Reef Angel Wizard
PostPosted: Thu Jun 28, 2012 10:22 pm
Cool. Pm sent
PostPosted: Fri Jun 29, 2012 12:47 am
I have another suggestion for the Reef Angel Wizard.
It would be cool to have a navigation window to the left, so you can just click on the area you want.
some people have large setups. It would take a bit of time flicking through. especially if you are troubleshooting.
sam
PostPosted: Fri Jun 29, 2012 8:05 am
Great idea!!!
PostPosted: Fri Jun 29, 2012 8:08 am
Roberto-
WOrking on setting up comm for the Weather package and was going to use wizard to generate base .INO file for my main. Do you recommend I try out the beta or stick to current release version, just don't want to bake in uncertainty with respect to debugging my comm.
PostPosted: Fri Jun 29, 2012 8:44 am
Use the currect release
PostPosted: Mon Jul 16, 2012 8:16 am
Hi,
Not sure if i have found a bug if i select Aqua Illumination Cable, go through the process.
when i get to Aqua Illumination Port select. i click Low ATO Port or High, click next the nothing stays on that screen.
v 2.0.1
sam
PostPosted: Mon Jul 16, 2012 10:24 am
Yes, bug.
Thanks for reporting.
I've added to the issues list:
https://github.com/reefangel/Wizard/issues/5
PostPosted: Thu Jul 19, 2012 3:08 am
Feature Request
it would be cool for cloud and thunder storm options for dimming and AI Sol.
PostPosted: Sun Oct 07, 2012 10:24 pm
Not sure if this is the place for it, but I'd like to be able to set a timer function for my algae scrubber that runs twice a day. I normally run this equipment for 6 hours on and 6 hours off. I just got my RA and for now I am attempting to program a wavemaker port to run for 21600 seconds every 720 minutes.
PostPosted: Mon Oct 08, 2012 8:32 am
I've never tried using it that way.
Can we do a custom code?
Is it 0-6, 6-12, 12-18, 18-0 hours?
Return to Apps
Users browsing this forum: Google [Bot] and 2 guests
