Page 2 of 2
Re: Reef Angel Wizard
Posted: Wed Jun 27, 2012 2:44 pm
by DrewPalmer04
All updates went as they should.
No problems with RAGen or uploading my existing code.
Anything else to test?
Posted: Wed Jun 27, 2012 2:46 pm
No, not RAGen.
I've updated the Reef Angel Wizard.
Tools->Reef Angel Wizard
Posted: Wed Jun 27, 2012 3:08 pm
by rossbryant1956
are there any release notes yet? What's in the new version?
Posted: Wed Jun 27, 2012 3:13 pm
It has not been released yet, thus no notes
I was just asking for beta testers before it gets released.
But it was a total overhaul of the original one and that's why it will be bumped it to 2.0
If you do get to test, watch for new user interface, new logic for code generation, internal memory code generation, settings are stored so when you open again, you get it just the way you left off.
Posted: Wed Jun 27, 2012 3:36 pm
by DrewPalmer04
Doh! Ok I'll mess with it!
Posted: Wed Jun 27, 2012 4:59 pm
by DrewPalmer04
Works beautifully! Now granted I don't have the most advanced RA set up. But I love the layout. It generates the correct code and compiles. The added relay features are great!
Posted: Wed Jun 27, 2012 7:47 pm
by jpalmer
As an OSX user, you'll need to do the following to test the new wizard:
open the zipfile
Copy the "tools" and "updates"folders to ~/Documents/Arduino (I personally renamed the old folders, just in case)
Copy the pde.jar file to /Applications/Arduino.app/Contents/Resources/Java/
You'll need to change the paths if you installed the software to a custom location.
Posted: Wed Jun 27, 2012 7:58 pm
Dave just informed me that the Wizard generates a code that requires the newest libraries that are to be released shortly. So, if you upload the code, you may get the "No Internal Memory" message.
This is expected as you don't have the newest set of libraries. So, for now, please don't upload any code.
Posted: Wed Jun 27, 2012 11:17 pm
by Toolboy
I used the wizard, but didnt put values into the internal memory but had it put it into the code and it all works fine since 14 June 2012
The only issue I'm having since I did this. Is the wifi unit loose connection often. Some times in 6 hours or sometimes 2 days. Most times I just have to unplug the unit to get it to work again. Otherwise I have to reprogram it. I've already upgraded to 2.35 and still having issues. Do you think new libraries could help with this issue?
Posted: Thu Jun 28, 2012 7:50 am
Interested on knowing more... you got pm
Posted: Thu Jun 28, 2012 10:22 pm
by Toolboy
Cool. Pm sent
Posted: Fri Jun 29, 2012 12:47 am
by slipperysam
I have another suggestion for the Reef Angel Wizard.
It would be cool to have a navigation window to the left, so you can just click on the area you want.
some people have large setups. It would take a bit of time flicking through. especially if you are troubleshooting.
sam
Posted: Fri Jun 29, 2012 8:05 am
Great idea!!!
Posted: Fri Jun 29, 2012 8:08 am
by rufessor
Roberto-
WOrking on setting up comm for the Weather package and was going to use wizard to generate base .INO file for my main. Do you recommend I try out the beta or stick to current release version, just don't want to bake in uncertainty with respect to debugging my comm.
Posted: Fri Jun 29, 2012 8:44 am
Use the currect release
Posted: Mon Jul 16, 2012 8:16 am
by slipperysam
Hi,
Not sure if i have found a bug if i select Aqua Illumination Cable, go through the process.
when i get to Aqua Illumination Port select. i click Low ATO Port or High, click next the nothing stays on that screen.
v 2.0.1
sam
Posted: Mon Jul 16, 2012 10:24 am
Yes, bug.
Thanks for reporting.
I've added to the issues list:
https://github.com/reefangel/Wizard/issues/5
Posted: Thu Jul 19, 2012 3:08 am
by slipperysam
Feature Request
it would be cool for cloud and thunder storm options for dimming and AI Sol.
Posted: Sun Oct 07, 2012 10:24 pm
by tentacles
Not sure if this is the place for it, but I'd like to be able to set a timer function for my algae scrubber that runs twice a day. I normally run this equipment for 6 hours on and 6 hours off. I just got my RA and for now I am attempting to program a wavemaker port to run for 21600 seconds every 720 minutes.
Posted: Mon Oct 08, 2012 8:32 am
I've never tried using it that way.
Can we do a custom code?
Is it 0-6, 6-12, 12-18, 18-0 hours?
Posted: Mon Oct 08, 2012 2:50 pm
by tentacles
Well, the actual on/off hours don't matter to me as long as it gets the right timing... I could always keep my current timer for that anyways.
Posted: Mon Oct 08, 2012 3:45 pm
Try this:
ReefAngel.Relay.Set(Port1,now()%43200<21600);
Posted: Sat Jun 15, 2013 5:45 pm
by psantillana
hi roberto. i already downloaded version Arduino ver1.05 for MacOS but there is no WIZARD under tools. please send me a link where i can find the version with the WiZARD. thank you
Posted: Sat Jun 15, 2013 5:57 pm
You need to use the version that is packaged for the Mac from ReefAngel. If you want to use the Wizard with a different IDE version, you can try and install it manually. It's only distributed on the git repo
Posted: Wed Jul 10, 2013 6:55 pm
by psantillana
lnevo wrote:You need to use the version that is packaged for the Mac from ReefAngel. If you want to use the Wizard with a different IDE version, you can try and install it manually. It's only distributed on the git repo
hi lnevo.
i downloaded the zip file from github. should do i import it in the library of my Arduino 1.0.5? sorry, totally clueless how to add the wizard.
thank you
Paul
Posted: Thu Jul 11, 2013 1:01 am
I think you should stick with the packaged version. I really am not sure. Was just answering the question where to download from..
Posted: Thu Jul 11, 2013 8:49 am
Yeah, stick with the downloadable version from the reefangel.com website.
It's a modified version of the standard Arduino release.
Posted: Sat Jul 13, 2013 8:53 am
Just as curiosity, did you see anything on v1.0.5 that would be worth spending the time trying to update our modified IDE?
