android app
Posted: Sat Mar 12, 2016 8:26 pm
by bkc6868
i can connect to my controller as long as im on my home wifi but if i turn it off and try from LTE it times out. I forwarded the port to 2000 on my router for ip 192.168.2.6 but it doesnt seem to be working off of my home network. if i change the app to portal it will work off LTE
Re: android app
Posted: Sun Mar 13, 2016 6:58 am
do you have your public ip set in the app?
your internal ip will not work outside of your network.
Re: android app
Posted: Sun Mar 13, 2016 7:15 am
by bkc6868
I finally got it working using the dmz setting on my router
Re: android app
Posted: Mon Mar 14, 2016 5:21 am
by bkc6868
Whats the green circle that come up on the page where you can turn equipment on and off? Thanks in advance
Re: android app
Posted: Mon Mar 14, 2016 9:52 am
that means that the port has been forced on or off (overrode the default). the port will stay in that position until you tap the green dot to restore it to normal auto operation
Re: android app
Posted: Mon Mar 14, 2016 9:53 am
this is useful if you want to turn something off to replace and you don't want it to come back on until you are ready or other various options.
Re: android app
Posted: Mon Mar 14, 2016 9:56 am
by bkc6868
Thanks binder
Re: android app
Posted: Mon Mar 14, 2016 11:24 am
bkc6868 wrote:Thanks binder
welcome.
