iOS Help
PostPosted: Thu May 01, 2014 2:34 pm
yeah, same here. im getting close to my renewal to my ios subscription. plus im wanting some improvements to the app for ios people...they suffer enough with ios. ;-)
PostPosted: Thu May 01, 2014 5:31 pm
Sorry guys, I've been super busy in the past few weeks with work and some relatives who came to stay with us for two weeks :roll:
I am planning to wrap up the UI by sunday, at least the stuff i got from design. will post a preview link later on sunday.
PostPosted: Fri May 02, 2014 5:45 am
Following this with excitement!
PostPosted: Sun May 11, 2014 6:46 pm
Any updates? Thanks
PostPosted: Thu May 15, 2014 5:23 am
Just to add. The current version of the app does not work with dyndns.
I have been trying for ages, just pops up an error "error parsing XML data"
Also. What is the functionality of the portal username in settings?
PostPosted: Thu May 15, 2014 11:57 am
Poiromaniax wrote:Just to add. The current version of the app does not work with dyndns.
hmmm...it should work with dyndns. that shouldnt make much difference if you are using dyndns. there could be an issue with the parsing of the xml data that is getting you. i will have to look at that then. what version of the libraries are you using?
the portal username does not do anything currently. it was added as a forward thinking strategy.
PostPosted: Thu May 15, 2014 12:05 pm
He is using an older lib since he had a size issue..that could definitely be causing it.
PostPosted: Thu May 15, 2014 12:31 pm
lnevo wrote:He is using an older lib since he had a size issue..that could definitely be causing it.
Currently I'm on 1.0.7 because of size, but direct IP address connection works fine. It's odd, dyndns on the app has never worked for me
PostPosted: Thu May 15, 2014 3:09 pm
hmmm...that is bizarre with dyndns not working. i would not have thought that at all. a puzzler indeed.
PostPosted: Thu May 15, 2014 4:21 pm
Honestly, you said you had problems when the portal gets the IP address from your controller and getting stuck. Thats the same thing dyndns does...your provider could be doing something odd on their network with load balancing and/or nat'ing your outbound connection.
Return to Apps
