Arduino on Linux
PostPosted: Wed Sep 19, 2012 4:22 pm
Linux Users.
This post will discuss how to use / run Arduino on a linux machine and make use of the Wizard, Library Version check and to Restore Preloaded Code.
These files contain the following software:
  • Arduino 1.0.1 (32 or 64bit) (modified for Reef Angel)
  • Reef Angel Libraries 1.1.1
  • Wizard 2.1.9
I have uploaded 32bit and 64bit versions of the Arduino app with the modifications to my website.
To install, make sure you have Java installed (openjdk java 6 runtime is fine).
  • Download either the 32bit (http://curtbinder.info/apps/ReefAngel-Arduino-v1.0.1-32bit.tar.gz) or 64bit (http://curtbinder.info/apps/ReefAngel-A ... bit.tar.gz) version of the Reef Angel modified Arduino.
  • Extract the tarball into your home directory. It should create a folder called ReefAngel.
  • Download the arduino libraries tarball. http://curtbinder.info/apps/arduino-libraries-1.1.1.tar.gz
  • Extract it to your home directory. It will create a folder called Arduino inside your home directory.
  • Open up the ReefAngel folder.
  • Double click on the arduino file. It will prompt to Run in Terminal, Display, Cancel or Run. You can choose Run. If you encounter problems, you should choose Run in Terminal to see more output. NOTE: If you are running Ubuntu 13.04, Nautilus behavior has changed and double clicking on a shell file (*.sh file) causes it to be opened in a Text Editor by default. To fix this, go to Nautilus > File menu > Preferences > Behavior, and change preferences there: set the item "Executable Text Files" either to "Run executable..." or to "Ask each time".
  • On first run, Arduino will prompt you for the folder to store your sketches. Select the Arduino folder.
    If it does not prompt you for the directory when Arduino starts up, you need to change the folder. To change the folder, goto the File menu and choose Preferences. Then click the Browse button next to the Sketchbook location. Change the folder to be "/home/USER/Arduino" where USER is your username.
You will now want to select your Reef Angel from the Tools menu and then Board. Most people will use either Reef Angel Controller w/ optiboot OR Reef Angel Plus Controller.
Lastly, you will need to choose what Serial Port to use to communicate with the controller. This port can change at times but will most likely be /dev/ttyUSB0 for the 1st USB device. If arduino cannot communicate with the proper port, it will notify you and prompt you to change it.
This will allow you to run arduino on linux and make use of the wizard and functionality. I have tested this on the following systems:
  • Xubuntu 14.04.2 LTS 64bit
  • Ubuntu 10.04 LTS 32bit
  • Ubuntu 12.04.1 LTS 64bit
  • Ubuntu 12.10 64bit
  • Ubuntu 13.04 64bit
If you are looking for the older version. Here are those files:
1.0.9 Libraries
Pre 1.0.9 Libraries
Let me know if you have any questions. :geek:
PostPosted: Wed Sep 19, 2012 11:18 pm
Thank You!
PostPosted: Thu Sep 20, 2012 5:38 am
Awesome, thanks for this!
One thing to note so far. If you are trying to run arduino as your normal login user and not root, you probably will notice the Serial Port option is grayed out. This is due to permissions on the device.
Plug up the usb-ttl cable, sudo to root and run ls -l /dev/ttyUSB0:
ag@aglaptop:~/ReefAngel$ sudo ls -l /dev/ttyUSB0
[sudo] password for ag:
crw-rw---- 1 root dialout 188, 0 Sep 20 08:25 /dev/ttyUSB0
You'll see my device is in the dialout group. So just add your normal login user (in my case ag) to the dialout group, reboot or logout/login and now you should have access to change the Serial Port.
PostPosted: Thu Sep 20, 2012 6:43 pm
Thanks for that tip. I didn't encounter that one myself but can understand possibly having to do that.
PostPosted: Thu Sep 20, 2012 6:52 pm
Sorry have to be a picky UNIX guy :) sudo is not needed to ls -l the USB device :)
It is needed though for adding the user to the dial out group which for those that don't know how, the command would be:
$ sudo useradd -G dialout lnevo
No reboot necessary, logout/login required (or relaunch terminal window if launching from a shell)
Lee
PostPosted: Thu Sep 20, 2012 6:55 pm
lnevo wrote:Sorry have to be a picky UNIX guy :) sudo is not needed to ls -l the USB device :)
# useradd -G dialout lnevo
Lee
lol. yeah that's how my system is setup. much easier to do that so you have access as needed and limit the use of the super user. :smile:
PostPosted: Thu Sep 20, 2012 7:21 pm
Lol forgot to add the necessary sudo for the useradd command...fixed :)
PostPosted: Thu Sep 20, 2012 7:36 pm
Thank you, Thank you, Thank you! It worked! I now have to buy a RA and play around with it. Very excited to be able to use it on Linux. Go Binder!
PostPosted: Wed Aug 21, 2013 6:53 am
Curt,
Any plans to update the linux version to use the new libraries and new wizard? Is it difficult to update? If you dont have time to update i'm happy to test for you with some gentle nudging in the right direction :)
PostPosted: Wed Aug 21, 2013 6:56 am
ishtak wrote:Curt,
I didn't even realize that the library version on it was "outdated". I don't believe it's too difficult to update. I will need to check with Roberto to make sure I grab the latest wizard and have the updated files setup. I might be able to get to it today or in the next upcoming days.
When I get something updated, I will let you know so you can test it out.
Next
Return to Apps
