Universal App
Re: Universal App
Try deleting the profile and creating a new one and make sure that you do not type anything on the cloud section. You may also need to use the Uapp without the ssl.
http://forum.reefangel.com/uapp
kirkwood
Re: Universal App
Post by kirkwood »
Thank you. I used the link you provided - entered my IP and port -and it worked.
dapg8gt
Re: Universal App
Post by dapg8gt »
rimai wrote:I made a change to the portal page.
Try again.
You may need to reload the page by holding shift while clicking the refresh icon.
I also fixed the issue with the certificate expired.
Thanks I'll get in this again. So please disregard the PM I just sent lol. I need to turn on the notification for forum replies.. Happy holidays everyone..
dapg8gt
Re: Universal App
Post by dapg8gt »
So I got it all working again( thanks for adjusting the portal ) but for some reason just in the U App webpage it won't list the main relay . It has expansion 1&2?
Got the labels fixed on the portal but the main relay labels are not there and exp 2 controls the main relay ?
Also no matter how many times I upload from wizard it has my expansion relay(older style )as the fist relay not the newer one from the *?
I think something is compiling wrong as it thinks I have two expansion relays when I only have one. I can control /toggle the relays but it's off by a full 8outlets ?
Edit : I just named the outlets for exp 1&2 to transfer them to the U APP.. work around is fine but weird how I can't see main relay and unable to just have the newer relay as the "Main".
Noticed the head unit doesn't save /Display the correct date and time after a reboot. Does this just take a bit ?
I tried not choosing expansion module etc all the same.
How do I get the main relay to show on the U APP? It's accurate on the portal I just can't control them due to port forwarding.
Re: Universal App
The RA* doesn't have a main box. Only expansion boxes
edisonvs
Re: Universal App
Post by edisonvs »
Could you check new version of app please. When I install app it gives me screen as on picture. All buttons are non responsive.
brennyn21
Re: Universal App
Post by brennyn21 »
Please clear you cache/cookies
Sincerely, Brennyn
