I setup my MP10wES last night. Since I removed the old pump on port 6 I'd like to plug my skimmer in it's place, however can I have the port delay start coming out of feeding and water change mode 5 minutes? I need time for the water level to settle.
Generating PDE w/ RAGen & using Reef Angel Client via USB
Re: Generating PDE w/ RAGen & using Reef Angel Client via US
Inside the loop() function you will want to add this line:
That will tell the controller that Port6 is on a 5 minute delay at startup and coming out of the feeding & water change modes.
ReefAngel.Relay.DelayedOn(Port6, 5);
Great, thanks Curt!
