Reef Angel Web Wizard
PostPosted: Fri Oct 07, 2016 1:56 pm
I did not have the TTL cable connected as I usually use Bluetooth. :D
I hooked one up but got the following message:
Attempting to upload your code to RA_PLUS on local port COM4 ...
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
Could not program the board
It's set to COM4, but looks like it's trying to open COM3.
PostPosted: Fri Oct 07, 2016 2:13 pm
Bug. I hard coded COM3 when testing.
Let me fix it and I'll update shortly
PostPosted: Fri Oct 07, 2016 3:12 pm
Try again.
PostPosted: Fri Oct 07, 2016 3:16 pm
Appears to work! Compiled and uploaded successfully.
PostPosted: Fri Oct 07, 2016 3:18 pm
Awesome!!! :)
PostPosted: Fri Oct 07, 2016 8:35 pm
Can this fix my issue with the other boards? :)
PostPosted: Fri Oct 07, 2016 8:56 pm
I don't know how you were able to upload codes because there was a misconfigured option on the config.ini file.
I updated it, so you should reinstall.
Also, I just updated the original post with links for the Win and Mac versions of the plug in.
@lnevo, hopefully it will. I have not tried other boards just yet. I wanted to get the ones that use avrdude first.
PostPosted: Fri Oct 07, 2016 8:58 pm
Ahh. On a second look, the settings wasn't related to upload codes, but to download other stuff that we may need in the future.
PostPosted: Sun Oct 09, 2016 6:31 pm
lnevo wrote:Can this fix my issue with the other boards? :)
I think this is working too :)
Can you test?
Unfortunately, it is still using the ssid, password and cloud settings of the original RA_CustomSettings.h file.
I need to come up with a plan to be able to update that on the fly, but you should be able to test the upload feature to the board.
PostPosted: Wed Oct 12, 2016 12:40 pm
Ok, I implemented today the ability to save sketches on the cloud.
No more loosing your sketches because of computer crash :)
Wizard is still not implemented.
Test it out and let me know how the save and open files are working out.
Return to Apps
