Client Suite 3.0
Re: Client Suite 3.0
I though with the new Arduino is was supposed to update automatically. What is the best way to update? Thanks
Well when you launch the Reef Angel Installer (Arduino) it should update itself and pull down the latest libraries. You will still need to actually push the updated libraries to the controller through your USB cable.
I think the best way to get your controller updated would be to open the Reef Angel Installer (Arduino) and let it update itself and pull the latest libraries down from the internet.
From there you can run through the wizard built into the Reef Angel Installer (Tools -> Reef Angel Wizard) and generate a fresh Memory sketch and operating sketch and let the wizard upload them both to your controller.
The auto update only works on the new Installer. It started on version 1.0.0
If you are running older versions, the best solution is to download the new installer from their website
Sent from my Galaxy S3 using Tapatalk 2
Hi Guys,dmolton wrote:Thanks, Sebyte.
I think I see the issue. The Listener service validates that the internal memory locations from the controller match up with a defined set that the Client expects to see. This makes sure that we're displaying the correct values in the correct places on the Memory tab and also updating values in the right spot on your controller.
It looks like a new memory location (329=Mem_I_SalTempComp) was added since I last updated the Memory Map File and you happen to be running the libraries with the new location causing the validation to fail on the Client. This should be an easy fix.
Download the RAMemory.ini file attached to this post and save to your PC. From the Client, choose Settings => Load Memory File and browse to the file you just downloaded. You should get a success message. Restart the Client and try refreshing the memory tab once more.
-Dave
Just wanted to say thanks. I also ran into this issue. After comparing the error log posted and the one I had it appears to be the same issue. I went ahead and downloaded the RAMemory.ini file, uploaded it via the client, and restarted. Only thing I noticed different is when I first started the client program after doing this it actually crashed. I went ahead and restarted it and it appears to be fine now.
Appears to be working fine. Thanks again.
-scottf
FYI - here is my log:
*****11/30/2012 1:35:42 PM*****
Message:
Index was outside the bounds of the array.
StackTrace:
at ReefAngelWCFListener.ReefAngelListener.GetAllMemoryValuesPost10(String[] locations)
Message:
Value cannot be null.
Parameter name: String
StackTrace:
Hi Dave,
Bug report:
There is just one memory location for ATO timeout now.
It's memory location ATOExtendedTimeout (276)
All functions use this location.
Bug report:
Got it - thanks for the heads up. So the location 278=Mem_I_ATOHighExtendedTimeout is no longer being used for anything? I'll update the Memory tab on the main page to have just one numeric up down control for location 276 as well as the little memory utility.
Correct...
These are no longer being used:
#define Mem_B_ATOTimeout VarsStart+30
#define Mem_B_ATOHighTimeout VarsStart+42
#define Mem_I_ATOHighExtendedTimeout VarsStart+78
They are still there, just not being used by any function.
Also, the Portal doesn't use the MH schedule nor the Wizard generate any code with the MH schedule.
Should we make it consistent to avoid confusion?
I changed it to use offset from standard light function, instead.
All ok for almost 1 month, this mornig my pc restarts and then....
I'm using last lib version
*****17/12/2012 11.32.33*****
Message:
There was an error parsing the query. [ Token line number = 3,Token line offset = 24,Token in error = 5 ]
StackTrace:
in System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
in System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
in System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
in System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
in ReefAngelClient.DAO.DataAccess.ExecuteNonQuery(String query)
Message:
There was an error parsing the query. [ Token line number = 3,Token line offset = 23,Token in error = 5 ]
StackTrace:
Uploaded with ImageShack.us
Message:
StackTrace:
Message:
StackTrace:
Stephy
on the client it shows my led% and if you click on it you can change the %s but i never updates on the leds.....they just stay the same. do i need to add something to my code to be able to adjust my led bluw:white %s?
Here is what you do:
I see you use Port1 and Port2 for your LED drivers...
Modify your code to have Port1Bit and Port2Bit in the ReefAngel.LightsOnPorts
Like this:
Now, everytime you override those ports on, you will be able to use the client to adjust the LED %.
Like this:
man roberto you are the man thank you
after installing the ini file i got this error..
*****1/19/2013 7:56:48 AM*****
Message:
StackTrace:
at System.Int32.Parse(String s)
Message:
StackTrace:
Just pushed a new release (3.0.1) which is ready to download. This release addresses minor UI inconsistencies between the Client and the RA Wizard. Mainly deprecated ATO memory values and MH settings. In addition it should resolve an issue with the Notification Service that stopped it from pushing data to the Portal while connected via USB. The first post of this thread includes the full changelog and the download link has been updated accordingly.
