Did someone say iPhone app?
Re: Did someone say iPhone app?
Also, I uploaded the first and second builds to TestFlight. So you guys should be able to download, install and test.
Hey!
I've tested it this morning.
I don't get the datas temp (still empty)
It looks like I've got the same problem that I've got on th http web page also ("Please wait loading...")
But I can toggle On/Off my relays.
What's the blue button LED near toggle button? (Blue mask Auto, Green mask ON, Red mask Off ???)
Mine still in blue all the time.
Do we must need optiboot for having working Http server?
On http://curtbinder.dyndns.info:2000 it's working (I didn't touch the relay ^^) Need to set password autentification here for security !
The app bug when I lunch it with Wifi Off and my IP local (working with http://curtbinder.dyndns.info:2000). Looks like it's working when the Reef is responding.
Thanks !
Thanks !
Salt Water Aquarium 60*60*60
The values stay even when I retry my IP just after I tryed curt address. (There is no error sync message and the date refresh to the actual time).
Maybe you can put the date in red if there is no datas sync?
This is Curt infos :
Thanks for the feedback, I am working on alerts that will display if it cannot connect.
The blue led is actually a button that puts the relay back into Auto mode.
Do you have the 2 other temp probes connected?
my setup has all the latest fixes in it, so thats why some stuff works as expected on mine.
I only have 1 temp probe plugged in. I can plug in additional ones if needed.
Just ordered my wifi module and an additional temp sensor. Now I will be able to use the app on my own tank.
please push your fixes then curt
Soon. Im waiting on confirmation of some features plus i have to write a guide for the custom menu. Hopefully i will have it released this weekend barring any complications.Xender wrote:please push your fixes then curt
Uploaded latest build to TestFlight.
*Added alerts for when unable to connect or download data.
*Removed feedback button which caused crash
*Fixed bug so app does not crash when switching multiple relays quickly
*Fixed bug so exp relay shows without having to refresh
If anyone wants to create any new loading screens or interface feel free, I am terrible with graphics.
Here is what it currently looks like:
Awesome!!
What type of file do you need for the logo?
Can it render vector type of files?
When you change tab from settings to tank for example, it tale long time because of the datas check. Can you change tab before checking datas? The app looks like it crash therefor
This is great work guys, how would you put the application on your Iphone through SSH?
Here are the guidelines for the icon. I am pretty sure vector files will work.rimai wrote:Awesome!!
http://developer.apple.com/library/ios/ ... mages.html
If you make one 512x512, we can just use http://iconswitch.me/ to create all the other icon sizes.
When do you think we can get it on the app store? I'm waiting till then.
Was this on the version I uploaded last night? The first build had a bug that caused it to download the data 3 times before displaying which caused a big delay. One the newer build using Curts dev box mine updates in a split second on wifi or 3g.Xender wrote:When you change tab from settings to tank for example, it tale long time because of the datas check. Can you change tab before checking datas? The app looks like it crash therefor
Will probably submit this weekend for approval. Usually takes a couple days after that to get approved. You can sign up for the TestFlight site or I would just need your UUID for your device and I can email you the .ipa to install.Chris wrote:When do you think we can get it on the app store? I'm waiting till then.
Can't wait. I can only see my r/a on wifi and that's at home so be good to keep watch when I'm at work or out. Good work.
Here it is.
I hope this helps.
I hope this helps.
- ReefAngel-Logo-512x512.png (20.94 KiB) Viewed 6075 times
icon looks great, thanks.
We may have to scrap the loading screen since Apple is not too fond of them. But we will see. Got anything for that? Size should be 640x960. My current one looks a little grainy on the iPhone 4.
got my wifi module in today and uploaded a new build to testflight. Let me know if there are any issues so we can fix before submitting to apple.
How about this one?
- ReefAngel-Splash-640x968.png (77.04 KiB) Viewed 6035 times
rimai wrote:How about this one?
wow, looks great, will add it in tonight.
So bad I can't test it until I've got the librairies fixes push for http errors
Can you get to the /r99 page for your controller? that should be all you need. the /wifi page is not needed.
Just released. Enjoy.Xender wrote:So bad I can't test it until I've got the librairies fixes push for http errors
Cool !!! Thanks !!!
Yes! It's working with .17
App has been submitted to Apple, should take less than a week to hear something back.
Seriously nice work, Wolfador. I'm glad this is finally released to the public and you did a terrific job with picking up the slack and making a polished app. Will definitely give it a download once it's available.
Just wanted to throw out a couple more features that would be cool to have in case you got bored..
-Some type of graphing capability would be cool..
-Maybe provide a way to set a limited number of internal memory values (Dim%, on/off light times, wavemaker intervals etc..)
-ATO status.
Congrats on the release,
-Dave
-ATO status.
-Dave
We need authentification also in the settings.
good job!
good job!
