Page 1 of 2
host unreachable error
Posted: Tue May 26, 2015 11:18 pm
by MDB1029
On the android app, any time i try to update, it gives me error 13 host unreachable. The portal works fine, i am sure i just don't have something configured properly. Any suggestions?
Re: host unreachable error
Posted: Wed May 27, 2015 8:06 am
on wifi or cellular network?
Sent from my Moto X
Posted: Wed May 27, 2015 10:01 am
by MDB1029
It gives me that error on both Wi-Fi and cellular network. It will show me my parameters but gives me this error if i try to change anything.
Posted: Wed May 27, 2015 12:16 pm
do you have other devices communicating with the controller at the same time? i have encountered that before if i am connected to the controller and then try to issue an additional command.
do you have device authentication enabled on the controller?
Posted: Wed May 27, 2015 12:22 pm
by MDB1029
I don't have authentication on it yet.
My computer may have the portal up, but nothing else.
Posted: Wed May 27, 2015 1:32 pm
by MDB1029
Update
On the portal when i am not at home it tells me 'unreachable address' as well. I guess it only works correctly from my home computer. I don't know if this info will help with resolving the app issue or not.
Posted: Wed May 27, 2015 5:22 pm
ok. are you using your internal ip address, the public ip address or a domain name (dynamic domain name)?
are you certain you have port forwarding setup properly on your router? im just asking and making certain everything is setup properly.
Posted: Wed May 27, 2015 8:12 pm
by MDB1029
You are gonna hate me by the time we get this figured out.
binder wrote:ok. are you using your internal ip address, the public ip address or a domain name (dynamic domain name)?
I believe i set it up correctly but i probably didn't. I used a guide which i can't seem to find which had me set up a dynamic domain name and I tried to set it up as well. I also think i set up the port forwarding correctly but again i am not sure. Do you hate me yet?
Is there a way to check if the port forwarding is set up correctly?
Posted: Thu May 28, 2015 12:11 am
by MDB1029
So it seems the port forwarding is not correct, anymore. It was working for the portal but apparently stopped working on the 23rd. It was updating my temp and pH on my phone for a while but i was never able to control anything from the app even when on my home wifi but i was able to control it from the portal from home on my computer.
Posted: Thu May 28, 2015 4:52 am
Lol...no I don't hate you. It is just part of getting things up and running.
I would get the port forwarding corrected and that should get things working.
As for the dynamic dns, using the one provided by reef angel is probably the easiest (once you have port forwarding working).
Posted: Sun May 31, 2015 9:34 pm
by MDB1029
binder wrote:Lol...no I don't hate you. It is just part of getting things up and running.
For some reason I can not get the port forwarding to work. I have been working on it since Thursday and have had no luck. I have read article after article and still it is just not working. Do you have any advice in this area? I must be missing something but have no idea what it is.
Posted: Mon Jun 01, 2015 12:42 pm
with the port forwarding, there are a couple things you must do..
1. assign a static ip to the reef angel either via static ip or a static dhcp lease
2. forward port 2000 tcp in your router to the static reef angel ip at port 2000 tcp
3. ensure you have a dynamic dns host name point to your router / public ip
the first 2 options give people trouble. i would focus on them in this order. make sure you can communicate with your controller at its internal ip address. then make certain the port is open and forwarding, then worry about the dynamic dns.
Posted: Mon Jun 01, 2015 2:36 pm
by MDB1029
On the wifi adapter, the blue light is on solid and then it will fast blink and the green will slow blink. Could something with it not be setup correctly?
Posted: Mon Jun 01, 2015 3:05 pm
blink blue led means it is not connected to your router.
Posted: Mon Jun 01, 2015 6:20 pm
by MDB1029
What about it being solid blue? It is sold blue 90% of the time and then will fast blink blue and slow blink green.
I am really confused because it was working fine with the portal for about 3 weeks then just stopped and i did absolutely nothing to it.
Should i reset the Wi-Fi and go through the setup again? Any other suggestions?