-Dave
-Dave
Thanks, Got it working now.
Arnee.
Arnee.
Can the listener service app config be edited to change the polling frequency?
Scratch that, after looking closer I see the listener is real time. How do I change the logging frequency in the client app? It is updating every 3 min but sometimes every 4min so I'm assuming it's logging around every 3.1 min.
Dave,
Is there any chance of getting the latest source too listener & Logger?
Thanx,
Michael
Thanx,
Michael
Dave, will you be supporting the ph expansion, the salinity expansion units any time soon? Love your product!
Also, how do I use the min, max, and average temp values shown on the pictures? Thx
Is there anyway to see the value of my water level at certain intervals? or when a specific relay is turned on? I use the water level instead of the ATO switches and would like too see when and how often it reaches the high/low thresholds I set. If it is being log in a memory file, where can I access that? It would be awesome to graph the WL %
JP
JP
The live parameters get updated 15 seconds on screen (Temp, PH, ATO, Relays etc...). The chart will get updated every 3 minutes if you're viewing the Live (24hr) view of the chart or grid. Parameters will get stored in the database every 6 minutes. I believe data will be pushed to the portal every 5 minutes. Some of these used to be configurable but that option was removed to avoid errors when setting the timespan too low.smoothdog wrote:Can the listener service app config be edited to change the polling frequency?
How often were you looking to poll?
I'm finishing up a new API to communicate with the controller/portal that I'm using in the Store App. The source code and .dll will be available on github shortly.ibmlmjm wrote:Dave,
Thanx,
Michael
Thanks, Ross. Salinity is already supported - have a look at the General Tab in settings to enable it. This is also where you get the min/max/avg calculations. Check the "Display aggregate values" checkbox in that tab also. I'll work on getting the pH expansion working as well!rossbryant1956 wrote:Dave, will you be supporting the ph expansion, the salinity expansion units any time soon? Love your product!
I recently received and hooked up a water level sensor as well and already have a rough implementation of it in the desktop client. SMS/Email notification alerts need to implemented for water level, salinity and the pH expansion as well.jtomasi wrote:Is there anyway to see the value of my water level at certain intervals? or when a specific relay is turned on? I use the water level instead of the ATO switches and would like too see when and how often it reaches the high/low thresholds I set. If it is being log in a memory file, where can I access that? It would be awesome to graph the WL %
JP
Water Level/ Salinity on the Client:
Im getting "Error 1920" during install at starting services.
Paulturner911 wrote:Im getting "Error 1920" during install at starting services.
Is there any more to the message other than Error 1920? Can you confirm you have the .Net Framework 4.0 installed? What version of Windows?
I do have .net 4, Im on XP. Its a list of errors...probably not your problem. I managed to get it installed and then reads cannot open because it is configured incorrectly. Do you have an email address you could pm me so that I could send you a picture of the error?
Question on the Client Suite v3.0.
Does it still support adjusting the PWM percentage?
I believe that the earlier version allowed you to adjust it via the sliders. This one does too, but it never actually changes. It displays the precentage but then goes back to the current settings via the controller. No matter what I do, it stays.
I was trying to get the color ration set because I think the LED's are a bit too blue.
It does, as long as you override the port that was selected as lights on.
So, for example your code has a line like this:
If you override port 2 to always on, you can use the sliders.
ReefAngel.LightsOnPorts = Port2Bit;
Hi, and thanks for the reply. I don't recall changing that but I went ahead and pulled up a sketch and see it is set to 0.
The next question is how do I know that is the sketch that is loaded? Is there anyway to tell on the actuall device?
Thanks again.
Thanks again.
Hi Rimai,
I tried setting the Port2Bit as you suggested but it still isn't doing the trick and allowing me to adjust the lighting per the client. In fact, I'm not even sure the client is pulling the correct memory settings oddly enough. I know it is working but maybe I don't have it configured correctly. Everything is working as it should though as my lights come on, off via PWM as I set. I even tested it this morning by changing the start time from 10 to 7.
Not sure if I can post the code, but I will try:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 880 );
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port4,07,0,22,30 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,20,0,1,100,1) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,21,0,1,90,1) );
ReefAngel.Portal( "saf1" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, ReefAngel.Params.PHExp );
int x,y;
// pH Expansion
Ok, the code looks good.
Now, on the client, override port 2 to always on instead of auto.
Does it change now?
Does it change now?
