source I can use to tell me all the different options without diving into a bunch of code? Alternately.. if I do need to dig through code, where would I start my search?
Re: VortechMenu
It's on RA_Wifi.cpp
This is the extraction from the file:
There isn't any documentation on the codes yet.
if (strncmp("GET / ", m_pushback, 6)==0) reqtype = REQ_ROOT;
else if (strncmp("GET /wifi", m_pushback, 9)==0) reqtype = REQ_WIFI;
else if (strncmp("GET /r", m_pushback, 6)==0) reqtype = -REQ_RELAY;
else if (strncmp("GET /mb", m_pushback, 7)==0) { reqtype = -REQ_M_BYTE; weboption2 = -1; bHasSecondValue = false; bCommaCount = 0; }
else if (strncmp("GET /mi", m_pushback, 7)==0) { reqtype = -REQ_M_INT; weboption2 = -1; bHasSecondValue = false; bCommaCount = 0; }
else if (strncmp("GET /ma", m_pushback, 7)==0) reqtype = -REQ_M_ALL;
else if (strncmp("GET /mr", m_pushback, 7)==0) reqtype = -REQ_M_RAW;
else if (strncmp("GET /v", m_pushback, 6)==0) reqtype = -REQ_VERSION;
else if (strncmp("GET /d", m_pushback, 6)==0) { reqtype = -REQ_DATE; weboption2 = -1; weboption3 = -1; bCommaCount = 0; }
else if (strncmp("HTTP/1.", m_pushback, 7)==0) reqtype = -REQ_HTTP;
else if (strncmp("GET /sr", m_pushback, 7)==0) reqtype = -REQ_R_STATUS;
else if (strncmp("GET /sa", m_pushback, 7)==0) reqtype = -REQ_RA_STATUS;
else if (strncmp("GET /bp", m_pushback, 7)==0) reqtype = -REQ_BTN_PRESS;
else if (strncmp("GET /mf", m_pushback, 7)==0) reqtype = -REQ_FEEDING;
else if (strncmp("GET /mw", m_pushback, 7)==0) reqtype = -REQ_WATER;
// else if (strncmp("GET /cr", m_pushback, 7)==0) reqtype = -REQ_CAL_RELOAD;
else if (strncmp("GET /mt", m_pushback, 7)==0) reqtype = -REQ_ALARM_ATO;
else if (strncmp("GET /mo", m_pushback, 7)==0) reqtype = -REQ_ALARM_OVERHEAT;
//else reqtype = -REQ_UNKNOWN;
- JNieuwenhuizen
Re: VortechMenu
I get an error now - "Else without a previous If"rimai wrote:Try this:Code: Select all
void MenuEntry7() { // TODO complete this function /* Need to have an override variable inside the loop that forces a specific mode whenever the menu is toggled. This should mimic the PWM override. */ /* Cycle through the modes. Use the Internal Memory values OR create a switch statement that has default values for Speed and Duration based on the modes being switched to. Once at the end of the modes, return to constant mode (begining) resume normal operations */ if (!fOverrideRF && vtechmode == 9) vtechmode=0; ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode else vtechmode++; fOverrideRF = true; if ( vtechmode == 7 ) vtechmode = 9; if ( vtechmode > 9 ) { vtechmode = 0; fOverrideRF = false; } // 1st parameter is Mode, 2nd is speed, 3rd is duration ReefAngel.DisplayedMenu = RETURN_MAIN_MODE; }
Re: VortechMenu
Sorry.
void MenuEntry7()
vtechmode=0;
vtechmode++;
fOverrideRF = true;
vtechmode = 0;
- JNieuwenhuizen
Re: VortechMenu
So I have tried this one
Still doesnt change the modes.
Any other Ideas?
The closest one was Binders suggestion, as it changed for a split second.
Any other Ideas?
Re: VortechMenu
Does it change on screen and not on the module, or it doesn't even change on screen?
- JNieuwenhuizen
Re: VortechMenu
It does not change on screen , or on module.
