Hrmm, I saw the update, installed it, rebooted my phone to verify I am running the new version, and I'm still seeing the same behavior. Is there anything on my side that I might be missing?
I guess the better question, have you released multiple updates today? Maybe I didn't get the most recent one...
Most recent update is 0.4.1.
If you are still seeing the same behavior, could you elaborate more on what your setup is? How many relay boxes do you have installed?
Sure. I just verified I'm running 0.4.1. I am running 2 relay boxes at the moment and both are connected. I have port 2000 forwarded on my router to port 80 on the internal IP address of the wifi module. I can read memory settings as well.binder wrote:Most recent update is 0.4.1.
I can PM you my connection information if it will help with debugging.
Hi,
I am having the same issue. As of the update a few days ago, the Android app got stuck on Parsing forever. I just downloaded the newest update today and it is doing the same thing.
I have 1 additional Relay box (besides the main one). This was working great for me till a few days ago.
I know I am able to reach the box because I can Read and Write Memory and also the Feeding Mode button works. I have Library version 0.8.5.19 and Reef Angel Status version 0.4.1
Don
Don
Yeah, I figured out what the problem actually is now. Thanks to agentgreen for letting me test out on his controller to confirm a couple things. It was a continued error on my part with the only partially implemented expansion relay support. Problem is fixed and will be released shortly.
Just released the fix for the problem. Let me know if it still persists.
Success! Thanks so much!binder wrote:Just released the fix for the problem. Let me know if it still persists.
Ok. I figured out a problem. In fixing the relay box issue, it breaks with the 0.9.0 libraries. It has to do with how the data is sent. There's gonna be one more minor update. So bear with me on this update. This will fix both versions of the libraries now until expansion relays are officially supported.
Works for me too.
Thanks.
Looking forward to having the Expansion Relay Support.
Thanks.
I'm finally diving in to the memory settings in this app and they are awesome. Is there a guide or info available that explains how each setting works? I'm trying understand how the actinic/daylight pwm % settings relate to the pwm slope actinic/daylight end % settings. Does the pwm % setting adjust the maximum intensity that the light will reach once the slope function ramps up fully? Does the slope % end setting set the threshold at which the lights turn off? This setting appears to range from 0 to 255 rather than a 0 to 100 scale?
Thanks Curt that answered my question. It sounds like I need to set the pwm values to 0 when using the slope function and use the pwm slope ____ end % to set the peak values.
That would work just fine. To ensure that, you would most likely need to modify your PWMSlope function call inside your PDE file to have it read the memory values. What we have done in an upcoming release is link the PWMSlope call to the on/off times for your StdLights call. Here's the code you should use to have it mimic that:Mike S wrote:Thanks Curt that answered my question. It sounds like I need to set the pwm values to 0 when using the slope function and use the pwm slope ____ end % to set the peak values.
ReefAngel.PWM.SetActinic(PWMSlope(
InternalMemory.StdLightsOnHour_read(),
InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(),
InternalMemory.StdLightsOffMinute_read(),
InternalMemory.PWMSlopeStartA_read(),
InternalMemory.PWMSlopeEndA_read(),
InternalMemory.PWMSlopeDurationA_read(),
ReefAngel.PWM.GetActinicValue()
ReefAngel.PWM.SetDaylight(PWMSlope(
InternalMemory.PWMSlopeStartD_read(),
InternalMemory.PWMSlopeEndD_read(),
InternalMemory.PWMSlopeDurationD_read(),
ReefAngel.PWM.GetDaylightValue()
Curt,
I was looking into adding support for Relay Expansion boxes to the Android app (mostly because I need it).
I got the code from git and have successfully compiled and run it. I see that you have code to parse the expansion data and store it in the database. I even hacked in code to display the status of expansion relay box 1 on the screen instead of the main one.
I wanted to get your thoughts on how you planned to deal with this. Were you thinking to have some sort of selector that would switch the relay controls from box to box, or were you thinking to add more controls to the scrollable page?
I would like to help out here if I can, some pointers as to your intent would be helpful. Of course if this is somthing you have nearly completed anyway then I will just stay out of your way.
Don
Don
Curt
Anyone else other than me an Roberto getting the error 23 xlm parser error? I can get it to work on ocassion by unplugging my wifi adapter but within a few minutes I get the error again until I reboot it. I can adjust the memory and the relay toggles work. Am I beating my head against a wall for no reason trying to get this to work? Should I just be sitting patiently waiting for an update?
Don -
Glad that the code compiled and ran fine for you. Good to know I uploaded all the proper files.
