Reef Angel Status apk running on Blackbery Z30...
Posted: Tue Oct 21, 2014 7:33 am
by bece13
I installed Reef Angel Status v 1.0 apk on my Blackberry Z30 (BB10 OS) and is working fine on Home (connected over my home wireless network) and on Away (connected over an external wifi network). However is not working on Away connected over my data plan. When I tap on the refresh button nothing happens. Also tried to run the app on my Nexus 7 tablet connected to internet through my Z30 over data and it worked (away mode). So I believe it's not my mobile data provider. My feeling is that some functions in the apk might not be fully compatible with Blackberry way of running apks.
Thanks in advance for any ideeas?
Re: Reef Angel Status apk running on Blackbery Z30...
Posted: Tue Oct 21, 2014 10:21 am
by binder
hmm. that is odd. the only difference between home and away modes is the host and port of the controller. what error message is being displayed?
have you tried to put your external ip/host in the home mode and run it that way?
Sent from my Moto X
Posted: Tue Oct 21, 2014 12:53 pm
by bece13
Home and away are working fine as long as I'm connected over wifi. As soon as turn off my wifi and try to connect over mobile data, the refresh button doesn't work anymore. I press it and nothing happens. No error messages. If I switch back to wifi everything is fine again.
Posted: Tue Oct 21, 2014 2:41 pm
by binder
there must be something that BB does differently with the device when using wifi vs mobile data. my app does not distinguish between the 2. the only thing with connectivity that my app does is it verifies that there is a network connection through the android calls to determine if there is network connectivity. if there is no connectivity, it displays a "toast"/popup message that says there is no internet connection and it does not proceed. i wonder if that is hanging up your device?
Posted: Tue Oct 21, 2014 7:39 pm
by bece13
Thanks Curt,
I know it's weird as I don't get any messages. Maybe the next version of BB OS 10.3 due to be released soon will fix the issue. I'll keep trying and I will let you know if I find anything. At least is working over wifi. :-)
Posted: Wed Oct 22, 2014 11:51 am
by binder
ok cool. yeah I know bb does things differently. there were issues with the app not running in the past due to how bb handles android apks. guess we will just have to wait and see.
Sent from my Moto X