- JNieuwenhuizen
Re: VortechMenu
HI Roberto
Here is my current config - a few items are // out, as I am waiting for rufessor to complete the comms between the PWM module, and the RA
#include <avr/pgmspace.h>>
//-------------------------------------------------------------------------- Screen set-up ---------------------------------------------------------------------------------
#define NumScreens 6
int ScreenID=0;
//--------------------------------------------------------------------- Start of Global Variables ---------------------------------------------------------------------------
bool fOverrideRF = false;
byte vtechmode = 0;
boolean bFeeding=false;
byte x,y;
byte TempRelay =15;
byte TempRelay2=15;
//----------------------------------------------------------------------- Custom Menu Code ----------------------------------------------------------------------------------
prog_char menu1_label[] PROGMEM = "Food!!";
prog_char menu2_label[] PROGMEM = "Cleanup";
prog_char menu4_label[] PROGMEM = "Storm";
prog_char menu5_label[] PROGMEM = "pH Cal";
prog_char menu6_label[] PROGMEM = "Salinity Cal";
prog_char menu7_label[] PROGMEM = "Vortech Mode";
prog_char menu8_label[] PROGMEM = "Sump On";
prog_char menu9_label[] PROGMEM = "Sump Off";
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Food!!");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Cleanup");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("ATO Clear");
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Storm");
void MenuEntry5()
ReefAngel.DisplayMenuEntry("pH Cal");
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Salinity Cal");
ReefAngel.SetupCalibrateSalinity();
void MenuEntry7()
vtechmode=0;
vtechmode++;
fOverrideRF = true;
vtechmode = 0;
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Sump On");
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Sump Off");
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
//------------------------------------------------------------------------- Grouped Menu Entries ----------------------------------------------------------------------------
PROGMEM const char *menu_items[] =
menu7_label,menu8_label,menu9_label
//------------------------------------------------------------------------------- Custom Main -------------------------------------------------------------------------------
void DrawCircleOutline(byte x, byte y, byte radius, byte bordercolor);
void FillCircle(byte x, byte y, byte radius, byte fillcolor);
void DrawCircleOutletBox(byte x, byte y, byte RelayData, bool reverse = false);
//-------------------------------------------------------------------------- Analog Clock constants -------------------------------------------------------------------------
const float pi = 3.141592653;
byte clock_center_x = 65;
byte clock_center_y = 65;
byte clock_radius = 55;
byte secondhand_radius = 33;
float secondangle;
byte secondend_x;
byte secondend_y;
float minuteangle;
float hourangle;
//--------------------------------------------------------------------------- Analog Clock Structure ------------------------------------------------------------------------
int minutebase_radius = 3;
int minutehand_radius = 33;
int hourbase_radius = 3;
int hourhand_radius = 25;
int seconds_hand_x, seconds_hand_y, minutes_hand_x, minutes_hand_y, hours_hand_x, hours_hand_y;
int hours_hand_base_x, hours_hand_base_y, hours_hand_base_x1, hours_hand_base_y1;
int minutes_hand_base_x, minutes_hand_base_y, minutes_hand_base_x1, minutes_hand_base_y1;
