Page 5 of 6
Re: iOS Reef Angel Status
Posted: Wed Jun 18, 2014 8:10 am
I have an apple dev account. Without it I can't deploy to apple products to even test it.
Posted: Mon Jun 30, 2014 1:55 pm
Roberto has released an OFFICIAL version of the status app for iOS. That app is located here:
https://itunes.apple.com/us/app/reef-an ... ?ls=1&mt=8
That app is now the default/standard app.
My app will be going away soon. If you have it installed, you can still use it but after July 14, 2014, it will no longer be available on the iTunes Store.
Posted: Mon Jun 30, 2014 3:22 pm
Curt,
Thank you for the time, effort and expense to setup this app in the meantime! Hopefully now you can focus on your awesome android app!
Posted: Mon Jun 30, 2014 3:25 pm
lnevo wrote:Curt,
Thanks! I plan on focusing more on my android app. I have great things in store for it.
Posted: Mon Jun 30, 2014 3:28 pm
by Elevatorguy1
You guys rock!
Posted: Thu Sep 04, 2014 6:04 pm
by treetopflyn
I can't get this to work. It says my forum name is not set up.
Posted: Fri Dec 11, 2015 7:43 am
by bboss
I cannot to get this App to work either. Both my iPhone 5C and iPad Mini return status.html timeout, forum ID not been set, and invalid forum username. I just got my WiFi attachment, configured it and portal is working great.
The App was downloaded from Apple App Store, my iOS version is 9.1on my iPad mini, 9.0.2 on my iPhone.
Am I missing some setting here? Thanks.
Posted: Fri Dec 11, 2015 9:08 pm
It's been relaced by the Universal App. Look for ReefAngel UApp. The current version has a few minor issues with ios9 but hopefully roberto will release the new one soon.
Posted: Fri Dec 18, 2015 3:42 pm
by bboss
lnevo wrote:It's been relaced by the Universal App. Look for ReefAngel UApp. The current version has a few minor issues with ios9 but hopefully roberto will release the new one soon.
Thank you for re-direct me to correct thread. I will wait for the new release.
Posted: Tue Dec 22, 2015 12:52 am
by Ferdi
bboss wrote:I cannot to get this App to work either. Both my iPhone 5C and iPad Mini return status.html timeout, forum ID not been set, and invalid forum username. I just got my WiFi attachment, configured it and portal is working great.
I have the same issue on hand. My friend can connect with no issue on his android phone.
The app works fine on wifi and normal IP address but when i use my "mydns" it gives the same error as bboss mentioned.
Sorry forgot to mention i have the iphone 6S
Posted: Tue Dec 22, 2015 6:34 am
This app is old and deprecated. Make sure to use the current ReefAngel UApp
Posted: Tue Dec 22, 2015 12:12 pm
by Ferdi
lnevo wrote:This app is old and deprecated. Make sure to use the current ReefAngel UApp
Hi lnevo, i am using that app. Version 1.0.2 but its last update was 1 August 2014
If im still using the old version, please add a link as i also only get 1 app in the app store.
Posted: Tue Dec 22, 2015 12:13 pm
Ok there are some issues with ios9. Email Roberto to get access to the dev version.
Also if you load the dev code, the latest uapp is built into the controller. So if your port forwarding is good you could browse to
http://ip.of.controller/wifi
Posted: Sat Jan 30, 2016 7:53 am
by jjdezek
I just updated my app on my phone and it erased my info so I plugged it back in. now I can access the internal memory and clear status but my relay and status icons don't load. keeps saying disconnected.
Posted: Sat Jan 30, 2016 9:56 am
You must update the controller with the latest libraries and you must not use cloud settings.
http://forum.reefangel.com/viewtopic.ph ... ead#unread
Posted: Sat Jan 30, 2016 4:43 pm
by jjdezek
Ok got it figured out thanks.
