PostPosted: Thu Aug 04, 2016 3:04 pm
Is there a way to add part readings to it
PostPosted: Fri Aug 05, 2016 5:21 pm
bkc6868 wrote:Is there a way to add part readings to it
part readings? I'm not familiar with that.
PostPosted: Fri Aug 05, 2016 5:37 pm
PAR from Robert's PAR sensor I'd assume.
PostPosted: Mon Aug 08, 2016 12:04 pm
lnevo wrote:PAR from Robert's PAR sensor I'd assume.
that is what I thought as well but I wanted to be certain.
If it is referencing the PAR sensor, then that is not currently implemented in the app.
PostPosted: Tue Mar 14, 2017 5:26 pm
Will this app be updated to work with the new cloud attachment?
PostPosted: Tue Mar 14, 2017 5:36 pm
slm222 wrote:Will this app be updated to work with the new cloud attachment?
Possibly. I do not currently know how the new cloud attachment works, so I cannot say for certain. (I have not kept up on the discussion of it.)
PostPosted: Sun Nov 26, 2017 6:52 pm
Well, after 2 years of "inactivity", I finally put out another release of my app. It doesn't have lots of the requests from people. It primarily is updated to use the newer support libraries, which should hopefully fix some of the random connection issues. I personally have noticed that it fixes my issues with being unable to read the date and time from the controller.
I also added in some of the initial support for the RA*. You now have the second AP and DP channels available. It still displays the main/primary relay box, which is unused with the star. This should be hidden in future releases. It also does not use the new MQTT protocol. It still gets the data the standard way.
I am going to be gradually working on updating more in my spare time. It's just a slow process now for me.
Enjoy.
PostPosted: Sun Nov 26, 2017 6:58 pm
cool
thanks!!!
PostPosted: Thu Feb 15, 2018 8:22 pm
Curt, thanks for this! One question. I am having trouble downloading the labels. Not sure what is happening. Anything I can do?
PostPosted: Fri Feb 16, 2018 5:12 pm
lucho wrote:Curt, thanks for this! One question. I am having trouble downloading the labels. Not sure what is happening. Anything I can do?
it pulls the labels from the portal. so if the labels are not in the portal, it cannot get them. there could be a problem with your communication with the portal. try it on a different network if possible (use cellular instead of wifi).
PreviousNext
Return to Apps
