New Windows Gadget
PostPosted: Mon May 07, 2012 3:20 pm
Hi,
I hope no one minds, but I have attached an updated version of the Gadget with the following changes.
1. The main window is 30 pixels taller so that the arrow is visible (at least on my screen).
2. The Flyout 2 window is also taller so that all the LEDs are visible.
3. I changed R0 to R1.
4. I bumped the revison to 1.0.1.0
Don
ReefAngelGadget.zip
zipped up .gadget file
(24.01 KiB) Downloaded 808 times
PostPosted: Mon May 07, 2012 3:24 pm
Sweet. I don't think anybody minds. :)
PostPosted: Thu Jul 12, 2012 4:12 pm
Can anyone confirm this is still working on libs 1.0.0?
PostPosted: Fri Jul 13, 2012 10:37 am
Nevermind. I just confirmed it is working.
PostPosted: Mon Aug 20, 2012 9:32 pm
Do I have to add some sort of code?
I am not able to get this to work.
Adam
58 Gal
PostPosted: Mon Aug 20, 2012 10:50 pm
I'm assuming you have the wifi attachment working, right?
Then, on Reefangel IP address, you have to make sure you add http:// in front of it and :2000 after it.
Like this: http://ipaddress:2000
PostPosted: Tue Aug 21, 2012 7:53 pm
Portal works, Android app works,
but not the windows gadget.
using same address
Adam
58 Gal
PostPosted: Tue Aug 21, 2012 8:31 pm
Can you browse to your controller when you type http://ipaddress:2000 in your browser address?
You should see "Reef Angel Controller Web Server"
Copy the address that your browser is showing and paste it in the gadget address
PostPosted: Wed Aug 22, 2012 6:12 am
I get the Reef Angel controller web server,
still nothing on the widget.
Adam
58 Gal
PostPosted: Wed Aug 22, 2012 7:58 am
Weird.
Are you using the version posted on this page?
Here is how mine looks.
PreviousNext
Return to Apps
