Did someone say iPhone app?
Re: Did someone say iPhone app?
lnevo wrote: Curt, i wouldn't discount any possible relation also a lot of reports about ph probes...maybe some underlying timing change be affecting?
It's hard to say. I'll just keep an eye on things and see what all comes about.
Just to add to the confusion. Upgraded from iOS 5.1.1 to 6.1.3 and I experience 50% less crashes (approx) than before. Now that's just odd...
So, here's the error that popped up in the simulator when I tried it. Crashed immediately...
Entity: line 1: parser error : Premature end of data in tag RA line 1
><C4>43</C4><C5>4</C5><C6>9</C6><C7>0</C7><RFM>11</RFM><RFS>33</RFS><RFD>0</RFD>
Entity: line 1: parser error : Extra content at the end of the document
<RFW>0</RFW><RFRB>0</RFRB><RFR>0</RFR><RFG>0</RFG><RFB>0</RFB><RFI>0</RFI><RFWO>
This line is the one generating the error
        paramArray = [xmlParser fromXml:self.response withObject:raParam];
So it's definitely something in the xmlParser class that is doing it... reviewing that code next..
Have you tried to increase the flush size on the wifi attachment?
I post somewhere in the last couple days.
No can you post again and I'll try
I didnt see anything in the ios code restricting how much data to read etc...
I'm curious to know what you have right now.
So before you change, grab the "get e" dump.
http://forum.reefangel.com/viewtopic.php?p=29662#p29662
It was 450. Now it's 1420.
That was it... no more issues. So not a code problem... whew :)
Curt, can we get the current version submitted now :) Can't wait for my fixes to be in place :D
Awesome!!!
Yeah, 450 was enough for when we started and now we have so much info packed into the XML data that we need more room in the TCP packet :)
Both Android and iPhone seem not to like the fragmented packet.
Internet browsers and the Portal don't mind it though.
So this correlates with the android timeout then also?
Not the timeout. Android doesn't crash. It reports SAX parser error.
lnevo wrote:It was 450. Now it's 1420.
I am in the process of figuring out how to go about that process plus differentiating between this newer version and the existing version.
Sent from my iPad
Poiromaniax
Post by Poiromaniax »
Well my ios "training" has been out on hold, so I hope someone has managed to fix ios 7 issues :p otherwise the app will be redundant soon enough :( :(
redundant? i think you mean obsolete..
We still have until the fall before iOS 7 is going to be widespread. I'm 100% sure that most of the issues will be resolved when a release candidate comes out for iOS 7. Until then I wouldn't worry too much. My brother is doing the beta for iOS 7 and apparently many apps are broken. Apple won't release it if it breaks a lot of their 1billion apps on the app store...
Poiromaniax
lnevo wrote:redundant? i think you mean obsolete..
Lol, yes that's what I meant.
I really really hope so and that Apple aren't just relying on Devs to update their apps with ios 7 compatibility.
I seem to recall something similar with ios 6, a lot of apps would randomly crash until they were updated
iiluisii
Post by iiluisii »
What is going on with the iPhone app now it stuck on updating I deleted the app and download it again and same issue.
Did you change the flush size on your wifi module?
romebaby
Post by romebaby »
Anyone else getting some weirdness in iOS 7? Temp reading works about every other refresh as do the on/off status bars on the outlets.
Yes its broken. No ETA.
Correct. No ETA. I'm looking at the code now and just trying to follow along with it. It's a little confusing to a non-ios programmer. Regardless, when the app is updated, unless wolfador updates it (which is doubtful), the app will be released under a different signature.
Curt just curious if the problem is still present when compiled under Xcode 5? If so... carry on with the troubleshooting...
lnevo wrote:Curt just curious if the problem is still present when compiled under Xcode 5? If so... carry on with the troubleshooting...
yeah, there's still more problems.
some stuff that it breaks on doesn't make sense to me right now.
label downloading is broken. I think xml parsing for everything is broken.
so im trying to follow through everything and see what i can come up with.
Sent from my Nexus 7
Ok, just to give everybody a status update on the app...
The existing/current app is confusing and poorly designed (sorry for all that were involved). Things changed with iOS7. Lots of existing libraries and addons were broken and not updated. One specifically that comes to mind is the XML parsing.
Since the app is pretty broken and tough to track down all the problems and follow along, I'm creating a new app specifically for iOS7 and later. It will initially be stripped down to the basics (which isn't much deviated from the existing app). I have updated the internal workings of the app and made it more modular (following along with my android app). I have XML parsing working currently (but not all elements are saved, still have to get that going but I've got the data being pulled down). The way I'm handling it should not break any time in the future unless Apple breaks their own XML parsing utilities.
Once I get the rest of the XML data being saved, I will have to get the first relay box data being displayed, then toggling relays and saving settings. I'm hoping to have this stuff completed by the end of the week and have it submitted to iTunes Store. It will initially be only targeted at the iPhone and run on the iPad in compatibility mode.
I ask that everyone continue to bear with me during this process as iOS programming is new to me and my time is limited. Hopefully things will come through pretty quickly.
Robert1969
Post by Robert1969 »
Thanks for the update. Really looking forward to using the app again
3rdson
Post by 3rdson »
This is very good news! I'm going through withdrawal badly!
Thank you for your efforts, I know it's a lot of work for you.
3rdson wrote:This is very good news! I'm going through withdrawal badly!
you're welcome. i know how important the app is on my android phone and it's definitely needed for the iphone.
I've made some progress but not as much as I would like. I've got the app downloading the status from the controller and displaying any errors (connection, timeouts, parsing, etc). It's only displaying the main status and not the status of the relay boxes (yet). I've got it parsing the data, but not displaying the relay box data (that will require additional things to get the display to work properly and allowing for scrolling).
I have the main app settings stored in the main Settings app for iOS. This will be where you set the host, port and your portal username (this is not currently used, but it is configured).
Here's some pictures of my progress:
Main Screen
Main Screen
iOS Simulator Screen shot Oct 20, 2013 7.06.36 PM.png (723.34 KiB) Viewed 17077 times
Setting Section
Setting Section
iOS Simulator Screen shot Oct 20, 2013 7.07.58 PM.png (69.99 KiB) Viewed 17077 times
Settings
Settings
iOS Simulator Screen shot Oct 20, 2013 7.10.16 PM.png (47.39 KiB) Viewed 17077 times
When I release the app, I will be creating a new thread on here since it is a "new" app (meaning I didn't use any code from the existing app or even look at it closely).
What is everybody's opinion?? Do I release it now with the limited functionality so you can start using it or do you want to wait for me to get the main relay box working first (which I can't give you an eta on this)?
Release early release often! Hehe yes please! Looks awesome!!! Great job!
I like it :)
jjdezek
Post by jjdezek »
Release it. It's gotta be better then nothing.
