android app
PostPosted: Sat Mar 12, 2016 8:26 pm
i can connect to my controller as long as im on my home wifi but if i turn it off and try from LTE it times out. I forwarded the port to 2000 on my router for ip 192.168.2.6 but it doesnt seem to be working off of my home network. if i change the app to portal it will work off LTE
PostPosted: Sun Mar 13, 2016 6:58 am
do you have your public ip set in the app?
your internal ip will not work outside of your network.
PostPosted: Sun Mar 13, 2016 7:15 am
I finally got it working using the dmz setting on my router
PostPosted: Mon Mar 14, 2016 5:21 am
Whats the green circle that come up on the page where you can turn equipment on and off? Thanks in advance
PostPosted: Mon Mar 14, 2016 9:52 am
that means that the port has been forced on or off (overrode the default). the port will stay in that position until you tap the green dot to restore it to normal auto operation
PostPosted: Mon Mar 14, 2016 9:53 am
this is useful if you want to turn something off to replace and you don't want it to come back on until you are ready or other various options.
PostPosted: Mon Mar 14, 2016 9:56 am
Thanks binder
PostPosted: Mon Mar 14, 2016 11:24 am
bkc6868 wrote:Thanks binder
welcome.
Return to Apps
