Generating PDE w/ RAGen & using Reef Angel Client via USB
Re: Generating PDE w/ RAGen & using Reef Angel Client via US
The lighting schedule does, but I don't know what each value means in the following.
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
CheckCloud();
CheckCloud();
byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
So this will start the actinic at 7am at 0 PWM and ramp it up to 50 in what duration time? What about the reverse at dusk? What's byte oldValue for?
Sorry for all the questions. I really appreciate your help.
//byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(7,00,22,15,0,0,50,ActinicPWMValue);
DaylightPWMValue=PWMSlope(9,00,22,15,0,0,50,DaylightPWMValue);
CheckCloud();
No... Sorry...
If you look at the function, your code is doing this:
startHour=7
startMinute=0
endHour=22
endMinute=15
startPWM=0
endPWM=0
Duration=50
oldValue=ActinicPWMValue
The oldValue is always going to be the original variable you are using. It's just to return the same value in case it is outside the PWM slope window frame.
So, what you really want to do is this:
This will start at 7am and last for 60 minutes and ramp from 0 to 50. Then, it will start again at 9:15pm and last for 60 minutes and ramp from 50 to 0.
The PWM slope ios simetrical, which means the duration is the same for both up and down direction.
The end of the slope (10:15pm) is the time when the slopes ends, so mathematically, it will start 10:15pm minus 60 minutes (duration).
I hope this helps.
startHour=7
startMinute=0
endHour=22
endMinute=15
startPWM=0
endPWM=0
Duration=50
ActinicPWMValue=PWMSlope(7,00,22,15,0,50,60,ActinicPWMValue);
I hope this helps.
Helped a lot. I got it now. Thank you!
The wavemaker code was working last night. I don't recall making any changes to it, but it's not working today. I do recall pulling out what I thought was an extra "ReefAngel.ShowInterface();" last night. The port just stays on all the time. Any ideas?
By the way! I got the tank filled up last night and this morning the lights ramped up beautifully. I love the shimmer on the substrate from the LEDs. The tank just went through it's first lightning too. Caught be off guard while I was busy at work. Very cool!
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
#define DosingPumpIntervalSetup
#define VersionMenu
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define Actinic 2
#define Refugium 3
#define DosingPump1 4
#define DosingPump2 5
#define Wavemaker1 6
#define Heater 7
#define Sump 8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ReefAngel.FeedingModePorts = B10100000; //Ports 6 & 8 turn off
ReefAngel.WaterChangePorts = B10100000; //Ports 6 & 8 turn off
ReefAngel.OverheatShutoffPorts = B00000011; //Ports 1 & 2 turn off
ReefAngel.LightsOnPorts = B00000011; //Ports 1 & 2 turn on
ReefAngel.Relay.On(Port8);
// Random Interval Wavemaker Port between 15 and 35 seconds
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
// Specific functions
ReefAngel.MHLights(Port1);
ReefAngel.StandardLights(Port3);
ReefAngel.DosingPumpRepeat1(Port4);
ReefAngel.DosingPumpRepeat2(Port5);
ReefAngel.Relay.Toggle(Port6);
//Heater
ReefAngel.StandardHeater(Heater,775,779); // Setup Heater to turn on at 77.5F and off at 77.9F
//Lighting schedule
ReefAngel.MHLights(Daylight,9,0,17,0,0); //Daylight schedule 9:00am - 5:00pm with 0min cool down
ReefAngel.StandardLights(Actinic,7,0,19,0); //Actinic schedule 7:00am - 7:00pm
ReefAngel.StandardLights(Refugium,19,0,7,0); //Refugium schedule 7:00pm - 7:00am
ReefAngel.Relay.Write(); // Make relay changes effective
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(7,00,22,0,0,50,60,ActinicPWMValue); //Actinic turn on at 7am, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(9,00,19,0,0,50,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
I don't see anything wrong with the code.
I cleaned it up a bit, but nothing that would interfere with port6
#define VersionMenu
#define wifi
#define Daylight 1
#define Actinic 2
#define Refugium 3
#define Heater 7
#define Sump 8
//Heater
//Lighting schedule
CheckCloud();
void CheckCloud()
could happen.
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
I figured it wouldn't hurt to upload your cleaned up PDE. Still just stays on. I know it was cycling on and off last night.
Well. I pulled out the wavemaker code from my PDE, thinking the internal memory settings would take over for wavemaker1 on port 6, but they didn't. Is it because by default it's normally wavemaker2, and I only defined wavemaker1?
