Dimming control on Android App
PostPosted: Mon Feb 03, 2014 9:46 am
Is it possible to control my Daylight/Actinic dimming ports from the android app??
PostPosted: Mon Feb 03, 2014 11:09 am
Yes, if you use the internal memory settings.
Do you have anything in your ReefAngel.LightsOnPorts?
PostPosted: Wed Feb 05, 2014 8:33 am
rimai wrote:Yes, if you use the internal memory settings.
I don't use the internal memory settings. I don't think I have anything in the lights on ports.
PostPosted: Wed Feb 05, 2014 9:50 am
Ok, so let's try this:
ReefAngel.LightsOnPorts=Port1Bit;
Then, use Android app and override port1 on.
It should override both channels to 20% (default).
Then, you can go to internal memory and change the values for memory location Actinic PWM value and Daylight PWM value.
The other much simpler option is to use the new web interface (still in beta, so some browsers may have issues):
Go to http://ipaddress:2000/wifi
Eventually, we will have the override in the Android app :)
Return to Apps
Users browsing this forum: No registered users and 5 guests
