Client Suite 3.0
Re: Client Suite 3.0
Ok, that did the trick. Thanks. I figured there was something that I wasn't doing. Even though it was on, it wasn't set to always like you pointed out.
Thank you much. Appreciate the help.
This is the error I am getting trying to run the program. I can run the dashboard and listener will run, logger will run, but when I switch notifier on, logger will stop.
- error.jpg (181.45 KiB) Viewed 8503 times
I've been getting this since the library upgrade:
Any thoughts?
Any thoughts?
Yeah, we need Dave to fix the Client...
It happened before:
http://forum.reefangel.com/viewtopic.php?p=16602#p16602
Everytime there is an internal memory added, it's going to break the Client.
I think this new file may fix it...
Want to try it?
It happened before:
Want to try it?
- RAMemory.ini
- (3.32 KiB) Downloaded 527 times
Seems to have fixed it. I had to exit out and restart after I loaded the memory file.
Thanks, Roberto!
Thanks, Roberto!
Anyone wanna chime in on my error?
Next time this is updated, can we add the ability to see the expansion modules?
ie: ph expan, orp, water level, etc?
and all be part of the graphs?
and maybe have the ability to separate them all?
Adam
58 Gal
58 Gal
@Paulturner911:
It seems to be usually related to the VC++ redistributable... I imagine the installer ensures that you have the right one though. (Perhaps it doesn't, or maybe if it used to work you have installed something that changed the version of the library you had...)
Maybe try reinstalling the client?
Otherwise I think you'll have to wait for the author or someone else familiar with .Net programming to respond... I won't touch that stuff
Current setup:
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
Coralife skimmer
For v1.0.7, you need this new ini file.
- RAMemory.ini
- (3.34 KiB) Downloaded 553 times
save this file where?
Put it anywhere. Open up ReefAngel Client, go to Settings, then Load Memory File. Navigate to the settings file you just saved and it will load it up.rossbryant1956 wrote:save this file where?
A few posts back, Dave explains what to do with it:
Wherever on your computer.Then go Setting and Memory file and brows to where you saved the file.
Maybe it will work for you, it didn't for me.
Good luck.
Good luck.
Be sure to close out the program and restart it after you load the memory file.Bogdan wrote:Wherever on your computer.Then go Setting and Memory file and brows to where you saved the file.
Good luck.
Also, make sure you're using the correct memory file for your library version. There's a couple floating around.
I just installed it and got it working.
Great tool Dave Thanks.
The online settings don't seem to let me click in there and do anything.
Actually the "Send Parameters to Reef Angel Portal for online viewing".
I'm getting text & email notifications pretty much every hour saying "pH has reached defined low threshold of 7. The current pH is: x.xx" Usually around 6.0.
I've watched the portal pretty much all day yesterday and had it open at work all morning today and never saw it dip very far out of range. IE today it has stayed pretty much at 7.86.
Also yesterday when it was happening I would go to the client and look at the graph and there was no indication of anything that far out of line.
Are there known issues like this?
I also have notifications set up on the RA Portal and have received nothing except when I my sump fan turned on at noon and brought the water in the sump down to 74°. This is OK, because the light came on at that time to and will start heating up the water,
Hi,
Is can you set it to C temp reading?? My controller is in Celsius.
Tony
*** sorry i found it i looked straight at it and didn't see it***
Thanks for the application to its great.....
Tony
enigma32 wrote:@Paulturner911:
Id love to get this up and running. I have installed and uninstalled many times over on 2 different hardrives. One was XP with some jacked up mods which may have affected the .NET, so I tried on a virgin Vista, both show the same error. Anyone else have any troubleshooting I could try?
Problem was with the NET4 update....I had bought 1TB HD and started from scratch, works like a charm!! This thing is bad ass!!
after insatlling fresh new reef angel client suite
i cannot enter the memmory tab
i got the latest online version of libraries Controller is running dev libraries v.1.0.9
when it comes to programming i "always need help "
Download the RAMemory.ini file for the version of the libraries you are using. 1.1.0 is here:Redadeath wrote:after insatlling fresh new reef angel client suite
http://forum.reefangel.com/viewtopic.php?p=34019#p34019
Load the RAMemory.ini file you just downloaded in the RAClient. In RAClient, click Settings, Load Memory File, and select the RAmemory.ini file.
Close the RAClient and open it again. Check to see if you can read memory.
Im getting that same error and have tried on different machines with clean installs. seems ill never get this working.Paulturner911 wrote:This is the error I am getting trying to run the program. I can run the dashboard and listener will run, logger will run, but when I switch notifier on, logger will stop.
Does anyone know what is going on with the .Net stuff?
Okay why cant I see the refresh button anymore under memory. I can connect just fine but I cant scroll down to hit the refresh button. Ive tried everything all the way down to changing screen resolution.... Please help about to throw computer across room. All my tank parameters are showing so I know Im connected.
For v1.0.9 libs, you need this one.
- RAMemory.ini
- (3.4 KiB) Downloaded 540 times
Is there a new RAMemory.ini for 1.1.0?rimai wrote:For v1.0.9 libs, you need this one.
Try this one...
- RAMemory.ini
- (3.82 KiB) Downloaded 517 times
My client has stopped working. After I re-install the client it works for a couple of hours then it stops.
Listener has stopped (logger and notifier are both running), and attempts to reconnect don't work.
When I look in settings my ip address/port username and key are all erased. I can't even see the ip/port details unless i choose usb then change back to wifi. If i re-enter my details I am unable to save.
Hi can you help me
My code:
*****2014-03-31 23:02:41*****
Message:
La référence d'objet n'est pas définie à une instance d'un objet.
StackTrace:
à ReefAngelWCFListener.ReefAngelListener.GetPortalLabels()
Message:
There was an error parsing the query. [ Token line number = 3,Token line offset = 25,Token in error = = ]
StackTrace:
à System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
à System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
à System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
à System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
à ReefAngelClient.DAO.DataAccess.ExecuteNonQuery(String query)
Message:
StackTrace:
Message:
StackTrace:
Message:
La valeur ne peut pas être null.
Nom du paramètre : String
StackTrace:
à System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
à System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
à ReefAngelClient.Form1.DisplayMemoryValues()
Christian
My code:
My errors.., Sorry my log is in french..#include <ReefAngel_Features.h>
//1 1ight
//2 light
//3 Heater
//4 Wp40
//5 ATO
//6 Skimmer
//7 Pompe Remonte
//8 Phosban
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port8Bit; // Ports toggled in Water Change Mode
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded
ReefAngel.OverheatShutoffPorts = Port3Bit; // Use T1 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port3,760,769 );
ReefAngel.StandardATO( Port5,7200 );
Message:
StackTrace:
Message:
StackTrace:
Message:
StackTrace:
Message:
StackTrace:
Message:
StackTrace:
Christian