int minutebase_x, minutebase_y, minutebase_x1, minutebase_y1;
int minuteend_x, minuteend_y;
int hourbase_x, hourbase_y, hourbase_x1, hourbase_y1;
int hourend_x, hourend_y;
float minfloat;
//--------------------------------------------------------------------------------Time Stamp --------------------------------------------------------------------------------
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
//------------------------------------------------------------------------------ Draw Minutes Hand --------------------------------------------------------------------------
void draw_minute(int color)
Drawline(minutebase_x, minutebase_y, minutebase_x1, minutebase_y1, color);
Drawline(minutebase_x, minutebase_y, minuteend_x, minuteend_y, color);
Drawline(minutebase_x1, minutebase_y1, minuteend_x, minuteend_y, color);
//--------------------------------------------------------------------------- Draw Hour Hand --------------------------------------------------------------------------------
void draw_hour(int color)
Drawline(hourbase_x, hourbase_y, hourbase_x1, hourbase_y1, color);
Drawline(hourbase_x, hourbase_y, hourend_x, hourend_y, color);
Drawline(hourbase_x1, hourbase_y1, hourend_x, hourend_y, color);
//------------------------------------------------------------------------------ Draw Line ----------------------------------------------------------------------------------
void Drawline (int x0, int y0, int x1, int y1, int color)
int dy = y1 - y0;
int dx = x1 - x0;
int stepx, stepy;
if (dy < 0)
dy = -dy;
stepy = -1;
stepy = 1;
if (dx < 0)
dx = -dx;
stepx = -1;
stepx = 1;
dy <<= 1; // dy is now 2*dy
dx <<= 1; // dx is now 2*dx
ReefAngel.LCD.PutPixel(color, x0, y0);
if (dx > dy)
int fraction = dy - (dx >> 1); // same as 2*dy - dx
while (x0 != x1)
if (fraction >= 0)
y0 += stepy;
fraction -= dx; // same as fraction -= 2*dx
x0 += stepx;
fraction += dy; // same as fraction -= 2*dy
int fraction = dx - (dy >> 1);
while (y0 != y1)
if (fraction >= 0)
x0 += stepx;
fraction -= dy;
y0 += stepy;
fraction += dx;
//------------------------------------------------------------------------------ Draw Time ----------------------------------------------------------------------------------
void DrawTime(byte x, byte y, byte FGcolor, byte BGcolor, time_t ts)
char text[13];
char temp[]=" ";
strcpy(text,"");
itoa(hourFormat12(ts),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,":");
itoa(minute(ts),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(ts),temp,10);
strcat(text,temp);
if (isAM(ts))
strcat(text," AM");
strcat(text," PM");
ReefAngel.LCD.DrawText(FGcolor, BGcolor, x, y, text);
//------------------------------------------------------------------------------ Draw Circle --------------------------------------------------------------------------------
void DrawCircle(int a, int b, int r, byte color)
int f = 1 - r;
int ddF_x = 1;
int ddF_y = -2 * r;
int x = 0;
int y = r;
ReefAngel.LCD.PutPixel(color, a, b+r);
ReefAngel.LCD.PutPixel(color ,a, b-r);
ReefAngel.LCD.PutPixel(color, a+r, b);
ReefAngel.LCD.PutPixel(color, a-r, b);
while (x<y)
if (f >= 0)
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
ReefAngel.LCD.PutPixel(color, a + x, b + y);
ReefAngel.LCD.PutPixel(color, a - x, b + y);
ReefAngel.LCD.PutPixel(color, a + x, b - y);
ReefAngel.LCD.PutPixel(color, a - x, b - y);
ReefAngel.LCD.PutPixel(color, a + y, b + x);
ReefAngel.LCD.PutPixel(color, a - y, b + x);
ReefAngel.LCD.PutPixel(color, a + y, b - x);
ReefAngel.LCD.PutPixel(color, a - y, b - x);
// Refresh is called at start of ShowInterface.
