Reef Angel Wizard
Re: Reef Angel Wizard
The MH on and off hour and minute
The function does not use those.
It actually offsets the StandardLights by x amount of minutes that you need to set on memory location ActinicOffset or 884.
That would explain it thanks! Is the memory function not available in the Android apps yet or am I just missing it?
rimai wrote:The function does not use those.
Is there a default offset for this? My actinics relays don't appear to be cycling on. I'm not seeing any ActinicOffset code in my memory or pde files nor in Ragen or the android app. I'm confused why those relays aren't just cycling on with my standards lights. Thanks Mike
No default value.
It's a brand new memory location that has not been included into the RAGen yet.
Use this:
Or custom memory on Android.
Use this:
InternalMemory.ActinicOffset_write(30);
Ah so that what that custom location is for on the Android apps. That worked like a charm thanks.
I will be adding in the new memory locations to the app in the near future.
I need beta testers
I have the 2.0 beta version to be tested.
Please download the files needed here:
http://www.reefangel.com/files/wizardbeta2.0.zip
Extract the zip file and you will see 2 folders and 1 file.
Move the folder tools to Documents\Arduino and click "Yes" to any overwrite prompt
Move the folder update to Documents\Arduino
Move the file pde.jar to Program Files\Reef Angel Controller\lib and click "Yes" to any overwrite prompt
Let me know if you have problems getting it updated.
- DrewPalmer04
All updates went as they should.
No problems with RAGen or uploading my existing code.
Anything else to test?
No, not RAGen.
I've updated the Reef Angel Wizard.
Tools->Reef Angel Wizard
are there any release notes yet? What's in the new version?
It has not been released yet, thus no notes
I was just asking for beta testers before it gets released.
But it was a total overhaul of the original one and that's why it will be bumped it to 2.0
If you do get to test, watch for new user interface, new logic for code generation, internal memory code generation, settings are stored so when you open again, you get it just the way you left off.
- DrewPalmer04
Doh! Ok I'll mess with it!
- DrewPalmer04
Works beautifully! Now granted I don't have the most advanced RA set up. But I love the layout. It generates the correct code and compiles. The added relay features are great!
As an OSX user, you'll need to do the following to test the new wizard:
open the zipfile
Copy the "tools" and "updates"folders to ~/Documents/Arduino (I personally renamed the old folders, just in case)
Copy the pde.jar file to /Applications/Arduino.app/Contents/Resources/Java/
You'll need to change the paths if you installed the software to a custom location.
open the zipfile
Dave just informed me that the Wizard generates a code that requires the newest libraries that are to be released shortly. So, if you upload the code, you may get the "No Internal Memory" message.
This is expected as you don't have the newest set of libraries. So, for now, please don't upload any code.
I used the wizard, but didnt put values into the internal memory but had it put it into the code and it all works fine since 14 June 2012
The only issue I'm having since I did this. Is the wifi unit loose connection often. Some times in 6 hours or sometimes 2 days. Most times I just have to unplug the unit to get it to work again. Otherwise I have to reprogram it. I've already upgraded to 2.35 and still having issues. Do you think new libraries could help with this issue?
I have another suggestion for the Reef Angel Wizard.
It would be cool to have a navigation window to the left, so you can just click on the area you want.
some people have large setups. It would take a bit of time flicking through. especially if you are troubleshooting.
sam
sam
Roberto-
WOrking on setting up comm for the Weather package and was going to use wizard to generate base .INO file for my main. Do you recommend I try out the beta or stick to current release version, just don't want to bake in uncertainty with respect to debugging my comm.
Hi,
Not sure if i have found a bug if i select Aqua Illumination Cable, go through the process.
when i get to Aqua Illumination Port select. i click Low ATO Port or High, click next the nothing stays on that screen.
v 2.0.1
sam
v 2.0.1
sam
Yes, bug.
Thanks for reporting.
I've added to the issues list:
https://github.com/reefangel/Wizard/issues/5
Feature Request
it would be cool for cloud and thunder storm options for dimming and AI Sol.
Not sure if this is the place for it, but I'd like to be able to set a timer function for my algae scrubber that runs twice a day. I normally run this equipment for 6 hours on and 6 hours off. I just got my RA and for now I am attempting to program a wavemaker port to run for 21600 seconds every 720 minutes.
I've never tried using it that way.
Can we do a custom code?
Is it 0-6, 6-12, 12-18, 18-0 hours?
