Reef Angel Web Wizard
PostPosted: Thu Mar 08, 2018 10:56 pm
I think it is the same
PostPosted: Fri Mar 09, 2018 5:44 pm
I kept getting Error 400 last night. I'll try again tonight.
Sent from my Pixel XL using Tapatalk
PostPosted: Fri May 11, 2018 4:09 pm
I just got the Cloud Portal. I downloaded the latest RA code, ReefAngelInstaller_1.1.3.exe. (I had 1.1.1 installed before that).
Installed.
Per the docs, used the WebWizard. Got a sketch. Copied it to my development machine (I use vMicro, but for this I used the RA Arduino fork executable). A snippet of the problem code:
   ReefAngel.CloudPortal();
I get an error:
Error: 'class ReefAngelClass' has no member function named 'CloudPortal'
Indeed, I downloaded the Github code (https://github.com/reefangel/Libraries) and find that the word "CloudPortal" does not exist in any of the library files, and is not a member of ReefAngel.cpp. I even followed breadcrumbs to https://github.com/lnevo but it's the same as what's checked in under ReefAngel.
So what do I have to do to get this to compile?
== John ==
PostPosted: Fri May 11, 2018 4:25 pm
Try using the dev branch of the github
PostPosted: Sat May 12, 2018 11:06 am
rimai wrote:Try using the dev branch of the github
That seems better, BUT ...
Then the "Dev" branch needs to be copied over, or the docs need updating. This is crazy.
I copied over the dev branch to my user folder (%USER%\Arduino) and now I'm getting a ton of compiler errors. Can't quite tell if the Dev branch is Arduino 1.0.1 or something newer. This is harder than it should be.
Is this product dead? :(
PostPosted: Sat May 12, 2018 11:14 am
No. The dev branch is the latest. It is what it is used on the web wizard.
I decided not use the Arduino IDE for mainstream anymore. It is only used for development.
The webwizard is what you want to use if you don't want to worry about compile errors.
Link for webwizard: webwizard
Now, if you are talking about doing library development, then it is another story. You will need the IDE.
So, I would suggest just going to webwizard and doing all the compiling and uploading in there.
PostPosted: Wed Jun 13, 2018 3:09 pm
I am doing development :(
Or, I was ... I copied over my code into the web wizard and at least sort of got it to work.
PostPosted: Tue Oct 02, 2018 1:56 pm
rimai wrote:So, I would suggest just going to webwizard and doing all the compiling and uploading in there.
But how do you suggest we do this if we use the Bluetooth adapter for upload?
PostPosted: Sat Oct 06, 2018 3:27 pm
Copy and paste into the Audrino app and upload with the Bluetooth adapter, it's just more convenient because it's wireless.
PostPosted: Sat Oct 06, 2018 3:40 pm
But that’s the problem. The web wizard is using the dev branch, which works with the cloud portal. The 1.1.3 libraries don’t support this in Arduino. And the web wizard doesn’t support the Bluetooth adapter.
Just a few posts above, it sounded like copying the dev branch locally was causing a bunch of compile errors. I haven’t tried doing this myself yet, though.
Seems odd to me that the web wizard would be using the dev branch and not a release branch. And why hasn’t the cloud portal made it into a release branch yet if it’s being sold?
PreviousNext
Return to Apps