// ShowInterface calls DrawCustomMain
switch (ScreenID)
//---------------------------------------------------------------------------- Screen Code 1--------------------------------------------------------------------------------
case 0:
//Top Banner
ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 1, " Drop Reef Tank ", Font8x8); //Top Banner
// Display T1 Header Text
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,255,5,15,"Sump Temp", Font8x8);
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 10, 25, 50, 60);
if (ReefAngel.Params.Temp[T1_PROBE]>290) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 10, 25, text);
else if (ReefAngel.Params.Temp[T1_PROBE]>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 10, 25, text);
else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 10, 25, text);
// Display the T2 Header Text
ReefAngel.LCD.DrawLargeText(0,255,5,45,"Room Temp", Font8x8);
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 90, 50, 132, 60);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 45, text, Num8x8);
// Display pH Header Text
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,95,15,"pH", Font8x8);
// Display pH Value
ReefAngel.LCD.Clear(0, 65, 62 , 65, 62);
if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 85, 25, text, Num8x8);
else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 85, 25, text, Num8x8);
else ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 85, 25, text, Num8x8);
//------------------------------------------------------------------ Display Vortech Mode ------------------------------------------------------------------------------------
ReefAngel.LCD.DrawLargeText(0,255,5,55,"Vortech", Font8x8);
//---------------------------------------------------------------- Display EcoSmart Mode Value -------------------------------------------------------------------------------
ReefAngel.LCD.Clear(255, 66, 60, 132, 70);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 66, 55,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 66, 55,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 80, 55,"RCM");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 80, 55,"Short");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255, 66, 55,"Long");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"NTM");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"TSM");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_GRAY,255, 80, 55,"Night");
//------------------------------------------------------------------- Display Salinity ---------------------------------------------------------------------------------------
ReefAngel.LCD.DrawLargeText(0,255,64,114,"Salinity", Font8x8);
//----------------------------------------------------------------- Display Salinity Value -----------------------------------------------------------------------------------
ReefAngel.LCD.Clear(255, 82, 85, 65, 95);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 85, 122, text, Num8x8);
//-----------------------------------------------------------Start Moon Phase,Cloud or Storm Display---------------------------------------------------------------------------
/* if (ReefAngel.PWM.Channel[5] > 0);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,105,MoonPhaseLabel());
if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() < 14 ) )
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,255,3,65, "Sunrise",Font8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,3,75, ReefAngel.PWM.ExpansionChannel[0]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,24,75, ReefAngel.PWM.ExpansionChannel[1]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,41,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,75, ReefAngel.PWM.ExpansionChannel[2]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,66,75, "|");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,75, ReefAngel.PWM.ExpansionChannel[3]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,87,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,91,75, ReefAngel.PWM.ExpansionChannel[4]);
else if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() > 14 ))
//---------------------------------------------------------- Display Main and Expansion Relay Box -----------------------------------------------------------------------------
TempRelay = ReefAngel.Relay.RelayData;
ReefAngel.LCD.DrawCircleOutletBox(10,90, TempRelay);
TempRelay2 = ReefAngel.Relay.RelayDataE[0];
TempRelay2 &= ReefAngel.Relay.RelayMaskOffE[0];
TempRelay2 |= ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawCircleOutletBox(40,90, TempRelay2);