I tried removing both
and adding
But gives a compile error
// Wavemakers
ReefAngel.Wavemaker1(Port6);
I think I may have hit my limit for questions, huh?BioCube_14_Sketch.cpp: In function 'void loop()':
BioCube_14_Sketch:72: error: expected unqualified-id before numeric constant
BioCube_14_Sketch:72: error: expected `;' before numeric constant
Duh... sometimes I have some moments where I can't see what is in front of me.
My wife tells me on those moments that if it were a snake, I'd have been bitten... lol
I know that the problem is.
When you use the DosingPumpRepeat1, it will affect the timer that you are using for your wavemaker.
So, let just comment those out for now.
#define VersionMenu
#define wifi
#define Daylight 1
#define Actinic 2
#define Refugium 3
#define Heater 7
#define Sump 8
// ReefAngel.DosingPumpRepeat1(Port4);
// ReefAngel.DosingPumpRepeat2(Port5);
//Heater
//Lighting schedule
CheckCloud();
void CheckCloud()
could happen.
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
YES! That did it!! Thank you. I was about to go out and get the 1/4" tubing to hook up the dosing pumps and test those. I guess I have another hurdle to get those going then? I calibrated my pH probe today, and ready to start figuring out my 2 part schedule.
Cool.
Now that we got wavemaking out of the way, let's work on dosing.
I'll recommend you use the same code I use, due to the fact that it won't interfere with the timer you are already using.
The assumption is that you will have 24 doses throughout the day, one for every hour.
You can change the number of seconds you want to dose and the minutes to spread them more apart if you need to.
#define VersionMenu
#define wifi
#define Daylight 1
#define Actinic 2
#define Refugium 3
#define Heater 7
#define Sump 8
//Heater
//Lighting schedule
// Dosing pumps
if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<4) //Alk Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump1); //Turn Alk Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn Alk Doser off
if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<4) //CA Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump2); //Turn CA Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn CA Doser off
CheckCloud();
void CheckCloud()
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
cstart*=60;
cend*=60;
Thanks again Roberto, relays switch on the hour and, 5 minutes. Unfortunately I haven't been able to use them yet. The plugs for the dosers won't fit in the relay box. They overlap the plug next to them Can I turn the plug clockwise 90 degrees easily if I open up the relay box? I really don't want to get shorty extension cords to plug them in.
I also made my connector to use the actinic PWM channel for both my Actinic LED dimming and moonlights. I did something wrong with the code though, the moonlight value is not being set.
Any ideas? Thanks!!
if (hour()>19 && hour()<7)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 7:00pm - 7:00am
ActinicPWMValue=PWMSlope(7,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 7am, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(9,00,17,0,0,50,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
Try this:
if (hour()>19 || hour()<7)
Moonlights working
Had to move the outlets and my labels on the relay box around a little more, since the dosing pump plug and the refugium light plug can't be next to one another either.
Could I be done?
Thanks again for all your patience, quick responses and such a great product. Now to figure out why my canopy is running 20 degrees hotter than yesterday and the days before. Could the moonlights run that hot?
#define Sump 1
#define DosingPump2 2
#define Refugium 3
#define Daylight 4
#define Actinic 5
#define Heater 7
#define DosingPump1 8
You can move them around just like you did.
You should be fine on the moonlights. Just make sure you don't get too hot to melt the plastic, tough.
Good morning Roberto!
If I wanted my dosing pumps to run alternately on the even or odd hours, what's the best way to code that?
I'd like pump1 to run on even hours, and pump2 to run on the odd hours.
Thank you!
Thank you!
Try this:
if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<3) // 3 sec dosing on even hours
ReefAngel.Relay.On(DosingPump1); //Turn DosingPump1 Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn DosingPump1 Doser off
if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<3) // 3 sec dosing on odd hours
ReefAngel.Relay.On(DosingPump2); //Turn DosingPump2 Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn DosingPump2 Doser off
Thanks again!! BTW, I ordered a MP10wES last night, so I'm sure the RF module is in my future
I setup my MP10wES last night. Since I removed the old pump on port 6 I'd like to plug my skimmer in it's place, however can I have the port delay start coming out of feeding and water change mode 5 minutes? I need time for the water level to settle.
Inside the loop() function you will want to add this line:
That will tell the controller that Port6 is on a 5 minute delay at startup and coming out of the feeding & water change modes.
ReefAngel.Relay.DelayedOn(Port6, 5);
Great, thanks Curt!
