Page 1 of 2
Re: iOS Help
Posted: Thu May 01, 2014 2:34 pm
yeah, same here. im getting close to my renewal to my ios subscription. plus im wanting some improvements to the app for ios people...they suffer enough with ios.
Re: iOS Help
Posted: Thu May 01, 2014 5:31 pm
by motti_horesh
Sorry guys, I've been super busy in the past few weeks with work and some relatives who came to stay with us for two weeks
I am planning to wrap up the UI by sunday, at least the stuff i got from design. will post a preview link later on sunday.
Re: iOS Help
Posted: Fri May 02, 2014 5:45 am
by wolffman64
Following this with excitement!
Re: iOS Help
Posted: Sun May 11, 2014 6:46 pm
by Seedlessone
Any updates? Thanks
Re: iOS Help
Posted: Thu May 15, 2014 5:23 am
by Poiromaniax
Just to add. The current version of the app does not work with dyndns.
I have been trying for ages, just pops up an error "error parsing XML data"
Also. What is the functionality of the portal username in settings?
Re: iOS Help
Posted: Thu May 15, 2014 11:57 am
Poiromaniax wrote:Just to add. The current version of the app does not work with dyndns.
hmmm...it should work with dyndns. that shouldnt make much difference if you are using dyndns. there could be an issue with the parsing of the xml data that is getting you. i will have to look at that then. what version of the libraries are you using?
the portal username does not do anything currently. it was added as a forward thinking strategy.
Re: iOS Help
Posted: Thu May 15, 2014 12:05 pm
He is using an older lib since he had a size issue..that could definitely be causing it.
Re: iOS Help
Posted: Thu May 15, 2014 12:31 pm
by Poiromaniax
binder wrote:Poiromaniax wrote:Just to add. The current version of the app does not work with dyndns.
lnevo wrote:He is using an older lib since he had a size issue..that could definitely be causing it.
Currently I'm on 1.0.7 because of size, but direct IP address connection works fine. It's odd, dyndns on the app has never worked for me
Re: iOS Help
Posted: Thu May 15, 2014 3:09 pm
hmmm...that is bizarre with dyndns not working. i would not have thought that at all. a puzzler indeed.
Re: iOS Help
Posted: Thu May 15, 2014 4:21 pm
Honestly, you said you had problems when the portal gets the IP address from your controller and getting stuck. Thats the same thing dyndns does...your provider could be doing something odd on their network with load balancing and/or nat'ing your outbound connection.
iOS Help
Posted: Thu May 15, 2014 10:24 pm
by Poiromaniax
lnevo wrote:Honestly, you said you had problems when the portal gets the IP address from your controller and getting stuck. Thats the same thing dyndns does...your provider could be doing something odd on their network with load balancing and/or nat'ing your outbound connection.
I've never had issues with any of my other dyndns connections (VPN, web based ui for an application)
What happens on the portal is that the portal removes my dyndns address from the settings and replaces it with whatever the controller sends it. So if my AP closest to the RA gets turned off or reboots (happens sometimes), then the RA doesn't automatically reconnect to the wifi when it comes back up. I have to unplug the wifi module and replug. This is when the portal gets "stuck"
I can browse to the RA web server using my dyndns address with no problem, every time. Never get any errors
Re: iOS Help
Posted: Sun May 25, 2014 2:00 pm
by morn623
Am I correct in assuming the iPhone app does not currently work to access your RA remotely? I think I've tried everything and can't get it to work. I am able to access my RA through the portal so I imagine the issue has to be with the app.
Re: iOS Help
Posted: Sun May 25, 2014 2:46 pm
morn623 wrote:Am I correct in assuming the iPhone app does not currently work to access your RA remotely? I think I've tried everything and can't get it to work. I am able to access my RA through the portal so I imagine the issue has to be with the app.
no. it works. i have it installed on my ipad. i have only heard of 1 person who had issues with the dyndns resolution and using the app (previously mentioned).
the app for ios 7 is limited in what it can do but it should work.
Re: iOS Help
Posted: Mon May 26, 2014 6:50 am
by Seedlessone
Can we try to take donations so we can hire someone to build app? I know a few people that I could get some leads for pricing...
Total first world problems here, but the lack of a full blown IOS app kills the RA for me.
And please dont get me wrong I apprciate the new app greatly, its just not as full featured as the andriod version.
Re: iOS Help
Posted: Mon May 26, 2014 9:05 am
It's being worked on by Motti. Hopefully he can give us a status update soon.
Re: iOS Help
Posted: Mon May 26, 2014 11:54 am
by Seedlessone
lnevo wrote:It's being worked on by Motti. Hopefully he can give us a status update soon.
He was suppose to update us like 3 weeks ago. Not being a downer but Im starting to loose faith.
Re: iOS Help
Posted: Mon May 26, 2014 5:37 pm
by Seedlessone
Actually put some more hands on with the new app. Its acutally pretty darn good and Curt has done a great job. I know that IOS is not his forte.
The only big thing now and its acutally not that big is the ability to rename ports. Curt is this an easy add on?
Re: iOS Help
Posted: Mon May 26, 2014 7:48 pm
Seedlessone wrote:Actually put some more hands on with the new app. Its acutally pretty darn good and Curt has done a great job. I know that IOS is not his forte.
I'm not sure. I will have to check on it more. the nice thing is I use logic and code from my Android app to help out (just have to convert it to obj c).
thanks for the feedback
Sent from my Moto X
Re: iOS Help
Posted: Tue May 27, 2014 6:48 am
by Poiromaniax
binder wrote:morn623 wrote:Am I correct in assuming the iPhone app does not currently work to access your RA remotely? I think I've tried everything and can't get it to work. I am able to access my RA through the portal so I imagine the issue has to be with the app.
Is there any way I can logs from the app so you can check my issue? (I have Xcode on my laptop)
Re: iOS Help
Posted: Tue May 27, 2014 1:43 pm
Poiromaniax wrote:binder wrote:morn623 wrote:Am I correct in assuming the iPhone app does not currently work to access your RA remotely? I think I've tried everything and can't get it to work. I am able to access my RA through the portal so I imagine the issue has to be with the app.
you should be able to download my project from github and then just run it through the emulator and look at the output log window.
