TCP to Serial forwarder
PostPosted: Tue Mar 18, 2014 10:34 am
I've added the solution file to git. I've also updated the application to run as a windows service and included an installer/uninstaller.
The link below will take you directly to the compiled binaries. Simply double click the install.bat file to get up and running.
https://github.com/smande00/ReefAngelTc ... r/Binaries
You'll also want to allow port 2000 through the windows firewall (as well as your router if you want to access this externally over the Internet).
PostPosted: Fri May 30, 2014 3:46 pm
So this allows incoming connection what happens to outgoing for portal updates?
PostPosted: Tue Jul 15, 2014 10:42 am
lnevo wrote:So this allows incoming connection what happens to outgoing for portal updates?
Errr... sorry, obviously haven't checked the forums in awhile. I haven't really messed with the portal to see what it does for updating. I do know it allows Reeftronics to read the controller state and update it's logs for whatever that's worth.
Previous
Return to Apps
