Client Suite 2.1
Re: Client Suite 2.1
I think Dave ran into this before. I think his next release will address the Globalization of the Client,
Im sure he could explain it to you more.
This is what stands out to me:
Could not load file or assembly 'System.Core, Version=3.5.0.0,
It looks like you're missing some of the .Net framework 3.5 stuff.. That's interesting, because the application directly targets the 3.5 framework and the installer has a pre-requisite check on it to make sure it's installed, and if not it will prompt you to d/l it.. at least it should..
I would have thought the Client screen wouldn't even open without required references.
Are you running Windows XP or WIndows Vista/7?
I have an issue when I try to connect to the RA web Page, The web page is showing up but it stay on "Loading Please wait" and when I try a refresh the web page can't be found anymore after that refresh. I have to close my browser to get the web page again.
do you have any idea??
thx
thx
Salt Water Aquarium 60*60*60
IIRC, didn't the issue have something to do with a javascript error? I thought after inspecting the web page for errors, there was a problem serving up the first instance of Document.GetElementById("..?")
Does that sound familiar?
Wifi OR USB = #define wifi
so wifi has to be enabled even if you're not using the wifi adapter and just using usb?
You will have to excuse my newbiness but I just got my RA today and I'm trying to set everything up.
The basic Arduino install went well (tested by rewritting the demo code, flawless). I then installed RAGen, the latest from Curt with the Dev Library. Seems to be working well, can find my RA on COM7 (Wifi module will be coming soon).
Here's where the problem begin. I tried installing Client Suite many times (and uninstalled/reinstalled the other 2) and the installation does go through. However, I cannot start Client Suite, it crashes immediately (I'm on WIndows 7 64). For some reasons I managed to start it up once but it never restarted properly. Once I have it installed, if I try to "locate controller" in RAGen I get an error and it crashes. So the issue is definitly with one of the active processes (logger or listener). After uninstalling Client Suite, RAGen seems to be back to normal.
I know this is really vague info but all I'm getting is also a very vague error. Any ideas on what to do ?
The Client Suite works great with Win7 64bit (I've used it on my laptop and so has Dave).astralmind wrote: Here's where the problem begin. I tried installing Client Suite many times (and uninstalled/reinstalled the other 2) and the installation does go through. However, I cannot start Client Suite, it crashes immediately (I'm on WIndows 7 64). For some reasons I managed to start it up once but it never restarted properly. Once I have it installed, if I try to "locate controller" in RAGen I get an error and it crashes. So the issue is definitly with one of the active processes (logger or listener). After uninstalling Client Suite, RAGen seems to be back to normal.
The "Locate Controller" option you mentioned isn't really designed to used often. When it locates the RA, it ends up rebooting the controller (only way to tell for certain it is the RA). So if you are trying to use the Client Suite and the locate controller at the same time, then you can get errors. If you know you have your controller connected, then I would suggest not using the Locate Controller option. It was only put there to help ensure the computer can find the controller and it is part of a future idea / feature of the software.
Do you have Wifi Enabled on your controller through RAGen? Client Suite 2.1 requires wifi to be enabled (read the beginning of this thread). This is very important otherwise the Client Suite cannot connect to the controller and you cannot get any data.
Have you followed the instructions in the first post? I know this is probably a stupid question, but I'm going to ask because it can make a difference.
What version of the .NET Framework do you have installed?
Thanks for the quick reply. Well I guess the issue could be related to the Wifi no being enabled. I did check it within RAGen but did not upload any new code to the controller itself. So generating the basic pre selected options in RAGen with Wifi checked and uploading the code to the controller could fix the issue ? I didn't want to "mess up" the controller yet but I'm assuming the default RAGen info is similar to the demo code right ?binder wrote:
I find it odd that it crashes (I'll try to find the log in Windows to see exactly what happens). In fact in crashes in the same way with or without the RA connected to the PC. I tried running the various exe in "Compatibility mode" but that didn't help. I wonder how I managed to get Client Suite to boot once (even tested the email and SMS function)... then again it worked up until I clicked the "dashboard" option and then crashed.
Beyond that I followed the installation instruction and my .NET Framework should be up to date (also ran all possible updates before installing the RA softwares).
