Universal App
PostPosted: Sun May 27, 2018 7:19 pm
If I go to the U app web base on a Android device if I go into draw graphs I do not get to see the full graph if I do at least custom for pwme4,pwme5 it only shows me a portion of the screen graph I think maybe there's a browser display size issue or something I don't know
One pic is landscape other is portrait orientation
PostPosted: Thu Feb 14, 2019 11:34 pm
My wife got me a 10 inch tablet to use as the main interface for the controller. Would it be a lot of trouble to do some formatting changes to the UAPP?
It would be nice if the Relays were tiled instead of vertical. I think you could go 3 wide and it would make it so you wouldn't have to scroll to see status of or change relay outputs.
Also, It would really be nice if we could create/save a default graph setting.
PostPosted: Thu Feb 14, 2019 11:52 pm
Maybe even 4 relay boxes wide... example.
PostPosted: Thu May 16, 2019 9:01 pm
v2.0.7 release.
Updates from sbidny
viewtopic.php?f=8&t=6924
PostPosted: Fri May 17, 2019 10:07 am
Just a heads up that it appears Safari heavily caches this site on an iPhone. You need to do clear the cache in order to view the new site properly.
Go to Settings -> Safari -> Advanced -> Website Data
Search for "reefangel.com," swipe the entry, and click "Delete."
Now you should be able to reload with the new site.
PostPosted: Mon May 20, 2019 12:56 pm
@tkeracer619, I have a working version with a responsive layout for the relays. It will lay as many as possible across horizontally before wrapping to the next line, depending on the device being used. I need to do a little more testing, but I'll try to get this over to Roberto in the next few days.
PostPosted: Mon May 20, 2019 10:32 pm
v2.0.8 release.
Bug fixes
Changed to secure SSL connections.
PostPosted: Tue May 21, 2019 3:36 am
Seeing the new version after clearing my browser cache. Glad to see the move to SSL.
PostPosted: Tue May 21, 2019 3:42 am
Looks like auto-reconnect broke after moving to SSL. Will take a look today. Likely just a different disconnect code, as I check the code before attempting a reconnect.
PostPosted: Fri Jun 12, 2020 11:13 pm
How can I get my labels onto the U app? Its written in my code ( Bottom in grey font) but wont show or upload into the app.
Is there a way I can force it ? I had a heck of a time getting my web wizard code to compile the same code it just uploaded onto the controller that is saved and when it did the com port would disappear etc.
I'm trying to not ask for everything but its been two days of research / attempted Work arounds( Portal) trying to get port forwarding working on my ORBI mesh system, Getting the android app to work until 10:35 tonight ( Mesh system opened up port 2000 on my external ip somehow allowing the android status app to work ) then after I spent time changed labels it stopped working once I triggered a reboot from the status app on the *.
The web Wizard does still have the ability to add labels right ? Is there a command prompt i need to add to the wizard to include the labels on the app? I got all 16 relays working , timers functioning , dosing pumps schedule running but I just cant get the labels to come through .
I know the forum isn't very busy anymore but I need a work around or advice please . Thanks
PreviousNext
Return to Apps
Users browsing this forum: No registered users and 7 guests
