Reef Angel Web Wizard
Re: Reef Angel Web Wizard
I think it is the same
mav3rick478
Post by mav3rick478 »
I kept getting Error 400 last night. I'll try again tonight.
Sent from my Pixel XL using Tapatalk
jgwinner
Post by jgwinner »
I just got the Cloud Portal. I downloaded the latest RA code, ReefAngelInstaller_1.1.3.exe. (I had 1.1.1 installed before that).
Installed.
Per the docs, used the WebWizard. Got a sketch. Copied it to my development machine (I use vMicro, but for this I used the RA Arduino fork executable). A snippet of the problem code:
	ReefAngel.CloudPortal();
I get an error:
Error: 'class ReefAngelClass' has no member function named 'CloudPortal'
Indeed, I downloaded the Github code (https://github.com/reefangel/Libraries) and find that the word "CloudPortal" does not exist in any of the library files, and is not a member of ReefAngel.cpp. I even followed breadcrumbs to https://github.com/lnevo but it's the same as what's checked in under ReefAngel.
So what do I have to do to get this to compile?
== John ==
Try using the dev branch of the github
jgwinner
Post by jgwinner »
rimai wrote:Try using the dev branch of the github
That seems better, BUT ...
Then the "Dev" branch needs to be copied over, or the docs need updating. This is crazy.
I copied over the dev branch to my user folder (%USER%\Arduino) and now I'm getting a ton of compiler errors. Can't quite tell if the Dev branch is Arduino 1.0.1 or something newer. This is harder than it should be.
Is this product dead? :(
No. The dev branch is the latest. It is what it is used on the web wizard.
I decided not use the Arduino IDE for mainstream anymore. It is only used for development.
The webwizard is what you want to use if you don't want to worry about compile errors.
Link for webwizard: http://forum.reefangel.com/webwizard
Now, if you are talking about doing library development, then it is another story. You will need the IDE.
So, I would suggest just going to webwizard and doing all the compiling and uploading in there.
jgwinner
Post by jgwinner »
I am doing development :(
Or, I was ... I copied over my code into the web wizard and at least sort of got it to work.
sbidny
Post by sbidny »
rimai wrote: So, I would suggest just going to webwizard and doing all the compiling and uploading in there.
But how do you suggest we do this if we use the Bluetooth adapter for upload?
mav3rick478
Copy and paste into the Audrino app and upload with the Bluetooth adapter, it's just more convenient because it's wireless.
sbidny
Post by sbidny »
But that’s the problem. The web wizard is using the dev branch, which works with the cloud portal. The 1.1.3 libraries don’t support this in Arduino. And the web wizard doesn’t support the Bluetooth adapter.
Just a few posts above, it sounded like copying the dev branch locally was causing a bunch of compile errors. I haven’t tried doing this myself yet, though.
Seems odd to me that the web wizard would be using the dev branch and not a release branch. And why hasn’t the cloud portal made it into a release branch yet if it’s being sold?
The release branch is quite old and hasn't been updated in a few years. As we've moved to the web wizard we can keep it up to date much easier. The RA libraries work just fine with the latest dev branch, you just get the compile errors but it does work. The bluetooth adapter just gives you a serial link over bluetooth to do the updating instead of using serial.
As far as the release branch, I was looking at it the other day and thinking it's probably a good time to update the master branch :) Overall that would be Roberto's call and will probably require re-packaging the local Arudino client which was quite a pain in the butt honestly, but I do affirm that if you download the latest and replace the libraries with the DEV branch you should be OK aside from the verbose compiler output.
spinev
Post by spinev »
Hi, I have a Reef Angle Star and have amended the code through the Web Wizard. The code is compiled successfully and I have also the Plug in found and connected in blue. However I cannot connect to any port. I am using the usb cable with my pc supplied. Any idea what I should do, cause I cannot upload the code on the unit.
Go to "Device Manager" on windows and expand "Ports (COM & LPT)"
Disconnect RA from the computer. Do you see any port disappear?
Now connect it back in. Do you see any port show up?
SouthernReefer
Post by SouthernReefer »
rimai wrote:Go to "Device Manager" on windows and expand "Ports (COM & LPT)"
Having the same problem. The Machine sees it as com 3, but still get the can not program board.... ive tried a few times. Code compiles etc. Im jut trying to get this done so i can finish cable managing. Ill do rest remote
Paulturner911
Post by Paulturner911 »
Roberto had me buy the Cloud Wifi Attachment to combat an intermittent connectivity issue with the old wifi attachment and I cannot upload.
I have a solid cyan light in the cloud module.
I have run the wizard and wrote a new code.
I downloaded and installed the plug-in, but the wizard says "Plugin was not found"
I cannot see any com ports or remote upload through the wizard, but I see them in device manager.
Any help would be great.
Thank you
Are you using chrome?
Paulturner911
Brave browser
Paulturner911
rimai wrote:Are you using chrome?
I switched to edge and that fixed the plugin. Still no com ports.
Wouldn't this allow me to remote upload with out using the usb?
No. remote upload is an experimental feature available for RA* only.
Paulturner911
Im getting somewhere. I was able to get COM5 and push an update to the controller. When I view the webpage for the controller it says disconnected. Ill start with resetting the password.
What else should I be looking at?
Go to Uapp: https://forum.reefangel.com/uapp/
Make sure to delete the old profile if you have one
Create a new profile and make sure to enter only username and password and leave the port and ip address alone.