This is indeed the case. Enabled for wifi or USB.alexwbush wrote:Wifi OR USB = #define wifi
Hi astralmind,astralmind wrote: Thanks for the quick reply. Well I guess the issue could be related to the Wifi no being enabled. I did check it within RAGen but did not upload any new code to the controller itself. So generating the basic pre selected options in RAGen with Wifi checked and uploading the code to the controller could fix the issue ? I didn't want to "mess up" the controller yet but I'm assuming the default RAGen info is similar to the demo code right ?
I'm kind of leaning towards a dirty config file or a permission issue, perhaps. The ClientSuite.exe in itself does not require any elevated permissions, however the Service Dash does. When you pressed "Launch Service Dash" did Windows prompt you for permission to launch it or did it just crash right away? What happens when you try to launch the service dash by itself from Start Menu -> Programs -> ReefAngel Client Suite -> Service Dash?
Because the Listener and Logger services are independent of the main Client application, errors in either of those most likely won't effect the startup of the main application. Meaning if the Listener can't find the controller because it isn't plugged in or wifi isn't enabled, then it should just log it, and try again in a few minutes. The only way the services could effect the main client application, is if the client can't connect to the Listener for updates for whatever reason, but at that point it wouldn't matter if the controller is plugged in, what code is running on it, or if you even own a ReefAngel controller. The application should at least startup.
The Windows Event Viewer could provide some insight what's happening when the application starts up and crashes right away. Also there's a log file that will hopefully have some useful information in it to help us figure out what's going on. Can be found in C:\Users\YourUser\App Data\Roaming\ReefAngel\RAExceptionLog.log
The fact that you were able to run it successfully once makes me think your okay with the .NET framework requirements.
What I would do is the following:
make sure the ReefAngelListener and ReefAngelLogger services are stopped. Control Panel -> Admin tools -> Services then scroll down to those two services and make sure they're stopped or that the status is not "running". Then Uninstall the Client Suite from the control panel. Get everything squared away with RAGen and make sure you have the controller setup the way you like. Just make sure you have wifi enabled in RAGen. Once finished there, try reinstalling the Client Suite and hopefully you'll be okay. It sounds like you had a few things going at once between RAGen, the locator tool and the Client Suite which may have been too much.
Also, something to be mindful of is you can only have one connection open over USB to the controller at a time. Meaning once you get the Listener up and running, you won't be able to upload code anymore to the controller through Arduino until you stop the Listener Service through the RA Service Dash. Not that I think that this your problem, just mentioning it as something to be aware of. Running a bunch of programs/utilities that are trying to talk to your controller over COM7 at the same time won't work out nicely.
Thanks for all that info Dave. I've followed you recommendation closely and unfortunately, I am still running in the same issue. Clean uninstall and reinstall without the controller being connected (after all I just want to see if the Client Suite crashes or not at this point).
Client Suite crashes instantly ("ReefAngelClient as stopped working" blablabla)
DashBoard asks for admin rights and then crashes.
The other exe, Serial reader asks for admin rights and run properly without any issues.
I looked up the log file and it's empty.
According to Windows event viewer the Logger and Listener services started and stopped sucessfully many times. No traces of the dashboard crashing or the Client Suite itself. All fresh and clean installs. This is really odd.
hmmm..astralmind wrote:Thanks for all that info Dave. I've followed you recommendation closely and unfortunately, I am still running in the same issue. Clean uninstall and reinstall without the controller being connected (after all I just want to see if the Client Suite crashes or not at this point).
An empty event viewer and log file is pretty strange, also makes finding the problem that much harder. I'm sure you did but just throwing it out there, you looked in the "Application" section of the Event Viewer? Is there any other information that you are presented with when the Client crashes? What does the blah blah part say?
I have seen the immediate crash once or twice before in version 2.0 while testing. It was due to missing but required fields in the config files that I modified by hand and messed up. Both the Client and the Dash have one. After installing, did you move any files/folders around related the Client Suite? The installer should take care to make sure the config files are correct as of the installation.
Could you take a peek at the config files and make sure everything looks okay? Specifically the directory locations that are in there. They key names are "DBLocation" and "ServiceDashLocation" Make sure that they are pointing to files that actually exist in your installation. I would copy/paste the directory paths into an explorer window and remove the extra backlashes between folders and try to browse there. (You'll know what I mean when you see the file) There's no sensitive data in there, so if you could attach or email the config files for me I can have a look to make sure every is good and I'll also plop them in my installation and see what happens.
