Reef Angel Wizard
AquaO
Reef Angel Wizard
Post by AquaO »
Hi Roberto,
I use the new Wizard to generate my code (great job it's very simple) but i set port 1-2-3-4-5-6-7 always on/off in feed mode and port 8 for my dosing pump.
After transfert in my ReefAngel, i realize all port is off exept dosing pump (i'm not in feed mode)
Do you have any idea??
Thank
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
Re: Reef Angel Wizard
Bug on the wizard.
Check a couple posts back:
http://forum.reefangel.com/viewtopic.php?p=10586#p10586
I already pushed the updated version.
If you run the update utility, it should download the newest file, which is v1.04
Let me know if you have problems.
CASPAR
Post by CASPAR »
Updated to v1.04 and everything seems to be working fine now, will keep ya posted. Thanks Roberto!
AquaO
Reef Angel Wizard
Post by AquaO »
CASPAR wrote:Updated to v1.04 and everything seems to be working fine now, will keep ya posted. Thanks Roberto!
Yess it's work!!
I love the new wizard it's "friendly user"
Thank you Roberto
rossbryant1956
Post by rossbryant1956 »
I just downloaded the new version and it still has 1.03. How do I get 1.04?
Use the update utility: www.reefangel.com/update
astralmind
Post by astralmind »
Nice!!! Got 1.04 running here, will have to generate new code to see if it fixes my screen issues.
2 observations:
- On my PC (Win 7 64bits) the layout cuts out some critical piece of info when left on standard "medium" size. For example, I only see the top of the AT Timeout dropbox but I can't click it. There seems to be noway to resize it. I'm running in standard 1080p resolution so I imagine I'm definitely not the only one with this issue. Reducing the display size to "small" fixes this but small is not very fun to use for everyday.
- The Wizard is awesomely user friendly when used with default "hard coded" values. However, if used in conjunction with the memory file (which I assume most people would want) it gets a little trickier. Would it be possible to use an almost identical interface when filling in the hardcoded and memory version? I would assume most of the memory file could be populated step by step in the same fashion and at the end of the wizard we could have both files generated with a simple pop stating that you should upload the mem file first followed by the rest of the code. Just a thought from a very lazy guy hehe :)
I think the Wizard truly makes the RA an accessible controller, even more so than others and that is quite an amazing feat!
Thanks for the suggestions :)
They are very welcomed and I never realized that the layout would get messed up with increasing font size.
I never tried doing it on my computer, but I'll look into it.
I'm planning on changing the wizard to make it as user-friendly and the hard coded version.
My initial plan was to just have it available for hard coded version, but decided to do the internal memory too, but didn't do as good of a job as the hard coded.
But, I've been working on changing the Arduino IDE and I got to a point now that I can interact and be able to load 2 INO files and have feedback of success or failure, which was what I was missing previously.
So, the future release will be be able to load both files in this step-by-step fashion. :)
Mike S
Post by Mike S »
Is anyone having issue with the actinic lights functions? I used the wizard last night to generate this code. For some reason the two ports (1&2 on my main relay) that my actinics are on are staying energized. The standard lights are on the same schedule and working ok. I've tried powering it on and off and have resent the memory values using the android app.
    ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.StandardLights( Port3 );
    ReefAngel.StandardLights( Port4 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.MoonLights( Port6 );
    ReefAngel.StandardHeater( Box1_Port2 );
    ReefAngel.MoonLights( Box1_Port5 );
    ReefAngel.SingleATOLow(Box1_Port6);
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Box1_Port6);
    ReefAngel.DosingPumpRepeat1( Box1_Port7 );
    ReefAngel.DosingPumpRepeat2( Box1_Port8 );
    ReefAngel.Portal( "Mike S" );
    int x,y;
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Which value did you update with android?
Mike S
Post by Mike S »
The MH on and off hour and minute
The function does not use those.
It actually offsets the StandardLights by x amount of minutes that you need to set on memory location ActinicOffset or 884.
Mike S
Post by Mike S »
That would explain it thanks! Is the memory function not available in the Android apps yet or am I just missing it?
Mike S
Post by Mike S »
rimai wrote:The function does not use those.
Is there a default offset for this? My actinics relays don't appear to be cycling on. I'm not seeing any ActinicOffset code in my memory or pde files nor in Ragen or the android app. I'm confused why those relays aren't just cycling on with my standards lights. Thanks Mike
No default value.
It's a brand new memory location that has not been included into the RAGen yet.
Use this:
    InternalMemory.ActinicOffset_write(30);
Or custom memory on Android.
Mike S
Post by Mike S »
Ah so that what that custom location is for on the Android apps. :D That worked like a charm thanks.
I will be adding in the new memory locations to the app in the near future.
I need beta testers :)
I have the 2.0 beta version to be tested.
Please download the files needed here:
http://www.reefangel.com/files/wizardbeta2.0.zip
Extract the zip file and you will see 2 folders and 1 file.
Move the folder tools to Documents\Arduino and click "Yes" to any overwrite prompt
Move the folder update to Documents\Arduino
Move the file pde.jar to Program Files\Reef Angel Controller\lib and click "Yes" to any overwrite prompt
Let me know if you have problems getting it updated.
sebimme
Reef Angel Wizard
Post by sebimme »
I will test it!
All updates went as they should.
No problems with RAGen or uploading my existing code.
Anything else to test?
No, not RAGen.
I've updated the Reef Angel Wizard.
Tools->Reef Angel Wizard
rossbryant1956
are there any release notes yet? What's in the new version?
It has not been released yet, thus no notes :(
I was just asking for beta testers before it gets released.
But it was a total overhaul of the original one and that's why it will be bumped it to 2.0
If you do get to test, watch for new user interface, new logic for code generation, internal memory code generation, settings are stored so when you open again, you get it just the way you left off.
Doh! Ok I'll mess with it!
Works beautifully! Now granted I don't have the most advanced RA set up. But I love the layout. It generates the correct code and compiles. The added relay features are great!
jpalmer
Post by jpalmer »
As an OSX user, you'll need to do the following to test the new wizard:
open the zipfile
Copy the "tools" and "updates"folders to ~/Documents/Arduino (I personally renamed the old folders, just in case)
Copy the pde.jar file to /Applications/Arduino.app/Contents/Resources/Java/
You'll need to change the paths if you installed the software to a custom location.
Dave just informed me that the Wizard generates a code that requires the newest libraries that are to be released shortly. So, if you upload the code, you may get the "No Internal Memory" message.
This is expected as you don't have the newest set of libraries. So, for now, please don't upload any code.
Toolboy
Post by Toolboy »
I used the wizard, but didnt put values into the internal memory but had it put it into the code and it all works fine since 14 June 2012
The only issue I'm having since I did this. Is the wifi unit loose connection often. Some times in 6 hours or sometimes 2 days. Most times I just have to unplug the unit to get it to work again. Otherwise I have to reprogram it. I've already upgraded to 2.35 and still having issues. Do you think new libraries could help with this issue?
Interested on knowing more... you got pm
