My wife tells me on those moments that if it were a snake, I'd have been bitten... lol
I know that the problem is.
When you use the DosingPumpRepeat1, it will affect the timer that you are using for your wavemaker.
So, let just comment those out for now.
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
#define DosingPumpIntervalSetup
#define VersionMenu
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define Actinic 2
#define Refugium 3
#define DosingPump1 4
#define DosingPump2 5
#define Wavemaker1 6
#define Heater 7
#define Sump 8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ReefAngel.FeedingModePorts = B10100000; //Ports 6 & 8 turn off
ReefAngel.WaterChangePorts = B10100000; //Ports 6 & 8 turn off
ReefAngel.OverheatShutoffPorts = B00000011; //Ports 1 & 2 turn off
ReefAngel.LightsOnPorts = B00000011; //Ports 1 & 2 turn on
ReefAngel.Relay.On(Port8);
// Random Interval Wavemaker Port between 15 and 35 seconds
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
// Specific functions
// ReefAngel.DosingPumpRepeat1(Port4);
// ReefAngel.DosingPumpRepeat2(Port5);
ReefAngel.Relay.Toggle(Port6);
//Heater
ReefAngel.StandardHeater(Heater,775,779); // Setup Heater to turn on at 77.5F and off at 77.9F
//Lighting schedule
ReefAngel.MHLights(Daylight,9,0,17,0,0); //Daylight schedule 9:00am - 5:00pm with 0min cool down
ReefAngel.StandardLights(Actinic,7,0,19,0); //Actinic schedule 7:00am - 7:00pm
ReefAngel.StandardLights(Refugium,19,0,7,0); //Refugium schedule 7:00pm - 7:00am
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(7,00,22,0,0,50,60,ActinicPWMValue); //Actinic turn on at 7am, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(9,00,19,0,0,50,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
