Page 7 of 8
Re: Universal App
Posted: Mon Oct 17, 2016 4:47 pm
by Smotz
I understand the tunneling work around but I would really like it if the U-App could support the wifi authentication.
Re: Universal App
Posted: Sun Nov 20, 2016 6:46 pm
by troylong45
Is not working for app pack for Android no file found or something like that
Re: Universal App
Posted: Sun Nov 20, 2016 7:21 pm
Fixed.
You should be able to download now.
You can also use the web version of the Uapp:
http://forum.reefangel.com/uapp/
Re: Universal App
Posted: Mon Nov 21, 2016 12:39 pm
by Smotz
You guys are awesome
Re: Universal App
Posted: Sun Dec 11, 2016 1:52 pm
by troylong45
is there a app for windows 10 tablet
Re: Universal App
Posted: Sun Dec 11, 2016 2:04 pm
The Uapp is browser based. It should work on any browser.
Re: Universal App
Posted: Sun Dec 11, 2016 2:36 pm
by troylong45
if i use the browser how do i get on it from there and can i get it to do live feed vs updates every XXX mins
Re: Universal App
Posted: Sun Dec 11, 2016 3:49 pm
Live feeds is only possible with the cloud server.
The current wifi attachment cannot connect to the cloud server.
You will need the cloud wifi attachment that has not been released yet.
The cloud server implements MQTT protocol so live feeds get updated on the fly on Uapp through jquery and paho mosquitto library.
Re: Universal App
Posted: Sun Dec 11, 2016 3:52 pm
If you want to see it working, go to
http://forum.reefangel.com/uapp/ and add a new controller with these settings:
Name: Anything you want
ip address: leave blank
port: leave blank
username: cloudtest2
password: 123456
I have this test controller online right now.
Re: Universal App
Posted: Fri Mar 10, 2017 3:46 pm
by GugsJr
I wasn't sure if I should add the request here or into it's own thread. Figured why add an extra thread.
For the Android App could you make it that when you get a flag (lets use ATO), and you go to the flag section it will clear if you tap it instead of going into the menu?
Re: Universal App
Posted: Sun May 27, 2018 7:19 pm
by troylong45
If I go to the U app web base on a Android device if I go into draw graphs I do not get to see the full graph if I do at least custom for pwme4,pwme5 it only shows me a portion of the screen graph I think maybe there's a browser display size issue or something I don't know
One pic is landscape other is portrait orientation
- 20180527_221703.png (111.73 KiB) Viewed 17708 times
- Screenshot_20180527-221055.jpg (215.77 KiB) Viewed 17708 times
Re: Universal App
Posted: Thu Feb 14, 2019 11:34 pm
by tkeracer619
My wife got me a 10 inch tablet to use as the main interface for the controller. Would it be a lot of trouble to do some formatting changes to the UAPP?
It would be nice if the Relays were tiled instead of vertical. I think you could go 3 wide and it would make it so you wouldn't have to scroll to see status of or change relay outputs.
Also, It would really be nice if we could create/save a default graph setting.
Re: Universal App
Posted: Thu Feb 14, 2019 11:52 pm
by tkeracer619
Maybe even 4 relay boxes wide... example.
Re: Universal App
Posted: Thu May 16, 2019 9:01 pm
Re: Universal App
Posted: Fri May 17, 2019 10:07 am
by sbidny
Just a heads up that it appears Safari heavily caches this site on an iPhone. You need to do clear the cache in order to view the new site properly.
Go to Settings -> Safari -> Advanced -> Website Data
Search for "reefangel.com," swipe the entry, and click "Delete."
Now you should be able to reload with the new site.
Re: Universal App
Posted: Mon May 20, 2019 12:56 pm
by sbidny
@tkeracer619, I have a working version with a responsive layout for the relays. It will lay as many as possible across horizontally before wrapping to the next line, depending on the device being used. I need to do a little more testing, but I'll try to get this over to Roberto in the next few days.
Re: Universal App
Posted: Mon May 20, 2019 10:32 pm
v2.0.8 release.
Bug fixes
Changed to secure SSL connections.
Re: Universal App
Posted: Tue May 21, 2019 3:36 am
by sbidny
Seeing the new version after clearing my browser cache. Glad to see the move to SSL.