Client config:
C:\Users\YourName\AppData\Roaming\ReefAngel\Client\ReefAngelClient.exe.config
Service Dash Config:
C:\Program Files (x86)\ReefAngel\ReefAngel Client Suite\ServiceDash\Service Dashboard.exe.config
Also, please confirm your installation folder structure looks similar to this. Heres a screenshot showing all the files/directories that the client suite installs. This is to just ensure you have everything you need from the installer and its in the right place.
Wow thanks for all the effort!
I just double checked my file structure and location, they are identical to what you just posted. Also checked the config files, all mapping towards the proper install location. I've attached both my config files (in rar the forum would not accept .config it seems).
The log is empty with a last modified date of March 27 so yeah definitly untouched.
As for the Event Viewer I managed to find the entry (was working remotely from work earlier on). Still, not very explicative to me (see bellow). The Windows error message was a generic one the "blablabla" part was just Windows will look for a solution to resolve your issue etc.. I'm also attaching the detailed log to this post (txt). Let me know if I'm doing something wrong on my end.
Fault bucket 1947214054, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: reefangelclient.exe
P2: 1.1.0.0
P3: 4d8fb902
P4: mscorlib
P5: 2.0.0.0
P6: 4d4f14f6
P7: c43
P8: 59
P9: System.FormatException
P10:
C:\Users\astralmind\AppData\Local\Temp\WER18EC.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\astralmind\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_reefangelclient._cde52edf3f155f3f354e33b7713404f42695c7a_045e3004
Analysis symbol:
Rechecking for solution: 0
Report Id: 46093c87-7c16-11e0-b287-1c6f6593c603
Report Status: 0
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P2: 1.1.0.0
P3: 4d8fb902
P4: mscorlib
P5: 2.0.0.0
P6: 4d4f14f6
P7: c43
P8: 59
P10:
Analysis symbol:
Report Status: 0
- Windows Error REport.txt
- LOG
- (13.73 KiB) Downloaded 478 times
- Service Dashboard.rar
- (366 Bytes) Downloaded 465 times
- ReefAngelClient.rar
- (1.54 KiB) Downloaded 460 times
Not sure if it helps in anyways but the DashBoard generates a different error type:
Fault bucket , type 0
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P1: service dashboard.exe
P2: 1.1.0.0
P3: 4d8fb8ff
P4: Service Dashboard
P5: 1.1.0.0
P6: 4d8fb8ff
P7: 27
P8: 16a
P9: System.NullReferenceException
P10:
So RA Client is a FormatException while DashBoard is a Null Reference Exception... Googled the errors and didn't find much except maybe this: http://runtingsproper.blogspot.com/2010 ... r20r3.html
Ha and FYI, Windows wouldn't let me install RAGen in its default location (some permission I assume which I found odd as it was looking at the usual PRogram Files).. so I installed it elsewhere.
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P2: 1.1.0.0
P3: 4d8fb8ff
P5: 1.1.0.0
P6: 4d8fb8ff
P7: 27
P8: 16a
P10:
yeah, everything looks good. Your config file worked fine for me if I put in my correct locations for those two keys. So if you're sure those two keys mentioned above are good, then the problem is somewhere else.
This part sticks out:
We saw this error with some of the international users whose culture information was set to French and Italian. The problem was the application didn't handle their decimal separators correctly. So 8.20 in the U.S. looks like 8,20 in France I believe. Is your computer configured for U.S. / English or do you have another culture set?
The only other thing I can think of is some crappy data got into the database file somehow. After loading up the configuration file, the application will pull all the historical data that's been stored so far and graph it for you. It also loads up some user defined information to use later in the Settings screen. (Profile information, relay names, etc..) It could be that you entered some information on one of the Settings screens when you had it running the first time, and the application allowed you to store something it should not have. Maybe special characters or something?
I'm attaching a fresh copy of the database file for you to try out. Stop both services again. Replace your version of the ReefLogDB.sdf file with the one I attached. Just rename your original to something different but make sure not to rename the new one. Then try launching the Client one more time. You don't need to start the services, you can just keep them off for now. If that works, I might ask you to send me your original renamed sdf file to have a look at to see where the problem occurred.