I have envisioned a swipe left/right to switch screens: Probes | Main Relay | Exp 1 | Exp 2 | etc
I don't really want to make the page longer from top to bottom if I don't have to. I planned on using fragments or something along those lines.
When storing the data from the expansion relay, you gotta be careful because the web banner code uses different relay box references. That's the problem I ran into with the 0.4.1 & .2 releases. I need to revisit the web banner / portal data referencing. The code to handle the retrieval and toggling of ports should exist. It's just "storing" it properly and displaying it.
I'm not close to completing it. I was working a lot with getting the swipe left/right working with a scrollable view (which is tricky to accomplish). I'm also trying to work on an easier way to handle the views without having to repeat a lot of code. I like to make things "elegant" and reuse code if I can instead of just duplicating things. Feel free to work up some suggestions and stuff and share with me. It could definitely help and then I can merge/add it if needed or help with it too.
Mike -
Hmmm....I'm not aware of it happening often. I've not had it happen much on my controllers and one gets accessed VERY often since it's my public one (and the default address when you install the app before it gets configured). I'll take a look at the code more and see if there's anything else that I can come up with for the error. It would be beneficial if I knew your general controller setup. What library version? Quantity of expansion relays? Wifi configuration settings? Is the Portal() enabled in your sketch?
Mike -
Thanks Curt
It started after I installed the new libraries and updated my code using the latest version of ragen with the portal code and added a second relay box. Im 99% sure that i set up the adapter the same way as before with the wifi utility program. I'm using the same IP as before and can see the wifi adapter when i put the IP address in my browser. Do you need to know any other settings for my adpater? The portal isn't working for me yet and my banner isnt updating but I think that is a seperate issue with port forwarding and the ooma voip adapter that i have installed between my router and modem. Trying to tackle on issue at a time. . Oh and I'm seeing the same issue on my phone running ics and my tablet.
I got my android app to work by unintalling the app and downloading it again.
It's working really good now
Yep tried that 2x. I have the app set tl pull the data from my controller. If i set it to get the info from reefangel.com do I just enter my user id ie Mike S? For some reason I think I had a different username entered there.
I don't need any more specific wifi adapter settings than what you mentioned. I'm thinking there is some sort of error or delay being caused by your ooma voip adapter based on you having problems with the portal. There could be some dropped packets somewhere in your network causing the problem. Routing issues can cause problems. It's not a definite answer, just a thought.Mike S wrote:Thanks Curt
I wondered about that but I'm having issues while I'm on my wireless network and the VOIP adapter is between my router and my modem so I wouldn't think that would matter. I can see how it could be causing an issue with trying to commincate externally, but how knows I'm a complete hack when it comes to networking, I ordered a wifi adapter for my VOIP which will eliminate having to feed my modem to the VOIP adapter to the router. I'll let you know how that works in a day or two.
The user id that is in the android app seettings. Is that the same ID that I use on this board? For some reason I have a completely different id noted on my instructions and can't remember why I would have noted it.
With the webbanner stuff, you just had to "pick" a userid and hope it wasn't being used by somebody else. That has changed with the portal. The portal is linked to your login/userid.Mike S wrote:The user id that is in the android app seettings. Is that the same ID that I use on this board? For some reason I have a completely different id noted on my instructions and can't remember why I would have noted it.
So for you, when switching to the Portal, you will want to use your forum userid unless Roberto has other input for you.
Ok so I added a wifi adapter to my Ooma VOIP adapter so that it is no longer between my router and modem. I then went into my router and set up my reef angel wifi adapter ip 192.168.1.101 as a static IP and forwarded port 2000. Rebooted my reef angel wifi adapter and the android app started updating and my portal started updating! Then a few minutes later the dread Error 23: XML SAX Parser error and no more love from the Portal getting the Unreachable Address. I also tried setting my starting IP address at 192.168.110 to avoid conflicts and when I do a port forwarding test it shows it as open. I'm at a dead end and don't know what to do next.
Looks like it was an issue with my wifi adapter. I switched it out last night and it has been working fine. Thanks for the help Curt and Roberto. Roberto if you'd like me to send the old one back can you pm me your address?
that's great to hear. glad it's working. i was gonna do a special build for you but now it's not needed.
i have been trying to use the app, i set everything with IP real and internal but none seen to work.
Have you checked canyouseeme.org to see if your port is actually open?
It is, i use portal and Reef Angel client without problem, but haven't been able to make this app work.
internal ip will only work if you have wifi on your phone turned on. if you use the cellular data connection, you have to use your public ip address. there isn't anything special being done by this app to make it not work?
what is the exact error you are getting?
No error at all, it just don't get or send any data.