Re: Universal App
Posted: Tue May 21, 2019 3:42 am
by sbidny
Looks like auto-reconnect broke after moving to SSL. Will take a look today. Likely just a different disconnect code, as I check the code before attempting a reconnect.
Re: Universal App
Posted: Fri Jun 12, 2020 11:13 pm
by dapg8gt
How can I get my labels onto the U app? Its written in my code ( Bottom in grey font) but wont show or upload into the app.
Is there a way I can force it ? I had a heck of a time getting my web wizard code to compile the same code it just uploaded onto the controller that is saved and when it did the com port would disappear etc.
I'm trying to not ask for everything but its been two days of research / attempted Work arounds( Portal) trying to get port forwarding working on my ORBI mesh system, Getting the android app to work until 10:35 tonight ( Mesh system opened up port 2000 on my external ip somehow allowing the android status app to work ) then after I spent time changed labels it stopped working once I triggered a reboot from the status app on the *.
The web Wizard does still have the ability to add labels right ? Is there a command prompt i need to add to the wizard to include the labels on the app? I got all 16 relays working , timers functioning , dosing pumps schedule running but I just cant get the labels to come through .
I know the forum isn't very busy anymore but I need a work around or advice please . Thanks
Re: Universal App
Posted: Sat Jun 13, 2020 3:40 am
by cosmith71
Enter them into the Portal, then "Download Labels from Portal" in the Uapp menu.
Re: Universal App
Posted: Sat Jun 13, 2020 5:54 pm
by dapg8gt
I've been trying to get into the portal but my new Mesh system wont allow me to forward the port . I got rid of my ISP gateway and bought my own and a mesh router system so something is not working.Inside the router it is set up to have 2000 open but it's just not physically open on the reserved IP address of the RA.
I'm going to have to find my old router or something ,Been on with netgear support and they had me do everything I already had done and the conclusion by them was "It should be working" with no resolution other than it must be your internet company.. .
I wish I could get into the portal without port forwarding. I need to try to figure out a way to temporarily get a port forwarded or something.
Re: Universal App
Posted: Sat Jun 13, 2020 8:19 pm
Just to change the labels, you don't need to get port forwarding setup.
Why do you want to get the portal connected to your controller with port forwarding?
Re: Universal App
Posted: Sat Jun 13, 2020 8:53 pm
by dapg8gt
rimai wrote:Just to change the labels, you don't need to get port forwarding setup.
Whenever I click on the labels or Portal settings it just clicks me to the top of the page .
I don't seem to have any option to click on any of the options . When I click on it it brings me up to show the top of the page like where the user control panel is and says an error occurred .The way to adjust is to just click on the area I have circled right?
Can you delete the portal info for my acct and let me start from scratch?
Can I literally start a new username and just go from there?
I tried it on two seperate computers just now and still same.
Also Google is saying the time cert for the website is unsafe or something ? My phone did it earlier and now both my laptops I had to bypass and proceed anyway .
Re: Universal App
Posted: Sun Jun 14, 2020 9:47 pm
I made a change to the portal page.
Try again.
You may need to reload the page by holding shift while clicking the refresh icon.
I also fixed the issue with the certificate expired.
Re: Universal App
Posted: Wed Jun 17, 2020 11:36 am
by kirkwood
I have Uapp on iPhone 10. What do I need to enter in the app settings to make this work? My login works in the portal and I have tested that my port is "open". The Uapp status tab reads "Cloud status: Disconnected" "Current mode: Nominal"
Re: Universal App
Posted: Wed Jun 17, 2020 11:44 am
Do you have the RA* or the cloud wifi attachment?
Re: Universal App
Posted: Wed Jun 17, 2020 11:47 am
by kirkwood
RA+.. I see my profile shows I joined in 2013 so that is when I purchased my equipment..
Re: Universal App
Posted: Wed Jun 17, 2020 11:51 am
Cloud feature is only available with RA* or with the cloud wifi attachment.
So, on Uapp, you enter the IP address and port and leave the cloud username and password blank.
Re: Universal App
Posted: Wed Jun 17, 2020 12:05 pm
by kirkwood
Yes I have done that and still get no response on the "status" page. If I try to press a function like "clear ATO" I get "unable to process controller data!". I have the android app on an old tablet with the same IP and Port data entered and it works fine.
