UApp Error - Nothing to update
PostPosted: Tue Jan 08, 2019 9:32 am
Will do...
PostPosted: Tue Jan 08, 2019 9:38 am
BTW, do you want me to do this while I'm seeing the null value? I have updated them again from the URL, so I will need to reproduce the issue. Should be easy, but I want to check before proceeding.
PostPosted: Tue Jan 08, 2019 9:40 am
Well, it was easy to get the null value back. Here is the string with the null value I'm seeing:
0f1e1500c2000f1e0a000f00525584035802340314140b030d03340333033ce402bf01001400161e00003c3c081e141e0a14323c14323c00800a0f643c0f643c0f643c0f643c0f643c0f643c780078000208c201000203f80220032a0300643c00643c00643c00643c00643c00643c00643c00643c00643c07f401c409000000000b0362645a3c00000032325702eb054e026c074e026c074e026c07ffffffffffffffff00ffffffffffffffffffffff
PostPosted: Tue Jan 08, 2019 11:26 am
That's very odd.
C2 is not a valid hour.
The string represents the internal memory values starting at 200.
What happens when you change to a correct number and click save?
Can you post the log?
PostPosted: Tue Jan 08, 2019 3:11 pm
FYI, updating the value is now causing my controller to reboot.
PostPosted: Tue Jan 08, 2019 3:17 pm
It seems to be rebooting every time the Uapp needs to update more than one value at a time, which the time fields do automatically. If I update a single field, it works fine. If I update two independent fields or a single time field, it reboots the controller.
PostPosted: Tue Jan 08, 2019 3:38 pm
Were you able to see what the console log shows when you update the value?
PostPosted: Tue Jan 08, 2019 3:41 pm
See attachment.
forum.reefangel.com-1546987244699.log
Chrome Console Log
(1.51 KiB) Downloaded 7 times
PostPosted: Tue Jan 08, 2019 4:32 pm
According to the log, the controller did receive the memory location 204 change to 14 and it even responded with OK.
The 205 was not acknowledged though.
That's when you mentioned it rebooted and I can see that in the log too.
But I can't replicate.
This is what I get on my RA+ test controller using the cloud wifi attachment:
0f1e15000e3b151e0a000f00040484035802ee021414fd02030307030303ff3e031c02071400161e00ffff3c003c00f6090f643c0f643c05380b0f643c0f643c0f643c0f643c0f643c0f643c7800ffff0208c2011e0203f80220032a0300643c00643c00643c00643c00643c00643c00643c00643c00643c07f401c40984031405ee023c41043c0001022e0a4e026c074e026c074e026c074e026c07ffffffffffffffff1effffffffffffffffffffff
uapp.js:661 PopoverControllermemoryrawok
uapp.js:2111 PH:340
uapp.js:2111 PH:342
uapp.js:2111 PH:340
uapp.js:2111 PH:342
uapp.js:931 mb204,13
uapp.js:2111 MBOK:204
uapp.js:2373 mb205,58
uapp.js:2111 MBOK:205
uapp.js:2111 PH:340
uapp.js:2111 PH:342
PostPosted: Thu Jan 10, 2019 12:27 pm
Strangely, the same change from my phone causes the same timeout, but it does not cause the reboot.
Previous
Return to Apps
