Client Suite 3.0
PostPosted: Mon Mar 31, 2014 8:50 pm
Thank you !
Everything is ok !!
PostPosted: Mon May 12, 2014 12:02 pm
Did something happen to my client? It just quit working today. Was working perfectly fine last night then this morning had a bunch of errors.
Uninstalled then reloaded it it still does not work.
Downloaded the client
Installed client
Loaded the .ini file with the memory load
Get this error when changing from Relay Box 1 to Box 2
Logger quit working
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Transitions.Transition.add(Object target, String strPropertyName, Object destinationValue)
   at ReefAngelClient.Form1.SpinActiveRelayBar(SpinRelay spin)
   at ReefAngelClient.Form1.btnScrollRelayUp_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.1022 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ReefAngelClient
    Assembly Version: 3.0.4768.39086
    Win32 Version: 3.0.4768.39086
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/ReefAngelClient.exe
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
DevExpress.Utils.v11.1
    Assembly Version: 11.1.10.0
    Win32 Version: 11.1.10.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Utils.v11.1.DLL
System.Windows.Forms.DataVisualization
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.5681
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.DataVisualization.DLL
System.ServiceModel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Core
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Runtime.Serialization
    Win32 Version: 4.0.30319.1016 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
DevExpress.XtraEditors.v11.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.XtraEditors.v11.1.DLL
DevExpress.Data.v11.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Data.v11.1.DLL
System.Configuration
    Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Data.SqlServerCe
    Win32 Version: 4.0.8876.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Data.SqlServerCe.DLL
System.Data
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Xml
    Win32 Version: 4.0.30319.1015 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ReefAngelException
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelException.DLL
System.EnterpriseServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Google.GData.Calendar
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Calendar.DLL
Google.GData.Client
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Client.DLL
System.Windows.Forms.Calendar35
    Assembly Version: 3.5.4568.30457
    Win32 Version: 3.5.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.Calendar35.DLL
AForge.Controls
    Assembly Version: 2.2.2.0
    Win32 Version: 2.2.2.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Controls.DLL
AForge.Video
    Assembly Version: 2.2.0.0
    Win32 Version: 2.2.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Video.DLL
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
SMDiagnostics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.DurableInstancing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
System.ServiceProcess
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.WorkflowServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.WorkflowServices/v4.0_4.0.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.ServiceModel.Discovery
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
System.ServiceModel.Activities
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activities/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activities.dll
System.ServiceModel.Routing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Routing/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Routing.dll
System.ServiceModel.Channels
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
System.IdentityModel
    Win32 Version: 4.0.30319.1001 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
ReefAngelCrypto
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelCrypto.DLL
Transitions
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Transitions.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PostPosted: Mon Oct 20, 2014 11:05 am
My Client is doing the same. Nothing shows up in my general settings and I get the error saying con not connect to listener service. And i've reloaded the memory.ini file.
PostPosted: Mon Oct 20, 2014 11:50 pm
Ok so I figured it out....un-install the client software and run regedit.Search for all reefangel registry settings. Delete only the ones for the client and re-install the software....works like a dream again.
PostPosted: Mon Nov 10, 2014 11:17 am
89delta wrote:Ok so I figured it out....un-install the client software and run regedit.Search for all reefangel registry settings. Delete only the ones for the client and re-install the software....works like a dream again.
Do you remember which files?
Tried this and regedit did not find any files. What search did you do in regedit to find the files?
PostPosted: Sun Dec 21, 2014 10:19 am
Two quick questions. 1, is there a 1.1.1 memory file?
Two, I added a ranet relay expansion today. Every time I try to switch to box 2 in clientsuite the program crashes. Any ideas?
PostPosted: Mon Dec 22, 2014 4:25 pm
This is for libraries 1.1.1
RAMemory.ini
(3.89 KiB) Downloaded 172 times
PostPosted: Mon Mar 23, 2015 12:18 am
got the client working with usb but when connected to wifi it not working
log file
*****3/23/2015 12:26:42 PM*****
Message:
There was an error parsing the query. [ Token line number = 3,Token line offset = 25,Token in error = = ]
StackTrace:
at System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
at System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
at System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
at System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
at ReefAngelClient.DAO.DataAccess.ExecuteNonQuery(String query)
*****3/23/2015 12:36:41 PM*****
Message:
Value cannot be null.
Parameter name: String
StackTrace:
PostPosted: Mon Mar 23, 2015 5:29 am
Did you update the INI file?
PostPosted: Mon Mar 23, 2015 8:23 am
no
Return to Apps
