New APP / Portal
tpriscu
Re: New APP / Portal
Post by tpriscu »
Hi Guys,
Just curious if any headway has been made with this?
Upgraded my phone to ios7 before i knew there was a problem with the reef angel app and kicking myself in the butt now..
acabano
Post by acabano »
Hello, just upgraded my 4s to 5s. not knowing there is a compatibility issue with iOs7, looking forward for this New APP/ Portal development, thanks for the hard work/effort.
mikedizon
Post by mikedizon »
Me too cant wait. The more iphone apps maker the better. The more options the better for us. As long as it being updated.
Our iphone developer is lost and missing. I'll pay a fee if someone can find him :)
I started working on ios programming over the weekend. I'm getting a better understanding of it. hopefully i can have a new app created by the end of the week. yes, i said new app because the existing one is a big ball of duct tape and lots of extras that are most likely not needed. so some functionality may go away initially just to get the basics working again.
and yes, it would be built for ios7 and later only.
and yes, it will still be free... or maybe 99 cents.... not certain yet.
it will be iPhone only initially (or run in compatible mode on ipad).
Sent from my Nexus 7
poolman
Post by poolman »
Great news thanks Kurt, and I dont thing anyone will have a problem paying 99cents for an APP that works.
Cheers
Bryan
acabano
Post by acabano »
Hi Curt, thanks for the update, Looking forward. if you need a tester, i have a 4s with iOS7
Im still waiting for my 5s in preorder.
Arnee.
acabano wrote:Hi Curt, thanks for the update, Looking forward. if you need a tester, i have a 4s with iOS7
Arnee.
cool. I'm getting closer for the initial release. i don't have an iPhone but I have an ipad mini and ipad 3. like I said, I'm targeting iPhones first and then work from there. I will need feedback on the overall look and functionality of it.
JoelIreland
Post by JoelIreland »
Hey guys sorry for delay, had a couple of bugs to iron out but will be live wednesday.
davaraj
Post by davaraj »
JoelIreland wrote:Hey guys sorry for delay, had a couple of bugs to iron out but will be live wednesday.
That is wonderful news.
tpriscu
Post by tpriscu »
That is very good news. Looking forward to seeing it!
ryanmell
Post by ryanmell »
any news on the updated app release date?
mikedizon
Post by mikedizon »
Can't wait! More iphone apps for me to use. I collected many iphone / ipad apps
And Supported paying for the really nice ones. :D apps.
Can you check if this is good for you?
http://98.248.54.136:2000/json
It's in the latest dev branch.
Looks good to me, but I haven't tried to read it yet through ajax. I'll have to throw some code together later. Very cool though.
JoelIreland
Hey Roberto where do i find the JSON branch you added?
Use http://ipaddress:2000/json
You must have the RA+ to get json data output.
It won't fit in the standard RA :(
JoelIreland
Great that helps. Can we get it to return JSON when relays are switched etc? Thanks
Also it needs to have xml headers removed, the benefit of json is we can control the RA as a local device using its ip address. XML wont allow cross domain but JSON will. But jquery still detects it as XML.
You'd have to add the functionality similar to /r for /json shouldnt be that hard but keep in mind that rules out the ability to support standard ra.
Why not just take the xml and do a json encode?
JoelIreland
Because if you want to retrieve results direct from module via browser and javascript, it wont allow you to take xml from another domain hence why json would be allot better not just for web but mobile as well as has become the more popular format for developers.
Can you add to our issue tracking system on github?
JoelIreland
If you would like to have another crack at the beta version on myreefangel.com go ahead. I have fixed a few issues. The alerts will not be live yet. Any feedback will be much appreciated. If you select "Use Local IP" you can toggle relays if the RA is on the same network otherwise turn that feature off.
arch
Post by arch »
Looks terrific.
I'm accessing it remotely. It's creates gauges for each of my RA Portal parameters but is not loading current values - is this the way it should be behaving at this stage?
A couple of minor comments:
Under Settings > Dash Parameters
'Click the "Add Gauge" button to add more' should be 'Click the "Add Parameter" button' (or change the button label to "Add Gauge")
Navigation around the app is a little confusing because the page title and breadcrumbs for each settings page don't match the items in the sidebar. e.g clicking on Settings > Dash Parameters - brings up a page labelled "Display" and breadcrumbs are "Portal>Display page"
JoelIreland
Thanks for feedback. Yeah understand will work on those. I want to get out of Beta for new year. It wont replace iOS app but if we can get it to support all devices via browser, i think will be handy
I still get Loading... when I hit the dashboard. I've never seen anything past that...
iiluisii
Post by iiluisii »
Help I can not get it to connect