Posted: Mon Jun 01, 2015 11:29 pm
by MDB1029
OK, so after redoing everything i have at least made some headway.
The wifi adapter started working correctly once i unplugged it from the controller and plugged it back in
Setup a new DNS so the app is working on the wifi and on the cellular network.
The Portal on the other hand is a different story.
I put the new DNS info in on the Control Panel - Profile screen and it will update, still says Host Unreachable Error, for a moment, but unable to toggle any of the relays or access the internal memory, and then it reverts back to an IP address which doesn't work.
So this is basically a Portal issue now, should I start a new thread there? I read a thread which had the same issue going on but its resolve is not working for me.
Posted: Tue Jun 02, 2015 1:53 pm
MDB1029 wrote:OK, so after redoing everything i have at least made some headway.
thats good to hear things are moving in the right direction.
I'm not sure about the portal issue though. roberto would be a better answer for that. yeah, i would think that starting a new thread over there would be smart...so it can be easier to locate in the future for others having a similar issue.
Posted: Thu Jun 04, 2015 4:23 pm
by MDB1029
binder wrote:thats good to hear things are moving in the right direction.
So as i was typing out that everything was working, Portal, and App, it decided nothing was going to work at all. So i am basically back to square one 1 minute after i was 100% done.
I have no idea why it stopped again but needless to say i am extremely frustrated.
Posted: Thu Jun 04, 2015 6:27 pm
I wonder if something is going on with your wifi module. sometimes they can drop their connection to the controller and have to be unplugged and plugged back in.
Sent from my Nexus 7
Posted: Thu Jun 04, 2015 6:30 pm
Is it blinking blue?
Posted: Thu Jun 04, 2015 8:08 pm
by MDB1029
binder wrote:I wonder if something is going on with your wifi module. sometimes they can drop their connection to the controller and have to be unplugged and plugged back in.
That is exactly what it did. Unplugged and plugged back in and everything is working perfectly.
rimai wrote:Is it blinking blue?
It was blinking blue the other day. I basically unhooked it from the controller and plugged into my laptop got distracted with whatever else was going on and then plugged it back into the controller and it started working again at that point.
Is there something i am doing wrong or is there something else i need to do to get it to stay connected correctly? I am not so great with computer stuff but am not an idiot and will get something figured out if i am pointed in the right direction.
I basically followed the "wifi attachement manual" following method 1, i used a document which doesn't have a title on it, at least no title page printed, which says it is a step by step guide for worldwide access to your reefangel server, and i don't know if i did this last one correctly or not about setting up a static IP.
I have got the port forwarding figured out or at least working and i think i have a DHCP reservation on my router for the controller and i am not sure if that is different than a static IP or not.
Is there anything else i need to do to make this reliable? I am wanting to add password to it as well but i wanted to make sure everything was working properly before i take that step.
Posted: Thu Jun 04, 2015 9:27 pm
That looks like it is loosing the connection.
Is it far from the router?
Posted: Thu Jun 04, 2015 9:42 pm
by MDB1029
rimai wrote:That looks like it is loosing the connection.
Not at all. I could literally set the wifi adapter on my router.
Posted: Fri Jun 05, 2015 8:49 am
Maybe some unknown interference?
Are you able to try it on another router?
Posted: Fri Jun 05, 2015 9:04 am
by MDB1029
unfortunately, i don't have another router to use.
Posted: Fri Jul 24, 2015 10:31 pm
by MDB1029
So I am getting this error again but only on the android app and only on cellular network. Any ideas how i could fix this?
Posted: Sat Jul 25, 2015 10:01 am
Check the port forwarding on your router
Posted: Thu Aug 06, 2015 10:47 am
by MDB1029
I checked it again. It seems to be working. But now the portal is giving me the unreachable host error again. This error is the bane of my existence
Posted: Thu Aug 06, 2015 11:55 am
I has to be port forwarding.
When you check port 2000, what do you get?
Posted: Fri Aug 07, 2015 9:12 am
by MDB1029
"Port 2000 is open"