C:\Users\YourName\AppData\Roaming\ReefAngel\ReefLogDB.sdf
Let me know how that works out.
- ReefLogDB.zip
- Fresh DB File
- (8.21 KiB) Downloaded 454 times
Well! Just solved part of the issue. My regional settings were French Canadian, switched to English US and got Client Suite to Work!
Unfortunately, the dashboard still crashes when I try to run it (after the admin permission is granted). Replacing the DB did not change anything though.
I can get the services to start manually though.. so is the dashboard access essential ?
Getting there!
Getting there!
Sweet irony, I installed everything on my rather old Toshiba R100 (running windows XP) and... I have no issues running the Dashboard but ClientSuite immediately crashes, same as it did on my WIndows 7 desktop except this time the Regional settings were properly set to ENglish US..
Here's the error log for that one:
Event Type: Error
Event Source: ReefAngelLogger
Event Category: None
Event ID: 0
Date: 5/11/2011
Time: 7:02:48 PM
User: N/A
Computer: TOSHIBA-35BDA03
Description:
Service cannot be started. System.IO.FileNotFoundException: Could not load file or assembly 'System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
File name: 'System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at LoggerService.RALogger..ctor()
at LoggerService.ReefAngelLogger.OnStart(String[] args)
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Error
Event ID: 0
Date: 5/11/2011
Time: 7:02:48 PM
User: N/A
Description:
Yeah, after thinking about it more, I remembered you said you uninstalled/reinstalled so that would have given you a fresh db file to start with. Of course that was a few mins after I posted and realized it probably wouldn't help, but figured what the heck, couldn't hurt
Well, looks like I have a bit more work to do with the localization part of the application. Glad you got it semi-working. I'm a little surprised that French Canadian culture settings don't work. Even stranger, work once and then stop. After working with Xender and all the issues he went through getting it running in France (FR-fr), I thought I had worked out the formatting issues so that it would at least run no matter the regional settings :/ I'll change my settings here to French Canadian and see exactly what's going on and hopefully have a more permanent fix for you soon. You definitely shouldn't have to keep your regional settings changed. If we're lucky, the dashboard issue is related also.
Also, no the dashboard isn't essential. It's just a quick way to access those two individual services running in Windows. If you're cool with manually toggling them for the time being then you should be good. It also lets you change the IP/COM settings if you need to. Most of the time, though those settings very rarely change if ever.
As for the Toshiba, umm...I would say it's too far away from the equator or maybe SkyNet has control? haha not sure, sorry
edit^^ Maybe update .net framework on laptop to 3.5.. ?
haha not a big loss on the laptop just curious why it wouldn't work though. .Net is up to date on it Proper regional settings and good old Windows XP up to date too.. odd. Ha well, once I get the Wifi module I won't care about that laptop anyways. Thanks for help, much appreciated. I'll be following the dev closely... who knows, maybe the next release will magically cure the Dashboard glitch (altough I am in English US now.. and it still crashes).
ahh crap. I think I found the problem.
I uploaded the localized code to github ~6 weeks ago, but I didn't tag it, nor is the latest version a "package download". It was just kind of a "hot fix" committed to source only since the only thing that changed was a culture invariant way of reading numbers. Just a couple lines of code and I did a pretty poor job of French translations on the UI if it detects a French culture. I'm sure you'll notice my bad translations if you install it with Windows set to French.
Anyway, so the only way to get it is to download the "source" as a zip. You can't rely on the tags or the package that says "Beta 2.1".. Whoops ><
here's the link to the direct download of the source installer that you need for localized setup outside the U.S. I just tested it with my Win 7 x64 set to French Canadian and everything worked fine, even the service dash. The other version did not, giving me the same errors you saw.
Again, please stop both services manually. Fully exit the client (File -> Exit) and then uninstall the Suite. Promptly, and with a sense of authority and conviction, put the installer you d/l earlier in the Recycle Bin and give this one a shot...
https://github.com/davemolton/Client-Su ... all/master
You should be able to switch your culture back to Canadian. If you don't like the French translations on the Client you can exit the Client, delete the "fr" folder from C:\Users\YourName\AppData\Roaming\Client and restart the Client.
