hmm, works now. Apparently it either needed a restart or needed the libraries placed in another location... (I had to move them to ~/sketchbook/libraries instead of where I originally had them in place of the default arduino libraries folder)
*shrug*
Adruino is always a pain
For reference, this is a summary of everything I did:
1) Install pde.jar in [arduino directory]/lib/ overwriting the existing one
2) Install the contents of update.zip in ~/sketchbook/
3) Install the Wizard-2.1.3/Wizard (
https://github.com/reefangel/Wizard/tre ... 1.3/Wizard) folder in ~/sketchbook/tools/Wizard
4) git cloned the Libraries repo (
https://github.com/reefangel/Libraries) at ~/sketchbook/libraries
5) Unzipped the contents of RestorePreloaded-1.2.2.zip (
https://github.com/reefangel/RestorePre ... -1.2.2.zip) into ~/sketchbook/tools/RestorePreloaded
6) Unzipped the contents of RALibsVer-1.zip (
https://github.com/reefangel/RALibrarie ... sVer-1.zip) into ~/sketchbook/tools/RALibsVer
These appear to be the most recent versions of these various things as of 2013-05-01.
I was able to successfully run the wizard and build the resulting code.
RestorePreloaded throws an exception, but I could be misusing it (I simply clicked the link with an empty sketch open):
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at processing.app.Sketch.load(Sketch.java:171)
at processing.app.Sketch.<init>(Sketch.java:142)
at processing.app.Editor.handleOpenInternal(Editor.java:2161)
at processing.app.Base.handleOpenReplace(Base.java:619)
at com.reefangel.tool.RestorePreloaded.run(Unknown Source)
Thanks for your help!
I'll try and catch up with Curt over the next couple days to see if he does have a package that would simplify this for me.
