iPhone app shows current readings, but no control
Re: iPhone app shows current readings, but no control
hmmm yeah its showing closed ........ stupid motorola, the settings are right i swear!!
for sanity sake, does this look right?
CMD
get ip
IF=UP
DHCP=ON
IP=192.168.10.5:2000
NM=255.255.255.0
GW=192.168.10.1
HOST=69.198.171.165:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<2.35> ???vk????j??=helloworld
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=MYPASSPHRASE
<2.35> get u
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
<2.35> GET /r99 HTTP/1.1
Host: 192.168.10.5:2000
Yeap. Looks correct.
Do you happen to have 2 routers?
Or maybe one modem and one router?
its one of those motorola surfboards - cable modem and router in the same device......
Is it wifi too?
All-in-one?
All-in-one?
yup - all in one.........
AHA - i figured it out...
on my unit, in port forwarding I can select "both" "tcp" or "udp" as a forwarding option.... apparently, when set to both, that is no good
setting it to TCP fixed the issue