I do have better translations from Xender, just not uploaded yet.
Hopefully that works for you.
Hey Dave,
French now works but unfortunately, the dashboard still crash in the same way.
hmm, not sure what it could be. I just tested again on a third laptop - Vanilla Win7 x86 French Canadian Region settings with no issues. I wonder what the problem is.. I'll keep an eye out for anything weird happening in that utility. It's pretty small, so not too many places where the error can be coming from.astralmind wrote:Hey Dave,
I just did the update and am now having an issue.
My client says its connected but is not receiving any data. I then installed the new RAGen with the latest libraries and created a new file, uploaded it to the control just fine and it seems to be running just fine, but still no data. I have tried it with both WIFI selected and with it not selected to the same result.
Any thoughts on why the client isn't getting data when it says its connected?
Oh and I am using a USB connection.
layton, the "connected" message on the statusbar just means that the Client has successfully connected to the Listener Service. It doesn't mean the Listener has, or even can communicate with the controller. If you're connecting over USB, there's a few things you have to make sure of.
Inside the ReefAngel_Features.h file, make sure the "#define wifi" line exists is NOT commented out. #define wifi is needed no matter if you're connecting to the controller over wifi or usb.
In the ReefAngel Service Dash application, make sure the "wifi enabled" checkbox is not checked, and you have the correct COM port and baud rate entered. Should be the same COM Port selected in the Arduino IDE. Baud Rate should be 57600.
Make sure the Arduino IDE is not running as it might have a lock on the COM Port needed by the Listener service. Once IDE is closed, from the Service Dash, stop and then start the Listener service. Try opening the Client again and see if you can see the information coming in.
If all that fails, send me a copy of the error log file and I'll have a look to see if there's anything that can help us.
C:\Users\YourUser\AppData\Roaming\ReefAngel\RAExceptionLog.log
so far no luck.. one question though. Do I need to have the web banner selected for logging? when I do it, i am unable to compile the code so i haven't been using it.
Web Banner doesn't need to be selected for logging. Web Banner is when the client pushes the data to reefangel.com automatically for you. If you have this enabled, it will conflict with the Client Suite.laytonp wrote:so far no luck.. one question though. Do I need to have the web banner selected for logging? when I do it, i am unable to compile the code so i haven't been using it.
The Client Suite automatically downloads the data from the controller at it's specified interval. So as long as WIFI is enabled, the Client will handle the rest.
Ok I have left the WIFI enabled, but it doesn't seem to be sending anything out over the COM port, and I do have the correct one selected as I am able to upload to the controller. I am assuming that the controller isn't sending anything out as when I am in the Arduino software and monitor the COM port I don't get anything. Here is a copy of the code from RAGen.binder wrote:Web Banner doesn't need to be selected for logging. Web Banner is when the client pushes the data to reefangel.com automatically for you. If you have this enabled, it will conflict with the Client Suite.laytonp wrote:so far no luck.. one question though. Do I need to have the web banner selected for logging? when I do it, i am unable to compile the code so i haven't been using it.
http://laytonweaver.selfip.com/website/ ... 1_0952.pde
Thanks for the help. This is kind of frustrating as I got everything working on the first version of the software, now it doesn't want to cooperate.
The PDE file looks good.
What about the Client Suite LOG file that dave asked about? Can you post it for him to look at?
There have been some really odd issues with the Client Suite services, so having that will really be helpful.
Here is the log file.
http://laytonweaver.selfip.com/website/ ... ionLog.log
Thanks again.
Also I should mention that I am running Win XP Pro. Don't know if that helps at all
Thanks again.
Layton, thanks for the log file.
You have a lot of the same error in there. I'm surprised the Client says "Connected" in green at the bottom, yet you are seeing these kind of connection errors from the Client. Looks to me like it's trying to connect to the Listener service for updates but the service is denying the connection over and over again. There's a 2 minute countdown timer that kicks in before trying to reconnect after an error like this. You can kind of see that happening since many of the errors are strung together exactly 2 mins apart.
Anyway, the only thing I can think of is your firewall might be blocking the request/response between the two. Would you mind stopping the firewall then restarting the Listener/Logger services and client and seeing if that helps?
