Android App with multiple Reef Angels
Posted: Thu Aug 28, 2014 6:32 pm
by hnnhflns
I have two reef angels running two separate tank systems. I have one tank running through the andriod app on my phone. I was wondering if there was a way to access both reef angels in the same app.
Thanks for any input!
Re: Android App with multiple Reef Angels
Posted: Thu Aug 28, 2014 6:39 pm
by binder
hnnhflns wrote:I have two reef angels running two separate tank systems. I have one tank running through the andriod app on my phone. I was wondering if there was a way to access both reef angels in the same app.
The "simplest" way to do it would be to setup the home and away profiles. All the data gets merged together as far as being stored and they act as the same unit, but you can at least monitor and control them. I would not suggest using notifications based on parameters unless you wanted them to be the same.
You will still have all the same functionality with using the home and away profiles. the only drawback (besides the notifications mentioned above) is the auto updating. that will only work for one reef angel.
i have been trying to figure out a good way to handle multiple reef angels using my Android Status app but have not implemented it yet.
You could try the Universal App on Android....I think it has the ability to handle multiple RAs.
Posted: Thu Aug 28, 2014 6:51 pm
by hnnhflns
Ok. Thank you!
I have had great results with your Android Status app. I hope you find a way to handle more than one angel with it!
Posted: Fri Aug 29, 2014 4:10 am
by binder
hnnhflns wrote:Ok. Thank you!
I have an idea how to do it, but I have not had time to sit down and implement it.
Sent from my Moto X