break;
//---------------------------------------------------------------------------- Screen Code 2---------------------------------------------------------------------------------
case 1: //PWM Module Info
ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
//ReefAngel.LCD.DrawMonitor(15, 20, ReefAngel.Params,
//ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.Clear(DefaultFGColor,5,52,127,52);
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,30,55,"PWM Expansion");
x=15;
y=68;
for (int a=0;a<6;a++)
if (a>2) x=75;
if (a==3) y=68;
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+12,y,a);
//ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
strcat(text," ");
ReefAngel.LCD.DrawText(COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,text);
y+=10;
break;
//---------------------------------------------------------------------------- Screen Code 3---------------------------------------------------------------------------------
case 2: //relay box key
ReefAngel.LCD.DrawCircleOutletBox(56,46,TempRelay);
ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 1", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,3,44,"LDFan", Font8x8); //1
ReefAngel.LCD.DrawLargeText(0,255,7,54,"N/A", Font8x8); //3
ReefAngel.LCD.DrawLargeText(0,255,7,64,"ATU", Font8x8); //5
ReefAngel.LCD.DrawLargeText(0,255,7,74,"Salty", Font8x8); //7
ReefAngel.LCD.DrawLargeText(0,255,75,44,"Skimer", Font8x8); //2
ReefAngel.LCD.DrawLargeText(0,255,75,54,"Reactr", Font8x8); //4
ReefAngel.LCD.DrawLargeText(0,255,75,64,"Heatr", Font8x8); //6
ReefAngel.LCD.DrawLargeText(0,255,75,74,"Relay", Font8x8); //8
break;
//---------------------------------------------------------------------------- Screen Code 4---------------------------------------------------------------------------------
case 3: //relay box key
ReefAngel.Refresh();
ReefAngel.LCD.DrawCircleOutletBox(56,46,TempRelay2);
ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 2", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,7,44,"VTech", Font8x8);//1
ReefAngel.LCD.DrawLargeText(0,255,3,54,"Return", Font8x8);//3
ReefAngel.LCD.DrawLargeText(0,255,7,64,"N/A", Font8x8);//5
ReefAngel.LCD.DrawLargeText(0,255,7,74,"PWM", Font8x8);//7
ReefAngel.LCD.DrawLargeText(0,255,75,44,"VTech", Font8x8);//2
ReefAngel.LCD.DrawLargeText(0,255,75,54,"SumpL", Font8x8);//4
ReefAngel.LCD.DrawLargeText(0,255,75,64,"Heatr", Font8x8);//6
ReefAngel.LCD.DrawLargeText(0,255,75,74,"LED", Font8x8);//8
break;
//---------------------------------------------------------------------------- Screen Code 5---------------------------------------------------------------------------------
case 4: //setclock
// Analog clock is modified from the original source by Jeff Miller
// Author: Jeff Miller http://arduinofun.blogspot.com/
// Frame
DrawCircle(clock_center_x, clock_center_y, clock_radius, COLOR_CORNFLOWERBLUE);
DrawCircle(clock_center_x, clock_center_y, clock_radius - 1, COLOR_CORNFLOWERBLUE);
DrawCircle(clock_center_x, clock_center_y, clock_radius - 2, COLOR_CORNFLOWERBLUE);
// Face Tick Marks (x = r cos theta, y = r sin theta)
for (byte r=0; r < 12; r++)
float angle = (2 * pi / 12)*r;
int tick_x_out = (clock_radius - 8) * cos (angle) + clock_center_x;
int tick_y_out = (clock_radius - 8) * sin (angle) + clock_center_y;
int tick_x_in = clock_radius *.72 * cos (angle) + clock_center_x;
int tick_y_in = clock_radius * .72 * sin (angle) + clock_center_y;
Drawline(tick_x_in, tick_y_in, tick_x_out, tick_y_out, COLOR_CORNFLOWERBLUE);
// Face Characters
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8,106," 6", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8, 25,"12", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x + 34,clock_center_y," 3", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 50, clock_center_y - 4,"9 ", Font8x8);
// Draw Seconds Hand
secondangle = (2 * pi / 60) * second();
if (second() > 15)
secondangle = secondangle -1.57;
secondangle = secondangle +4.71;
Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, WHITE);
secondend_x = secondhand_radius * cos (secondangle) + clock_center_x;
secondend_y = secondhand_radius * sin (secondangle) + clock_center_y;
Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, BLACK);
// Redraw minutes hand since the section closest to the center gets erased by the seconds hand
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
// Draw Minutes Hand
minuteangle = (2 * pi / 60) * minute();
if (minute() > 15)
minuteangle = minuteangle -1.57;
minuteangle = minuteangle +4.71;
// Erase old minutes Hand
draw_minute(WHITE);
