Yes, definitely. I noticed quite a few extra memory locations I didn't recognize initially on the drop down. I didn't mean to be overly critical or too harsh in anyway. Having 1 form with 100 options scattered all over the place is also not a very good solution. I think either a tabbed control or maybe an accordion style control similar to what you have on the portal dashboard would be a good way to show/hide what a user cares about at any given time. I'm still glad that RAGen is actively being worked on and evolving because I think it's the best application available for the RA bar none.rimai wrote:I liked the old format too, but the problem was that there is an increasing number of memory locations and it would become too big for one window.
Maybe a tab system just like the RAGen tabs? One for standard settings like lights, heater and ato and then one for the additional settings, and then one for each expansion module?
Just a thought.
RAGen v1.2.2 - MUST READ for all RAGen Users
dmolton
Re: RAGen v1.2.2 - MUST READ for all RAGen Users
- Contact:
Yeah Dave & I have had a lengthy discussion about the Internal Memory page. I do have some more ideas about improving it.
The comments were not too harsh, but they were rather hysterical.
The nice thing was that constructive criticism was given and suggestions for improvements. Commenting truthfully on things can be a bit touchy at times but it's definitely needed and appreciated.
One thing that I thought of as well, is to put a "Preview" button on the form. This would generate a "document" (just a bunch of text inside another window) that displays all of the memory settings. This way you could "preview" it before you generate the memory file. It would be a general overview that you could glance at all the settings and figure out what needs to be changed (if anything). This could be a temporary "fix" until I can devote time to improving it. Any thoughts on this??
rossbryant1956
how do I get the new app? Is it on the download site? TIA
rossbryant1956
should I uninstall the earlier version or just install over? Thx
Okay, so I looked..there is nothing to uninstall...there is also no setup.exe.
Do I just copy these files into the right directories?
Sebyte
It is always best practice to remove previous versions of any application before you install new. Most applications will leave behind files which hold user set up references, and they will then apply them to the new version. I believe that RAgen will do this too.
- Contact:
You just need to download the RAGen-v122-static.zip file (http://curtbinder.info/apps/RAGen-v122-static.zip). Unzip the file and you will have RAGen.exe. Overwrite the RAGen.exe file that is located in the c:\Program Files\Reef Angel Controller (or Program Files (x86)).rossbryant1956 wrote:should I uninstall the earlier version or just install over? Thx
Just copy / paste to overwrite. Make sure that you have RAGen closed when you copy & paste, otherwise it will give you an error.
That's all that it takes to update it.
abhi_123
Hi Curt.
suppose if i want to use pwm parabola function instead of slope than also we have to enter the values in internal memory.
- Contact:
The pwm slope and parabola both use the same internal memory locations. So you would need to have the internal memory locations set if you wanted to use the short forms of them. You can always use the long forms and manually add in your values, but doing this will not allow you to update them without reloading your code.abhi_123 wrote:Hi Curt.
abhi_123
This is my test internal memory code which i have generated.
and this is my first code// Autogenerated file by RAGen (v1.2.2.171), (04/29/2012 19:59)
// Memory_042912_1959.ino
// This file sets the default values to the Internal Memory
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOnMinute_write(0);
InternalMemory.MHOffHour_write(16);
InternalMemory.MHOffMinute_write(16);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(16);
InternalMemory.StdLightsOffMinute_write(15);
InternalMemory.WM1Timer_write(90);
InternalMemory.WM2Timer_write(200);
InternalMemory.DP1Timer_write(10);
InternalMemory.LEDPWMDaylight_write(70);
InternalMemory.LEDPWMActinic_write(75);
InternalMemory.HeaterTempOn_write(780);
InternalMemory.HeaterTempOff_write(791);
InternalMemory.ChillerTempOn_write(810);
InternalMemory.ChillerTempOff_write(785);
InternalMemory.ATOTimeout_write(75);
InternalMemory.PHMax_write(840);
InternalMemory.PHMin_write(550);
InternalMemory.MHDelay_write(5);
InternalMemory.ATOHighTimeout_write(60);
InternalMemory.DP1RepeatInterval_write(0);
InternalMemory.DP2RepeatInterval_write(0);
InternalMemory.SalMax_write(2550);
InternalMemory.PWMSlopeStartD_write(10);
InternalMemory.PWMSlopeEndD_write(95);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(20);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeDurationA_write(60);
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(100);
InternalMemory.RFDuration_write(10);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
here in my code there is no value assigned for pwm slope. should i manually enter the value or it will work default on values entered in internal memory?// Autogenerated file by RAGen (v1.2.2.171), (04/29/2012 20:02)
// RA_042912_2002.ino
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define ENABLE_ATO_LOGGING
#define SALINITYEXPANSION
#define ORPEXPANSION
#define FONT_8x8
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO(Port1);
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.Portal("abhi_123");
- Contact:
The 2 slope functions that are added (ActinicPWMSlope and DaylightPWMSlope) use these memory values:
and they also use the same light schedule (on & off times) as the StandardLights schedule.
So no changes are necessary to the functions.
abhi_123
Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?
- Contact:
The changes are simple. You would change this:abhi_123 wrote:Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?
ReefAngel.PWM.DaylightPWMSlope();Code: Select all
ReefAngel.PWM.DaylightPWMParabola();-
abhi_123
cool. Thats very simple.
one more thing(sorry for troubling you with my newbie question) i will be using pwm fans to control the temp of my heatsink & tank i want to put a conditional code like if the temp of t1 increased the desired value start the fan which is installed on channel 4 in pwm expansion module & gradually decrease its speed depending upon the temp.
- Contact:
http://forum.reefangel.com/viewtopic.ph ... 170&p=8969
Roberto will have to comment on how he does the gradual increasing.
TanksNStuff
Sorry to bring up old topics, but I had a question about the code above and the 1.2.2 libraries.binder wrote:The changes are simple. You would change this:abhi_123 wrote:Thanks Curt. Btw if i plan to use parabola what changes if i have to make in my current code?to this:Code: Select all
ReefAngel.PWM.ActinicPWMSlope(); ReefAngel.PWM.DaylightPWMSlope();Then reload your code on your controller. That's all that would be needed.Code: Select all
ReefAngel.PWM.ActinicPWMParabola(); ReefAngel.PWM.DaylightPWMParabola();
How would I do this for the PWM Expansion Module channels?
My currently working code (using slope) is as follows:
ReefAngel.PWM.Channel0PWMSlope(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel1PWMSlope(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();-
ReefAngel.PWM.Channel0PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel1PWMParabola(InternalMemory.ActinicOffset_read());
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
TanksNStuff
Thanks Roberto. That's what I thought it was, but just wanted to be sure.
