New Windows Gadget
PostPosted: Wed Aug 22, 2012 8:58 am
I was having the same issues at first. Make sure you don't have the trailing slash at the end of your URL: http://ipaddress:2000
It took a a few seconds, maybe a minute, after dropping the trailing slash for it to start registering.
~Charlie
PostPosted: Wed Aug 22, 2012 8:25 pm
I had to delete the gadget completely, reinstall it, then delete it again. reinstall ( fresh download ) and it worked finally!
Adam
58 Gal
PostPosted: Fri Feb 15, 2013 7:15 am
Anyone else having problems with the wifi attachment while using the gadget 24/7? It seemed to have started after I updated the RA library.
My wifi attachment will stop updating, but will reply to ping. I have to manually reconnect the wire and it will work for maybe a day or two.
I turned off the gadget and my wifi has been working for weeks without issue.
PostPosted: Thu May 30, 2013 8:08 pm
tried this gadget also cant get it to load. how long does it take to work, instant or a few mins? also i have 2 different ip addresses, i have my network ip then i have the RA ip which one do i use?
PostPosted: Fri May 31, 2013 5:34 am
It takes some time. I walked away from my computer and came back sometime later and it was working.
PostPosted: Thu Jun 06, 2013 4:34 am
very Good Thread. Yet i have no interest in Develop but i like your gadgets and there themes very much.
PostPosted: Sat Jun 14, 2014 8:55 am
Any way to get Salinity added to the gadget?
54gal Corner Bowfront with 30gal basement sump
PostPosted: Sat Jun 14, 2014 9:13 am
I don't think the creator is really working on this anymore. I haven't seen an update in a while. As you cab see there hasn't been a post since last year.
Previous
Return to Apps