// Calculate Minute Hand Base
minutebase_x = minutebase_radius * cos (minuteangle - pi/2) + clock_center_x;
minutebase_y = minutebase_radius * sin (minuteangle - pi/2) + clock_center_y;
minutebase_x1 = minutebase_radius * cos (minuteangle + pi/2) + clock_center_x;
minutebase_y1 = minutebase_radius * sin (minuteangle + pi/2) + clock_center_y;
// Calculate Minute Hand Point
minuteend_x = minutehand_radius * cos (minuteangle) + clock_center_x;
minuteend_y = minutehand_radius * sin (minuteangle) + clock_center_y;
// Draw new minutes Hand
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
// Draw Hour Hand
minfloat = minute(); // Convert minute short to float
hourangle = (2 * pi / 12) * ((hourFormat12()) + (minfloat/60)); // Find angle for hour hand
hourangle = hourangle -1.57;
// Erase old Hour Hand
draw_hour(WHITE);
// Calculate hour Hand Base
hourbase_x = hourbase_radius * cos (hourangle - pi/2) + clock_center_x;
hourbase_y = hourbase_radius * sin (hourangle - pi/2) + clock_center_y;
hourbase_x1 = hourbase_radius * cos (hourangle + pi/2) + clock_center_x;
hourbase_y1 = hourbase_radius * sin (hourangle + pi/2) + clock_center_y;
// Calculate hour Hand Point
hourend_x = hourhand_radius * cos (hourangle) + clock_center_x;
hourend_y = hourhand_radius * sin (hourangle) + clock_center_y;
// Draw new hours Hand
draw_hour(BLACK);
ReefAngel.LCD.DrawDate(5,121);
break;
//---------------------------------------------------------------------------- Screen Code 6---------------------------------------------------------------------------------
case 5: // Vortech Setup
ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
ReefAngel.RF.SetMode(Slave_Start,0,0);
if (ReefAngel.Joystick.IsButtonPressed())
ReefAngel.RF.SetMode(Slave_Stop,0,0);
ReefAngel.LCD.DrawText(0,255,50,60,"Done");
break;
//------------------------------------------------------------------------------ Begin Setup --------------------------------------------------------------------------------
ReefAngel.Timer[LCD_TIMER].SetInterval(180);
ReefAngel.Timer[LCD_TIMER].Start(); // start timer
ReefAngel.SetTemperatureUnit(1);
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port6Bit;
ReefAngel.LightsOnPortsE[0] = Port4Bit;
//------------------------------------------------------------------------- Ports that are always on ------------------------------------------------------------------------
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port3);
//--------------------------------------------------------------------------- Specific Functions ----------------------------------------------------------------------------
ReefAngel.Relay.DelayedOn(Port2, 2);
ReefAngel.Relay.DelayedOn(Box1_Port1, 2);
ReefAngel.Relay.DelayedOn(Box1_Port2, 2);
ReefAngel.StandardATO( Port5,80 );
ReefAngel.StandardHeater( Port6,247,255 );
ReefAngel.StandardHeater( Box1_Port6,247,255 );
ReefAngel.MoonLights(Box1_Port4);//SumpLight
ReefAngel.Portal("JNieuwenhuizen");
//------------------------------------------------------------------------------ Multiple Screens ----------------------------------------------------------------------------
if (ReefAngel.Joystick.IsLeft())
ScreenID--;
if (ReefAngel.Joystick.IsRight())
ScreenID++;
if (ScreenID<0) ScreenID=NumScreens;
//------------------------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//----------------------------------------------------------------- Start RF Daytime Control ------------------------------------------------------------------------------
if (hour() >8 && hour() < 14)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,80,7);
vtechmode = Smart_NTM;
else if (hour() >14 && hour() < 22)
ReefAngel.RF.SetMode(Random2,60,7);
vtechmode = Random2;
//--------------------------------------------------------------- Start RF Nightmode Control -----------------------------------------------------------------------------
else if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
ReefAngel.RF.SetMode(Night,10,0);
vtechmode = Night;
ReefAngel.RF.SetMode(vtechmode, InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
Re: VortechMenu
Sorry man...
Got busy and forgot to look at it.
I found out why
You forgot to check for fOverrideRF in your schedule.
use this:
Also, just a minor bug too on the screen checking...
You will go out of bound if you use ScreenID=NumScreens.
I found out why
use this:
if (!fOverrideRF)
vtechmode = Night;
- JNieuwenhuizen
Re: VortechMenu
Thank you Roberto.
We are getting somewhere
It changes modes on the screen now, not on the RF module
Re: VortechMenu
Try this one:
if (!fOverrideRF)
vtechmode = Night;
